I have been a very keen patron of main line steam specials for nearly 40 years, but my enthusiasm has significantly waned due to the issue of 'shoveage' i.e. diesel assisting at the rear.
Not sure about faceache, but it has been a hot topic on the NatPres (National Preservation) website for some time!
My principal interest is train timing / loco performance. I want to appreciate what the loco at the front is doing, not having to work out how much help is coming from the rear.
In my experience, the addition of a diesel makes it highly likely that assistance will be given as the load is increased and it's more difficult to maintain adhesion and/or keep time.
I did the Clun Castle tour in May 2024 because of the specifically advertised unassisted steam sections viz Bristol - Plymouth on the Friday and Plymouth - Bristol - Paddington on the Saturday.
But claims (including from the organisers) that Clun wasn't being assisted on the opening Birmingham - Bristol section were not just disingenuous but downright fanciful, especially given the running between Swindon and Bristol Parkway. Castle + 9 + 47 diesel topping Fosse Road in the mid 60s mph (mid 50s mph would be excellent for a Castle on 12!) was one thing, but sustaining 75+ mph on the 1:300 up to Badminton was quite another!
The arguments for and against a diesel on the back were brough into sharp focus on the South Devon banks. On the outward run, a 30 mph platform slack at Newton Abbot meant Dainton wasn't approached as quickly as it might and there wasn't the roar I've heard from other engines, speed falling to a minimum to 9 mph. The climb of Tigley / Rattery was a bit better.
But on the Saturday, despite a good speed at Plympton, the Castle stalled on Hemerdon, in ideal rail conditions. Again, other locos have been worked audibly harder. So the support 47 diesel running a block behind coupled up to give a shove. But in this instance, the suggestion the diesel gave no further assistance once we got up Hemerdon was more plausible and the Castle audibly worked very hard to regain the time lost waiting for the 47 to couple up.
Some railtour operatours (e.g. Vintage Trains) are more transparent than others (don't push me!) re whether a diesel will be attached. Also some loco support groups (Tornado and Clan Line spring to mind) don't like/want diesel assistance unless absolutely necessary, and so you have more chance of a proper steam run.
As a result of the shoveage I'm spending more time - and money - visiting our heritage railways, maybe not such a bad thing. I'd rather have unassisted steam at 25 mph on a heritage railway than 75mph shoved steam on the main line, and there's a vast range of locos to travel behind on heritage railways that will never be sampled on the main line.
