Diesel Hydraulic Locomotives
Tetragon213
14 Oct 2024
West Midlands
158s have the same arrangement, and we know how many complaints they've generated over the years...
All production Sprinters were hydraulic. I'm not counting the 210 & not entirely certain what the 151 had.
I believe some of the complaints wrt the AC on the Class 158/159 fleets is less to do with the transmission arrangement, and more to do with how poorly the system has handled the transition from CFCs to less Ozone-destroying refrigerants.
It wasn't just electric transmission, it was GM devising through research their adhesion control "creep control" mode. Their previous electric transmission locos couldn't do this. Similar research on hydraulic transmission control would doubtless produce similar results.
Creep control relies on very accurate control of the wheel's rotation speed to be a tiny bit faster than its speed over the rail. This is probably easier to do with electricity which can be switched much more quickly and accurately than hydraulics.
Various reasons have been cited as to why it doesn't work very well, and no doubt with enough time and money a system could be engineered that delivers reliable air conditioning based on what is essentially a mechanical rather than an electrical power source. But it would be a very bespoke application, and it's not too surprising more recent train aircon has been electric. It can take advantage of technology developed for the much larger automotive market, it can be fitted anywhere, and it can take its power over a jumper cable.
30907
I see the same old gen has been trotted out, none of which answers the following points :
  • If WR was "anti electric" pro hydraulic transmission, why did they not have any DH shunters (D9500s are not shunters) ?
True, but they appear to have been conceived as 57xx replacements, whose duties certainly included shunting.
  • WR had no hydraulic transmission DMU - yet both LMR and ER did - so why did not the WR if all the pro-hydraulic reasons are valid ?
I would suggest that the WR was familiar with DM units as the GWR operated the only fleet of them pre 1954.
Now look at LMR.
51591-51650....60....120
51681-51780....100....100
Half of the Power Twins were DM, so your total is 170 cars (plus 40 for the Lea Valley sets on the ER if you like).
Details apart, your summary covers:
1. 200hp+ shunters - DH and DM transmissions used widely across BR, and they came from existing industrial sources. No obvious reason why WR had none and I'm not sure it is significant.
2. 350hp+ shunters - the only DH one was D0227 which BR never accepted, all the rest were DE.
3. DMMUs and DHMUs - the latter being a very small proportion of the total. DEMUs were confined to SR as is well known.
As you have said, WR was familiar with mechanical transmission from GW days (but not with hydraulic, which I think explains why in categories 1 and 3 they stuck with it.
Going for hydraulic over mechanical is very different from hydraulic over electric (mechanical wasn't a serious option anyway for main line running).
Taunton
1 Aug 2013
I would suggest that the WR was familiar with DM units as the GWR operated the only fleet of them pre 1954 ... As you have said, WR was familiar with mechanical transmission from GW days (but not with hydraulic, which I think explains why in categories 1 and 3 they stuck with it.
The GWR streamlined cars had the same transmission as the AEC company had devised for the classic London RT bus, which probably many senior members here were familiar with in their youth. The Preselector gearbox had a small lever to choose the gear in advance, and then a foot pedal which operated the compressed air-assisted actual gearchanging, including on the remote car in the twinsets. There is a fluid flywheel in the transmission, which allows the gear to be engaged while the car is still at rest, and eliminates a clutch, until you open the throttle, so really a combination of mechanical and hydraulic transmission. Later GWR cars also had the AEC overdrive selector used on long distance buses.
The later Blue Square units followed along with a similar, though slightly different, approach.
norbitonflyer
24 Mar 2020
SW London
Actually originally developed for the earlier Q-type. This had the engine and gearbox remote from the driver, to allow a front entrance - it was under the stairs in the double deck version. This required a remote gearchange - exactly the same issue as a railcar, where the gearbox has to be remote from at least one of the cabs.
  • And LMR and ScR both had DH shunters as well as DE - so ditto why not WR ?
I think the answer is that the WR was not so much pro-hydraulic as unfamiliar with electrical engineering.
The small shunters and DMUs are a red herring - electric transmission was not feasible anyway for the smaller appliactions, and the (G)WR had a lot of experience with mechanical transmissions, particularly in DMUs.
Scotland had DH shunters because most of them were built by a Scottish company.
Taunton
1 Aug 2013
It was just a few years between the first WR main line hydraulic (D600) and the start of their very large fleets of Class 37 and 47. The opening day photographs of Landore diesel depot have their three main types, Class 37, 47 and 52, nicely lined up in echelon. Electrics in the majority.
Then of course there was Gas-Turbine 18000, ordered by the GWR long before any other types. Electric transmission.
The only diesel depot that came late to main line diesel electrics was Laira, and this was principally not transmission but due to their skills with high speed large diesels. Very many Laira staff at all levels are ex-Royal Navy from across the city, where they had encountered high speed big diesels earlier in their careers. This carried on right through to the HSTs.
Harpo
21 Aug 2024
Newport
To the best of my knowledge, creep control was only possible with electric transmission. I guess though we’ll never know what the upper haulage limit of a single hydraulic loco could have been.
Harlequinuk
15 May 2025
The GM class 59s were the point where electric transmission on locos used in the UK made an incredible step change, enabling one loco to move 5000 tons+ unassisted. Would hydraulic transmission have been capable of matching it by that point?
52s used to work the stone trains ; whislt they could match a 47 on teh flat, it was the continuous effort at a lower speed which was far better. TBH, they should have kept them for heavy freight and not waste the money on the 56s
Taunton
1 Aug 2013
the points are why did WR not have any DH DMU when all the reasons they went for DH locos still apply
Possibly because they weren't available ... the WR went for dmus quite early, their large Birmingham and South Wales suburban schemes being among the first, whereas the hydraulic drive cars, with Rolls-Royce engines and transmissions, came later, because only then had Rolls-Royce put them on the market, coming from the onetime Sentinel plant at Shrewsbury which they had ownership of then. You can't buy what isn't being sold.
30907
A very good point.
And even once you had the option, why have a mixed fleet?
Acathater
11 Dec 2025
NorthWest
presumably on a hydraulic transmission to get any form of creep control you'd need to fit limited-slip differentials on the axles - which there probably wasn't room for. Besides which you'd introduce a whole new gamut of wheel/rail interface problems with the wheels rotating at different speeds. You'd need completely new wheel cone profiles for a start
As far as I'm aware all locos with creep control have conventional wheelsets, not independent wheels. But I'm not convinced that sort of accurate speed control and rapid response to changing conditions is possible with hydraulics in the control loop.
Magdalia
1 Jan 2022
The Fens
The ER's suburban DMUs, with Rolls Royce engines and hydraulic transmission, were a bespoke order to meet a specific requirement, not a part of their general traction policy. That was for EMU standard performance on peak hour Liverpool Street-Bishops Stortford via Lea Valley trains as part of the Chenford electrification scheme, completed in 1960. The Lea Valley between Clapton Junction and Cheshunt wasn't electrified in 1960 because it had heavy coal traffic. A 6 car train with Rolls Royce engines had 8*238hp engines, giving a total 1904hp, they were the ER's DMU equivalent of the Deltics.
When the Lea Valley electrification was completed in 1969 they transferred to the GN, but, although notionally allocated to Finsbury Park, almost all of the maintenance continued to be done at Stratford.
Taunton
1 Aug 2013
Surely the Heavy Coal Traffic there had all come down through Bishops Stortford and Cheshunt, which was electrified ...
norbitonflyer
24 Mar 2020
SW London
; the points are why did WR not have any DH DMU when all the reasons they went for DH locos still apply,
The reason the WR went for DH locos was a lack of experience with electric traction. This weas irrelevant for DMU procurement since there was no prospect of electric traction for DMUs (except of course for the Southern, who DID have a lot of experince with electric traction), and the Western had plenty of experience with mecahnical transmissions for DMUs.
DHMUs were a relatively late addition to the fleet, and were generally used where more power was required than the standard BUT/AEC engines could provide, or a mechanical transmission cope with - notably the Lea Valley, (to keep up with EMUs), and the not-entirely-succesful idea of having one big engine per power car instead of two small ones (Class 113)
Shunters are, i think, a red herring - most types were bought more-or-less off-the-peg from the various manufacturers' catalogues. Of the sixteen sub-350hp types delivered, two were diesel electric and four were diesel hydraulic. Only one of each, classes 07 and 02 respectively, survived long enough to get TOPS classes
Acathater
11 Dec 2025
NorthWest
My point was that if you were going to have any kind of creep control (which is effectively a wheelslip elimination system) on a hydraulic drive then you would need independent wheels
In every mention of "independent wheels" I've heard (in 38 years in the rail industry) it has referred to wheels on opposite rails not linked by an axle. Are you actually referring to axles that aren't mechanically geared together?
It's certainly possible to have wheelslide protection on trains with axles mechanically linked, class 158 being one example where the axles on the powered bogie are linked by gearing and WSP effectively thinks it has three axles rather than four.
Acathater
11 Dec 2025
NorthWest
I was thinking of something on the lines of a limited slip differential so the driving axles consist of a pair of linked half shafts
I don't understand why that's necessary at all, as no creep control locomotive has it, and why having a hydraulic drive with creep control would make it necessary.
E27007
25 May 2018
Is there a lesson in examining the evolution of Br type 4 diesel locos from the EE4 and eventual mass adoption of the Sulzer Type 4?
1) EE4 class 40, heavy, too many axles, only 2000 bhp and under-powered.
2) the Peaks 2300/2500 bhp too many axles , a step-forward over class 40 power but not ideal.
3) the Westerns 2750 bhp, 6 axles but 2 diesel engines to buy and maintain a detriment
4 the 47, 6 axles, 2750 bhp from a single diesel engine.
5) DP2 / Class 50 6 axles 2700bhp from a single diesel engine.
Class 47 emerges as the choice ,six axles, a single diesel engine of the desired bhp, the Western not the choice over the costs of using two diesel engines to do the work of one.
DP2 / class 50 a contendor for first choice, but it was written BR CME had faith in the Sulzer diesel engine, but not the EE diesel engine
Prime586
26 May 2023
Knowsley
The pre-selector gearbox used on the Q and RT buses was a product of Wilson/Self Changing Gears Ltd, not AEC (Leyland became SCG's majority shareholder in 1957, and took over AEC in 1962).
The Wilson/SCG pre-selector gearbox uses epicyclic gearsets that are selected by clutch bands - the pre-selector lever selects the next gearset and pressing the pedal causes the gearbox to release the clutch band on the current gear and activate the clutch band on the selected gear. It is the same mechanism and principle of operation as using a hydromechanical automatic car transmission in 'semi-automatic' mode, though they operates the clutch bands automatically like later SCG 'Pneumocyclic' transmissions did, doing away with the third pedal.
The Mekydro transmission is also hydromechanical, with a single torque converter/fluid flywheel and automatically-selected conventional gears (engaged via claw clutches attached to the selector forks).
The Voith 3 stage transmission used by the Class 52 locomotives is a true hydraulic transmission, with 3 separate torque converter stages to provide the 'gears', which are selected by valves that control the flow of the fluid to each turbine stage.
Nicholas Lewis
9 Aug 2019
18100 was ordered from Met Vick by the GWR as well before WW2 but delayed due to the war
I do understand it was a question of economics ; UK was in a poor financial place, the diesel hydraulics were on 1 region vs all the others on diesel electrics. NBL had gone bust which meant everything had to go back to Germany (MAN Engines and Voith transmissions), Rolls-Royce had no interest in German diesels, so support for the Maybachs would have been German as well. Parts were also non standard vs German spec, so all would have been special order. 1 solution would have been to use Paxmans, but pre valenta they didnt have a good reputation. Biggest advantage was traction effort , especially the 52; the 56 that replaced it on stone trains (out of Westbury) just wasnt anything like as good
Paxman provided plenty of high speed diesels for minesweepers and submarines during WW2 and after that had sufficient power rating to match Maybacks but either drove props through gearboxes or via generators in the case of submarines.
matchmaker
8 Mar 2009
Central Scotland
A lesson might be not to let the prejudices of the CME affect the choice of engine. In retrospect the Sulzer 12LDA28C was not as reliable as the EE 16CSVT!
Fleetwood Boy
11 Oct 2017
Indeed. The final step in the evolution of the locomotive classes mentioned was the Class 56. I still think DP2 is the design that got away, spoiled by too many bells and whistles in Class 50.
E27007
25 May 2018
It is important to note, the WR hydraulics were not pure hydraulics, they were hydraulic-mechanical, pure hydraulics use hydro-static drives, hydro-static drive is a hydraulic pumped circuit driven by say a diesel engine, the pump pressurises hydraulic oil in the circuit which is fed to hydraulic traction motors creating propulsion, for hydrostatic drives, the pump is run flat out,by a diesel engine running at full rpm, control by swash plates to vary power to the hydraulic traction motors.
Western hydraulics employed a mechanical transmission with multiple gears over the speed range, recall the Hymeks on Lickey banking duties, at banking speeds, they would hunt between first and second gears back to first a risk to the transmissions, first gear was locked out to stop the hunting.
The Warships were known as camels, the mechanical gear changes very violent and alarming to the drivers, the roughness felt by the passengers.
Tetragon213
14 Oct 2024
West Midlands
Wasn't the Class 56 notoriously unreliable due to Ceausescu's Romania mucking the whole job up?
norbitonflyer
24 Mar 2020
SW London
The Class 47 was a development of the Peaks, and the Class 50 of the Class 40 - uprated engine, redesigned body, dispensed with the carrying axles. Indeed, the first twenty Class 47s were originally going to be Class 46s.
And the Class 40 was an uprated version of the Ivatt twins and Bulleid trio (the latter of which ahd the same bogies, and in one case the same uprated engine)
Both EE and Sulzer engines also found their way, in smaller versions with fewer cylinders but otherwise similar, into EE classes 20 (8 cylinder) 31, 37 and 58 (12 cylinder) and Sulzer classes 24-27 (6-cylinder) and 33 (8-cylinder). This is most obvious when listening to a Class 20 and a Class 40!
Clarence Yard
18 Dec 2014
A couple of years ago I was at the funeral of the former KX Divisional C&W Engineer (Pat Sumner) and David Russell, the DME who appointed him, was there. David was very frail - he died in April last year but as the ER CM&EE, he had to sort out the Romanian 56’s. He told me a a few things about them.
The build quality was uniquely bad. Stratford DRS had to give them to once over and, to give you just two examples, they found that the electrical conduit was actually gas pipe with solid connections and elbows and the axle box lubrication was actually swarf! Some internal equipment had “left hand” and “right hand” connectional variants.
Apparently there was a Brush rep on site in Romania but on some days/weeks the factory was empty. That was because the workers had been told to report to a shipyard to work on a ship or go on the land to collect in the harvest!
Class 50 locomotives. Those KV units were a very weak spot. Usually lack of volts should mean lack of power but the KV10 unit could work in reverse and if a locomotive “locked on” to full power, it was a fearsome sight and you had to quickly shut the locomotive down before it raced away to destruction.
DP2 was a well liked loco on ER both from the driving and maintenance point of view. Finsbury Park would have liked a fleet of them to look after.
