Didcot to Plymouth offpeak returns
orpine
24 Aug 2013
Hi,
Does anyone have any suggestions for splitting a ticket, Didcot to Plymouth, with an offpeak return (£82).
Using this route (all these are stopping stations):
Swindon (Wilts) [SWI]
Chippenham [CPM]
Bath Spa [BTH]
Bristol Temple Meads [BRI]
Taunton [TAU]
Tiverton Parkway [TVP]
Exeter St David's [EXD]
Newton Abbot [NTA]
Totnes [TOT]
I've got:
did-bth: £24.30
bth-ply: £56
Saving: £1.70 :-/
did-bri - £34.3
bri-exd - £27.9
exd-ply: £18
Saving: £1.80 :-/
did-bath: £24.30
bth-tvp: £29.20
tvp-ply: 19.5
Saving: £9!!! :) (For some reason bath-tvp is considerably cheaper than bristol to tvp, which is mostly where this saving comes from).
Anyone got any advance on the £9 saving? (might be able to save a £couple more on the tvp-ply segment as there are advances available).
Thanks
*bump* Anyone?
bnm
12 Oct 2009
Huh? Bath to Tiverton Parkway Off Peak Return is £29.20. Bristol TM to Tiverton Parkway Off Peak Return is £25.70.
bangor-toad
20 Feb 2009
I'll go the other way and suggest a ticket that's actually more expensive but may be far more interesting...
Didcot - Swindon. Super Off-Peak Return. £17.10
3 days in 7 Freedom of the South West Rover £79.00
Total of £96.10.
Obviously that's more than the bare minimum you could get the tickets for but it gives a lot of extra routing options and an extra day to travel anywhere in the region.
Maybe those would be worth the bit extra?
Cheers,
Mr Toad
orpine
24 Aug 2013
Exactly.
In contrast, Didcot to Bristol is £34.30. Didcot to Bath is £24.30. A £10 reduction for that leg, but the leg you highlighted is only a £4 increase, thus this gives a £6 saving overall. I wasn't as clear as I could have been, sorry about that.
I don't seem to be able to make it cheaper than that but maybe others have some ideas.
D6975
26 Nov 2009
Bristol
Tiverton-Plymouth can be done on a Devon day Ranger for £10 after 09.30. If you're coming back the same day that makes a saving. Even if you're travelling on 2 days, it's only 50p more than a return and gives you that extra flexibility. Also, there's an evening version for £5, so you could save that way too if one direction is in the evening.
orpine
24 Aug 2013
Thanks for the suggestions. I always forget about the rovers.
Just a quick FYI, but it seems to be £80.90, I guess it went up since last you looked. - http://www.nationalrail.co.uk/times_fares/pr0f61f9c35ce741009c0e3842403e09.aspx - alas while the idea is tempting, this is just for a short weekend with minimal travelling at the destination.
As I'm travelling in the evening, the Devon Evening Ranger is pretty much exactly what I want probably. So that puts the saving in the £18.50 range. Now if only I could get to Tiverton Parkway cheaply... :)
