Derby and Cardiff mainline depots
SlimJim1694
8 Jan 2020
Medway
Just wondering if anyone could shed some light on the mainline depots at Cardiff (TFW) and Derby (EMR) from the perspective of qualified drivers joining these companies please. From what I can work out you have to serve your time doing local work first (which I have no problem with), but unlike the usual progressive link systems the mainline work appears to be completely separate with no automatic progression, rather than just 'top link', as it were.
Have I got this right? And if so, how do you get into the mainline links at these places? Do you have to apply separately once you are already in the company like SE HS1? I wouldnt fancy Cardiff Valleys with all this talk of train-trams. Presumably there is a long wait for the mainline as I've never seen it advertised externally there, which I guess would rule it out for any newbie who doesn't want to be a tram driver in the future.
I wouldn't expect to, or want to jump any queues, and it wouldn't bother me doing local work at Derby indefinitely, I'm just trying to find out how the land lies at these places.
I'm 95% certain of a job somewhere else (awaiting final confirmation) but still keeping my options open in light of the current Covid situation.
tiptoptaff
15 Feb 2013
Cardiff works on progression, you have to join the Valleys and you 'apply' to go mainline and then go when it's your turn. Personally, I'd hold off until they're split and the metro is in place. See what happens to the depots after that. The tram-train things will be based at Taffs Well, so I'm guessing there will be some form of split on Valleys, and what remains will be 'proper' drivers ad-infinium.
Mainline, link dependant, do Cardiff-Crewe, Chester, Milford Haven, Cheltenham, Ebbw Vale, Maesteg and Canton depot. Also Crewe-Chester and the VoG line. Core routes are Swansea, VoG and Cheltenham, lower links do Maesteg and Ebbw Vale, and the upper links do Milford Haven and Crewe/Chester. Middle links pick up bits and pieces to build full card. Top links drop the 'local' stuff ie Maesteg and Ebbw Vale
Traction is 142/143, 150, 153, 158, 170 and 175. Small number of link 1 drivers also do 67+DVT
craigybagel
25 Oct 2012
Cardiff is effectively two separate depots, based in the same building, which is why it isn't just the normal link system in place. Although having said that even if you're already a driver elsewhere with TfW and you transfer to Cardiff you have to go on the Valleys first (not that that's an especially common move). I would be very surprised if anybody starting on the Valleys from now on was able to escape to mainline before the tram trains arrive. That said, it might well be an improvement - if you're going to spend all day bouncing up and down the Valleys stopping everywhere at least it'll be on new modern stock rather then Pacers.
Also worth pointing out, as Tiptoptaff alluded to when you do finally make it on to the Mainline depot the work isn't a whole lot better - in the bottom link there are lots of VOGs Ebbws and Maestegs which is still all stop Class 2 stuff really.
Also, a minor correction to Tiptoptaffs otherwise excellent post; Cardiff drivers don't sign Crewe - Chester, only the guards.
tiptoptaff
15 Feb 2013
Thanks Craigy! It's been 4 years, near enough, since leaving! Knowledge fade is a real thing it seems!
From memory, the link 'C' stuff was almost as bad as the Valleys diagrams. Double Maesteg double Ebbw wasn't uncommon!
craigybagel
25 Oct 2012
No problem - I only really know myself from having to sort out pilots when I was a guard working with Cardiff drivers and we occasionally got diverted that way :lol:
And yes, judging by the moaning in certain messrooms link C isn't a whole lot better these days.....
godfreycomplex
23 Jun 2016
Derby wise it’ll be mainline from day 1 as a qualified driver I believe, up and down to London and Sheffield. Some local work to Matlock/Crewe etc but only in certain links, most work at Derby is mainline I believe.
tiptoptaff
15 Feb 2013
Derby also has XC, and I believe they do Cardiff, Bristol, Nottingham and as far up as York, maybe Newcastle.
Traction would be 170, Voyager and HST. No idea what the links would be like or how the work would split up
43066
24 Nov 2019
Just be aware that there are some extreme (even by railway standards) early starts and late finishes at Derby.
Economist
24 Feb 2013
WMT are recruiting for qualified drivers at Shrewsbury, I don't think the work is that great according to the route and traction thread but it is another depot in the Midlands where overall T&Cs are fairly good (or so I hear). Chiltern seem to be doing a fair bit of driver recruitment recently, as do XC.
Alternatively, there's SWR/GWR in the south west and TPE in the north, all seem to have decent T&Cs.
2L70
18 Feb 2019
Barnetby
Derby EMR, well it’s an intercity depot so you would start off with Leeds - Sheffield - Derby - Pancras as your core route, then depending what link you go into add Lincoln or York.
The local link add Matlock and Crewe.
SlimJim1694
8 Jan 2020
Medway
Thanks for all the responses. I think based on the above I would rule out Cardiff but Derby EMR (or XC) both look good to me.
Thanks Economist, I've been busy over the last few months and have been offered a job with a decent TOC but it's currently on hold due to Covid (eg: no start date). I'm not taking anything for granted so still keeping my options open until it's in the bag. I appreciate all the input people put into this forum, its certainly opened my eyes to the bigger picture nationally. There are some good people on here.
lammergeier
5 Oct 2017
Derby don't sign 170. They sign HST and Voyager, Newcastle to Bristol via various routes. All drivers sign all routes/traction.
Evolution
29 Jun 2016
Manchester
Moving slightly further north (if possible) would give you the options of TPE and LNER, both of which are good TOC’s with good pay and work.
