Harry26
- Joined
- 9 Oct 2018
- Messages
- 10
It was a double header which suggests heavily used. I suspect a Commuter Leeds bound service, maybe the Regular 18 minutes or 45 minutes past the hour
Oh, just an afterthought, I’ve watched Sheffield station for a long time but never seen Northern 142 030 or 142 039 - anyone any idea where they operate ??
I might have guessed it was a Pacer (thought it may also have been a freight train) - I remember looking at Wikipedia and reading a few incidents involving Pacers - largely 142's I think.
The reason why I also perhaps thought a Freight train is that even though derailments are extremely rare in the UK, it's nearly always a Freight train that's reported to derail.
If commuters who use Pacers every day get wind of this then that's gonna mean a lot of words said to Northern.
Luckily Northern will probably have a spare DMU or Pacer to run in place!
Let's clear that one up before anyone gets the wrong idea. It was NOT a unit fault.If commuters who use Pacers every day get wind of this then that's gonna mean a lot of words said to Northern.
There's nothing that's suggested the type of rolling stock is to blame for this incident.I might have guessed it was a Pacer (thought it may also have been a freight train) - I remember looking at Wikipedia and reading a few incidents involving Pacers - largely 142's I think.
There isn't technically a "Cat 'A' SPAD" anymore, as a SPAD is by definition only Cat A nowadays.
Anything that used to be the other categories is now a SPAR ("Signal Passed At Red") because apparently passing a signal is only dangerous if the driver does it. (Cynical, moi?)
Before the recategorisation into SPAD and SPAR, the summary was Cat A = drivers fault; Cat B = signallers fault or technical problem with the signalling; Cat C = signaller making a safety intervention and Cat D was a runaway vehicle/train.
Nowadays Cat B is a "Technical SPAR", Cat C "Signaller SPAR" and Cat D "Runaway SPAR".
I personally believe that the reclassification from SPADs to SPARs is to make the others appear less serious than the "driver-at-fault-until-proven-otherwise" Cat A, and having at one time suffered a signaller-error Cat B approximately every 2 weeks for a six-month period I find that unreasonable.
Cat A means the signal may have been passed when no route was ever set, so the train could come into conflict with another train. For the other (SPAR) categories the train is still protected by the interlocking (approach locking keeps the route locked even if the signal drops back to red) except in the very unusual case of a wrong-side interlocking failure. Therefore a Cat A potentially has much more serious consequences.There isn't technically a "Cat 'A' SPAD" anymore, as a SPAD is by definition only Cat A nowadays.
I would like to think that the barriers, would still be locked by the signal interlocking, for at least 2 mins after the signal was put back to danger. Though not 'always' the case.Everyone I know still refers to categories and calls all of them SPADs regardless of what some office-dwelling word-player has decided they should be called.
At the end of the day call it what you like, the signal was displaying a red danger aspect, and it is therefore a signal passed at danger. Playing with terminology won't change that.
You appear to be falling into the industry's usual trap of assuming the only risk after passing a signal at danger is the railway. It isn't.
I once had a Cat B onto a main (A) road level crossing because the signaller had put the wrong lever back. I was later told that the signaller had admitted that he'd been about to raise the barriers as well. Not as risky as any Cat A would have been, though, eh?
From colleagues at Sheffield I have the following, which they say is already in the public domain (so can be repeated here).
- Northern unit has derailed on catch points at Fish Dock.
- Unable to use 1, 2 & 5 Platforms from the South.
- The derailed train has cut signalling cable, with the result that:
- S79 & S80 signals black; and
- S85 & S84 need to be passed at danger departing south.
- 5P09 is apparently not the culprit.
Beat me to it!Trap points not catch points.
The reason I thought it was a unit fault was it was said on page 1 of this thread that one of the axles fell off or something.
Sorry that was my terminology.The reason I thought it was a unit fault was it was said on page 1 of this thread that one of the axles fell off or something.
Also, even if it meant causing overcrowding, I'd have thought Northern would take a DMU off another service to run in the Pacers place until it's fixed.
CrossCountry will sometimes run a single Voyager set instead of a double if a Voyager is desperately needed.
They kinda don't really exist or at least shouldn't.
Surely, no SPAD should ever "exist", i.e. actually happen?? I thought that ATP was supposed to prevent them, and that after Southall/Ladbroke Grove, all locos and multiple units had to have ATP fitted and in working order, otherwise they couldn't be used?
I know there are circumstances under which trains have to be talked through signals set at danger, and also that there are occasions when signals turn red when the train is virtually on top of them and there is no way for the driver to stop in time but in general, I thought SPADs were a thing of the past. As a lay person, it's quite shocking to hear that they arent! Does anyone have any figures they could share on how often they're still happening, and/or how many per year across the network?
