Derailment between Thorpe le Soken and Clacton (16/07/22)
Peter Mugridge
8 Apr 2010
Epsom
The 10.18 from Liverpool Street to Clacton has hit four cows and derailed one axle roughly three miles short of Clacton.
Nobody on board is hurt, but obviously the Clacton line will be out of action for the rest of the day.
It's 720 528 leading 720 573, before anyone asks.
I'm in the front carriage...
Cowley
15 Apr 2016
Devon
That must have been quite an unpleasant experience Peter.
LAX54
15 Jan 2008
No service TLS to Clacton
Normal Walton - Colchester, and trains to / from Liverpool Street terminate at Thorpe le Soken.
Peter Mugridge
8 Apr 2010
Epsom
We're going to be evacuated into the rear unit and that will be uncoupled and return to Thorpe le Soken.
It's the second carriage of 720 528 which is derailed.
LAX54
15 Jan 2008
seems the farmer is going to assist with the wheelchair passengers etc, together with some of his farm hands.
Peter Mugridge
8 Apr 2010
Epsom
The evacuation is now nearly completed so 720 573 should shortly be taking everyone to Thorpe le Soken.
TT-ONR-NRN
30 Dec 2016
Cambridge
Oh dear, not good. Glad you and the rest of the train are alright though.
4 Sep 2015
Lehigh Valley PA USA
Wow I thought the lines there were fenced, maybe they broke through the fencing?
Sounds like something I'd expect to hear here in the US where many of our lines are unfenced.
Whistler40145
30 Apr 2010
Lancashire
Hope you're okay Peter
LAX54
15 Jan 2008
Fences get brokem on a fairly regular basis, either by the animals themsleves pushing on it, then suddenly may break after repeated nudges, or ramblers / tresspass incidents may break a fence, and its not always spotted until its too late, normally it just involves a caution for animals on / near the line, but to hit and derail is rare, or was rare, new units are a lot lighter !
Peter Mugridge
8 Apr 2010
Epsom
Now back at Thorpe le Soken.
This is the scale of the attendance for the incident.
Mcr Warrior
8 Jan 2009
Fences get brokem on a fairly regular basis, either by the animals themsleves pushing on it, then suddenly may break after repeated nudges, or ramblers / tresspass incidents may break a fence, and its not always spotted until its too late...
Wooden fenceposts often rot at the base and/or will also have been buffeted/rocked to and fro by the wind. After a cursory inspection, they might look fine/intact/still sturdy, but in actual fact, would quite probably fall over following the very slightest of nudges by any livestock.
Peter Mugridge
8 Apr 2010
Epsom
Horizon22
Jobs & Careers
8 Sep 2019
Must have been terrifying for driver to come up aginst that. Glad all is well Peter; all in all it seems like quite a successfully swift evacuation and resolution to the incident too.
Peter Mugridge
8 Apr 2010
Epsom
Correct on all counts; although to the layman three hours might not seem very fast it's not too bad in the circumstances - particularly given that nothing could be done beyond an immediate initial inspection of the train as there were still cows running loose afterwards; they would have had to be rounded up before anything serious could get done.
As for the rest of it, it was obvious as soon as I felt the impact and juddering and saw the ballast flying that we weren't going anywhere in a hurry. It was immediately clear that we had struck something on the track although at that point we had no idea what. I did initially suspect we were off the road from the juddering, but I wasn't completely sure because after that it was rather smooth while the stop was completed ( we're talking seconds here ). Turns out it was one axle in the second carriage that was derailed; I was in the first carriage.
Immediately we stopped I said to my wife and those around us that we would likely be there for at least an hour. A while later the crew came through and when they said we were derailed, the first thing I said to my wife was that it would be at least two hours before anything happened. Not too far off the mark as it happens as the evacuation plan was pretty much known at the two hour mark. The rest of the delay was the time it took to transfer everyone across and then double check that the rear unit was good to proceed plus getting the necessary confirmations from the signallers etc to commence the move wrong line.
One unexpected side bonus - I was able to get my first two class 720 cabbings during the evacuation transfer.
Question: Is this the first time a 720 has been derailed?
MCR247
7 Nov 2008
If so, now both 710s and 720s have fairly early into their working lives
LIMA66
8 May 2021
Sunshine Coast
My colleague was pretty shook up after the incident. The location was a bit of a logistical nightmare for the evacuation but in the circumstances good job all round. After dropping Peter and the other passengers off at Thorpe I took 573 back to Ilford EMUD. 528 was rerailed and now at Clacton.
route101
16 May 2010
I nearly boarded this service. I was on the 1107 from Colchester Town to Walton. I seen your train depart Thorpe and we had to wait for signal clearance. Did see Police walking down the line and the train as I returned from Walton.
Peter Mugridge
8 Apr 2010
Epsom
Lima - I'm trying not identify you openly here with too much detail but just so I can place you; are you the one in glasses who spoke to us a few times? The one I correctly said "We'll be here at least two hours, then?" to once you confirmed we were off the road? ( It was of course pretty much exactly two hours after that when the evacuation started ).
Absolutey agree it wasn't the most convenient location for this sort of thing to happen, but at least it was generally flat land so the distance from the access was the only awkward factor, and not having to contend with a big embankment or cutting as well.
We now have a BBC report, although the number of passengers I think was closer to 150 than 100? That's based on a quick count I did while we were walking through ready for the evacuation.
A train was derailed after hitting cows which got onto a railway line in Essex.
Greater Anglia said the 10:18 BST Liverpool Street to Clacton service was derailed after it hit the animals on the line near Thorpe-le-Soken at about 12:00 on Saturday.
No passengers were hurt but four cows were killed.
More animals had to be moved from the line and, as a result, there were no services between Thorpe-Le-Soken and Clacton-on-Sea until after 23:00.
LAX54
15 Jan 2008
Seems, it has been said, there was a metal detectorist meet, some of them it seems, left a couple of gates open, and they also spooked the cows, that ran for 2 miles or more, then through a barbed wire fence.
Peter Mugridge
8 Apr 2010
Epsom
I saw that rumour ( on the Essex LIve link someone posted somewhere I think ) but that also quoted the detectorists causing the cows to escape at 08.30; could they really have been running loose on and about the line for over 3 hours without anyone noticing them until the train hit them?
XAM2175
8 Jun 2016
Alfie1014
27 Jun 2012
Essex
That was my thought too, I noticed however when the same picture was used on the local TV news yesterday that bit was pixelated out.
LAX54
15 Jan 2008
They ran amok for over 2 miles, and then eventually went through a fence, if they gained access after the Up Clacton went past, there is a fair amount of time before the next down Clacton leaves TLS.
