Derailment at Dingwall
Tomnick
10 Jun 2005
Surely a lamp that is lit to indicate that it is not safe to proceed would be more meaningful. (a red, perhaps?)
...but not failsafe (especially important when such systems were potentially - in the beginning - designed to operate where no mains power supply was provided). As illustrated on the 'Railsigns' website though, the latest design of points indicator does include a flashing red light to replace the current black 'indication'.
27 Jan 2008
Did I read correctly that the speed limit over the points (and up to the next set) was 15mph and the driver was doing nearly 30mph?
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
You did read that correctly.
However, it was also suggested that he had not completed the necessary braking before the entrance to loop because the (normally lit) yellow which confirms that the points were set correctly (and which in darkess, indicates clearly where the points over which reduced speed applies actually begin, and would be visible from some distance away), was unlit.
That was the concern underlying my post this morning.
An unlit lamp in darkess doesn't convey as much information as a lit lamp. Not only does it not appear, but its position becomes barely visible, and the RAIB inspectors felt that this unlit lamp may have led to the driver having only partially reduced the train's speed, in anticipation of an indicator which was not visible from afar in times of darkness.
(before anyone snaps back a reply about route knowledge, please bear in mind that these services travel over very great distances with very little visible terrain during darkness.)
scotsman
6 Jul 2010
With respect, this section of the route has plenty of visible terrain. You've got the A9 overpass at Maryburgh, a whistle board for a UWC, a UWC, then a "distant on" board, then around 300m you enter a cutting with trees, then you're into the town of Dingwall. The driver would have known where he was.
37 418
27 Jan 2010
Dingwall, Scotland
Make that the A835 overpass, the A9 doesn't go anywhere near Dingwall ;)
