Derailed Loco at Wymondham
Trainfan344
13 Oct 2012
TheEdge
29 Nov 2012
Norwich
Looks like two recovery units are on the way (assuming that's what a BRUFF is...), doesn't look like anything will run till the end of service today. As for tomorrow, who knows at this point...
lordbusiness
17 Dec 2014
We don't have much luck with RHTT over here. Last year a level crossing demolished, this year.....
SpacePhoenix
18 Mar 2014
Would the points be controlled from the signalbox seen in the background of the 1st photo?
Taunton
1 Aug 2013
What ever happened to single line working past an incident which is not, as in this case, blocking all lines.
Trainfan344
13 Oct 2012
I'm presuming lack of crossovers, from what I can remember, the only crossover in the area is a trailing crossover near the signal box.
TheEdge
29 Nov 2012
Norwich
No. That box, along with all the Breckland ones is was closed a few years ago and mothballed, although none have been demolished yet. All controlled from Cambridge PSB.
Like Trainfan344 says, its the crossovers. I think the next available one between the derailment and Norwich is Trowse junction, which is all of a minute from Norwich station.
carriageline
11 Jan 2012
Even if there was crossovers, getting the staff these days is a massive struggle. It would seem it's just easier to stick busses on.
My area has plenty of crossovers, but SLW would be unworkable as I bet they couldn't get the handsignallers and pilotman, never mind any barrier attendants.
jopsuk
13 May 2008
looking at the 2009 Baseline Declaration version of the Sectional Appendix, there doesn't appear to be a single facing crossover between Ely & Norwich. Between the derailed loco and Norwich there's a ground frame at the other end of Wymondham station. Really, to run single line working along here would mean operating as a single line from Trowse Junction to Ely North Junction, a distance of over 50 miles
GB
16 Nov 2008
Somewhere
My apologies, I was confused by the headcode.
There's one at Brandon isn't there?
In anycase, if it came to it I don't think there is anything to stop you using a trailing crossover.
Crossover
4 Jun 2009
You mean via a double shunt? (i.e. pass over the crossover wrong line, shunt back across the crossover to the correct line, change direction once more continuing in the original direction but on the correct road?)
Johnny_w
23 Jan 2011
Rural suffolk
Just out of interest why would the RHTT Set (Weather it's an actual RHTT or not ) be going to/from the MNR?
seems a strange move non?
dk1
2 Oct 2009
East Anglia
The next facing crossover would be Brandon. Trailing ones available at Eccles Road, Thetford & Brandon.
DRS have used Dereham for many years for maintainence.
Taunton
1 Aug 2013
I suppose it's one of those things but single line working was always traditionally put in (in about 10 minutes) using trailing crossovers, which took just a couple of minutes to push back over and then set forward wrong line. The Wrong Line Forms (another bit of history I presume) envisaged this was how it would be done.
dk1
2 Oct 2009
East Anglia
Back in the day we always has local signallers in the area who could be called in to help out with such unplanned events. We have plenty of SLW going on on the GEML at the moment thanks to the HOBC. No Bi-Di North of Colchester to help out.
455driver
10 May 2010
Back 'in the day' (yawn) drivers were allowed to set back from the leading cab, that isn't permitted any more except in exceptional circumstances, there also needs to be a pilotman in place now etc but then you know all that but would rather have a dig!
Murph
16 Feb 2010
Here's an official steam era training film for it:
[youtube]F79R3Fg-pPY[/youtube]
Edit: Note the lack of death and destruction despite the complete lack of orange. ;)
