Depot to Mainline only in the future?
Ludus
11 Mar 2020
Greater Anglia have recently changed their driver recruitment process so that all trainee drivers will start as a depot driver and then have apply for a mainline role internally. Do we think this could possibly be the case for all TOCs in the future?
Does anyone know the rational behind the decision (other than obviously gaining traction experience prior to mainline) and do you know if you move from depot to mainline whether you have to retake all the psychometrics? If so that does seem a little unfair.
Magrar
20 Jun 2026
Reading
It would certainly be an effective and cost efficient method of ensuring people not fit for mainline duties for whatever reason (but which only came to light once they were feeling comfortable in the job) aren't entitled to redundancy or a disciplinary process.
Believe it or not, there are people out there who will be on their best behaviour and do an upstanding job, right up to the day they hit full entitlements. Which under recent working rights changes, can now often be long before they are actually put in a position of real responsibility. Not that driving in a depot is nothing. But it's behind closed doors.
But I'd wager that's not the official reason given.
Error404
5 Mar 2022
Not Found
- Employee will be productive much quicker (several weeks vs several months)
- It is cheaper to give an employee a few weeks training course, then get employee doing part of a job.
- The employer can see what the employee is like before offering full promotion.
- The employee must prove worth in probation (and a lower wage) before going up a step.
- The incident rate is much higher for a post qualified driver of less than two years. A comparison based argument could be made that a 5mph incident with no public on board vs a 70mph incident with several hundread public on board.
- There will be a level of dedication required to be in the depot for a few years before. This is very common in Flight, (First officer upto Captain), Water (First mate upto Captain) and within Health (Junior Doctor upto Consultant)
tiptoptaff
15 Feb 2013
They always used to do this on the GE side, then moved away from it.
So looks like they're back to it
172007
2 Jan 2021
West Mids
Struggling to work this out. How many depot drivers do Anglia actually have? Would there be enough turnover of depot drivers a year to fill mainline drivers vacancies.
Ludus
11 Mar 2020
Well the depot drivers will fill the mainline vacancies internally so in theory there would still be the same amount of vacancies.
scotraildriver
15 Jun 2009
That would never work here at Scotrail. We're taking 160 new drivers a year for the foreseeable future. There aren't enough depot posts for that.
Tonboles365
2 Apr 2020
Peterborough
All relevant points. I think this is a good direction to move in, personally, as it puts you in a position of responsibility and gives you the opportunity to demonstrate your worth, commitment, and most if your ability to operate matches everything you said in your interviews.
My other view point of this, is that it gives the opportunity to gain relevant railway experience, become much more acquainted with the traction 'on the job' and understand other operational areas. Following that, if someone can demonstrate the safety first mindset, can be reliable, and can be a vital part of a cog to ensure that trains are checked, prepped, and leave the depot on time to contribute to the efficient running of a service, then I can certainly imagine a promotion to mainline driver will certainly feel more rewarding. Considering back in BR days there was no 'direct-to-driver' route, you had to earn your keep and progress through grades following a strict lines of promotion, it ensured a healthy well-rounded knowledge of all aspect of the job. But, we live in modern times, there is no cleaner or fireman role anymore, there is an aging driver force who are coming toward the end of their career - with many I know having taken early retirement - so perhaps depot the mainline is the best modern equivalent.
Ludus
11 Mar 2020
Didn't think about the ageing driver force - this could be a good alternative to holding pools if TOCs need a large number of drivers in the future. If you do all your training and start depot driving you can then switch mainline almost immediately following route learning, that way they can get people filling vacancies with minimal downtime.
martin2345uk
21 Sep 2011
Essex
Not quite the same as not trainees but we (E*) have all driver start off as depot/ferry drivers for anything from 6 months to a year before going on to learn French rules.
tiptoptaff
15 Feb 2013
GWR have started doing it in locations where they have depot drivers.
But as I said upthread, Great Eastern/One/NXEA/GA did it this way for years on the GE side of things.
Lmc1976
2 Aug 2017
GWR slightly different in that you don’t have to go depot first it’s a choice at application stage as they are advertised seperately.
Also GWR depot drivers are guaranteed the next available mainline vacancy at their depot after completing 2 years service, no need to apply to move on.
Ludus
11 Mar 2020
Do you they have to retake the assessment centre?
Sorcerer
20 May 2022
Although depot driving might not be the part of the job everyone looks forward to, it would actually be quite nice to have a more clearly defined path towards becoming a main line driver at least. Whether Great British Railways opts to make this standard practice or depot/region specific is anyone's guess.
PP57601
3 Jun 2019
Where do you get the ‘several weeks’ statement from?
A Depot Driver for GWR still has around 8months training before being fully qualified.
Lmc1976
2 Aug 2017
No. It’s a full drivers licence. You do a mainline conversion course which is essentially a rules refresh and then handling hours with route learning.
Your absolutely right it’s a full drivers licence and the course is exactly the same as mainline, you just get through it quicker at the end as your handling is condensed into depot work which is much quicker than mainline so you tend to pass out after about 8/9 months.
Tonboles365
2 Apr 2020
Peterborough
This is actually an interesting point, which I would also be curious to find out if they are doing the same at GA. Imagine being a depot driver for 5 years, your psychometric results now being out-of-date, and to become a mainline driver, you have to re-do it. I've completed mine, while it was an experience, it's not an experience I want to have to endure again.
Ludus
11 Mar 2020
Exactly, whilst I've also past psychometrics, I'd be fuming at the prospect of having to do them all over again.
If it's the case of simply gaining experience depot driving and then naturally progressing to mainline after x amount of time/experience and without having to go through the whole process again, then I could be onboard with the idea.
Firestarter
15 Sep 2009
Heavy Haul Rail Limited are advertising for qualified Depot Train Driver to Mainline Train Driver Accelerated training program out of Peterborough on Linkedin.
Teddyward
3 Oct 2017
Essex
Redoing psychometrics is not required as GA depot drivers are issued a UK train driving licence. Well at least on the GE and Anglia sides. I’m afraid I have no idea what the plans are for the West Anglia setup. It’s all new.
For great eastern side I expect the average progression time will remain about 3-5 years. Wholly dependent on turnover.
Tonboles365
2 Apr 2020
Peterborough
That's actually really interesting and useful to know. Thank you
