Departing on full power?
Muttley
17 Jul 2007
Not true.
As my illustrious colleague has pointed out....
the two tier railway does exist, but the premiership is comprised of Darn Sarf and Scotrail. The north of England is very much in the Blue Square league.
17 Aug 2009
About Locos, You can depart on a 67 wide and you'll really really struggle to overload it. So yes, you can wide a loco from start and it won't overload.
Can you do it on a 37? From what I know, do it on a 37 or similar and you will very quickly chew the track up, not to mention revving the engine unecessarily high and perhaps causing damage.
westcoaster
4 Dec 2006
DTOS A or B
although not a loco driver im sure that this would cause an overload, and power would be cut, and you would have to shut off then power up again, down in fcc world we are taught to take power (319's) in step 1, with notch 2 power, once you feel the unit take power, off with the brake and notch 3 or 4 depending where you are.
O L Leigh
20 Jan 2006
In the cab with the paper
Don't you believe it.
All our rolling stock is fast approaching 30 years old, the only exception being the Cl317/6's which are a scant 24 years of age.
O L Leigh
TDK
19 Apr 2008
Crewe
Talk about a two-tier railway. :oops:
Ooop North we appear to be about a generation behind you Southies, so no WSP, ABS, CSR, GSM-R, etc etc etc
Errrm, The North has CSR, GSM-R, most trains have WSP but I haven't heard of any with ABS:roll:
turbo mick
17 Aug 2005
reading
I remember a driver i new opened up a class 56 light engine full power with brakes applied then released the loco brake and got up to speed rapid
Driving HSTs out of paddington you can only use up to notch 2 and when leaving the other stations no more than notch 4 till clear of stations
165/166 fleet notch 4 then straight to notch 5 smooth acceleration then 6,7
leaf fall coming you have to amend your power to stop Wsp cutting engines to idle if to agressive
mick
17 Aug 2009
I was on a train today and despite the tracks being wet the driver still kept slamming it into notch3/4 (EMU), there was slippage and you could hear a) the wheelspin and b) the WSP cutting in; made for excellent filming though!
