Gloster
So what to block instruments show with intermediate block?
Also of imterest here is the arrangements when switching boxes out, say at night, and ensuring that only one train can be in the longer section during the switching out procedure.
Also the arrangements where absolute block controlled by a signalman with his blick instruments, bells and levers joins onto an track circuit block controlled section. Hellifield to York power box at Skipton is a good example.
Intermediate block (IB) is a bit like a very advanced Starting Signal. The line is track-circuited from the signal box to the IBS, and usually with an overlap beyond it. The first train is offered by the signal box A to signal box C, when accepted the signals at A and IBS B, which has its own (usually automatic) Distant, are cleared. When the train passes A the signalman gives Train Entering Section to C and puts the signals back to Danger: firstly those around the box and later the IBS once it has automatically gone back to Danger as the train passed. The train is in the section to C, but the signalman can now let a train up to the IBS if the overlap is clear as it is prevented from running into the back of the first train by the IBS at Danger. Once the first train passes C and the signalman there gives Out of Section, the signalman at A can ask the road for the train approaching the IBS and clear the IBS when he gets Line Clear, before giving Entering Section. When I operated an IBS we gave Entering Section as the first train passed the A, but immediately after getting Line Clear if the train was between A and the IBS when we got Line Clear.
Switching out is pretty well identical to normal switching out: only done when there are no trains either On Line or Offered. Just remember that the IBS has to be cleared as well.
At a box that is AB one side and TCB the other, the line will be entirely track-circuited on the panel side of the manual box (right up to it) and normal AB the other way. The signalman just acts as an interface by describing trains using bell codes and any method a panel may use: sometimes he or she will hear and acknowledge four beats, and then tap 1??? into a train describer.
N.b. My signalling days were thirty-five years ago.
