Definitely Not MML Electrification progress updates: A6006 bridge reconstruction
8stewartt
18 Mar 2013
Syston to Sheet Stores/Trent East is now cleared for W10, restricted to slow lines only Syston to Ratcliffe due to the fast line bridge at Loughborough. Bridge 94, the next brick bridge north of this one (which is 88) is restricted to 25mph for W10 trains.
londonmidland
22 Dec 2009
Leicester
Trying not to get sidetracked but as soon as things go slightly wrong, the Leicester area becomes a big bottleneck.
I’ve noticed that the additional freight services have to manoeuvre the extremely slow 10mph curve at Syston North(?) Jn.
This causes delays if there is an XC service behind it, or if there is an XC or another freight waiting to cross over from the MML, from the Leicester direction, towards Peterborough.
This then has a knock on effect to the northbound EMR services.
There’s definitely a capacity issue between Wigston and Syston.
Northampton
One Network Rail were aware of at least 6 years ago:
[Link to Leicester Area Strategic Advice, authored in 2020]
Scenario 1, with the fewest additional services, would results in a capacity utilisation at Wigston North Junction of 90% in the Down direction (towards Leicester) due to the large number of conflicting moves. This is in excess of the desired level to run a reliable, punctual network and is likely to create timetabling difficulties. As Scenario 2 and 3 led to a utilisation of over 100%, interventions are recommended across all scenarios at this junction. The capacity analysis found that north of Leicester Station currently planned services through to the 2030s could be accommodated with existing infrastructure, primarily due to the low number of trains using the chord towards Syston East Junction
On the grand scale of things a slow curve at Syston North is a win compared with the previous route over to the West Midlands and back, including passing through the Syston-Wigston bottleneck.
Northampton
Especially as the Syston North curve is double track, as opposed to the single-line south curve, and joins the MML once it's back to 4 tracks so freight doesn't have to hit a gap in the Intercity traffic.
