December 2026 Timetable Change
GoneSouth
17 Dec 2018
(I think this is for December 2026 rather than 2027 if approved) RAIL are reporting that CrossCountry want to increase Glasgow services (not new news), including Sundays-only services via Shotts (which is a bit I hadn't heard before).
I think they should get their act together everywhere else before stretching themselves to breaking point adding more Glasgows to an already overloaded service through the core of Englands. Leave Scotland to Scotrail.
waverley47
17 Apr 2015
What an odd thing to propose. If they were an OA operation I'd assume it was an orcats raid, but asking the UK government to sign off on funding to send a unit, a driver, and onboard staff to shuttle to Glasgow and back with a stop at Shotts, on a Sunday, is certifiably bizarre.
A S Leib
9 Sep 2018
The only reason I can think of is that they'd like to be able to use Shotts for diversions if necessary. LNER don't need to run services through Gainsborough and Hexham on a weekly basis for that.
waverley47
17 Apr 2015
They use the Shotts line daily at least once.
5C49 shuttles a unit back from Central daily, as and when the inbound service actually makes it to Central and isn't capped early at Waverley.
There are also one outbound diagram from Craigentinny in the morning, and a second return at night.* Crosscounty runs one more service terminating at Central daily than departing there, and 5C49 gets the spare unit back to Craigentinny.
* There has however been an effort on XC's part recently to stable the unit at Polmadie instead, and send the driver back on pass, and therefore it's more often than not that either or both of these other workings run instead to Polmadie.
It's very likely therefore that there would be a high proportion of XC drivers who would already sign Shotts, and definitely doesn't begin to explain why they want to send a unit from Craigentinny on a three hour jaunt to Central via Shotts and back, and back to the depot, every Sunday from the middle of December. And it definitely doesn't explain why they want the Government to subside it....
amn
23 Nov 2021
Oxford
These are the paths that are already in the timetable from February, it's just the access rights for them that are currently out for consultation.
The paths via Shotts are really just there because there's no viable way of getting them a path though Motherwell. Odd considering these are only really putting paths that used to exist back, but there seems to have been a lot moved into the paths they used to use since they went.
tom1649
5 Jul 2010
Yep, absolutely crazy that this is being allowed when capacity problems haven't been fully addressed elsewhere. It's not like there's a shortage of services between Glasgow and Edinburgh operated by Scotrail.
318266
30 Sep 2017
S&W of Alexander Dennis, N&E of Wrightbus
I don't think we should be so quick to dismiss the possibility of the English Government wanting to ORCATS raid the Scottish Government...
The exile
31 Mar 2010
Somerset
Though it depends on whether use ;or not) of a “spare” unit between Glasgow and Edinburgh has any bearing on the capacity problems elsewhere. If the set is in Edinburgh at the time it can’t alleviate capacity problems between Reading and Birmingham - whether it’s going to Glasgow and back or not.
Mag_seven
1 Sep 2014
here to eternity
The two hourly XC Glasgow extensions were put in becuase the LNER Glasgow extensions were taken out.
Mag_seven
1 Sep 2014
here to eternity
I think the LNER Glasgow service was just once per day, leaving Lumo as the only Newcastle to Glasgow service.
Latterly yes but when LNER took off the 2 hourly throughout the day service we were told that XC would fill that gap (in regular through services from Glasgow to York, Newcastle etc).
Harpo
21 Aug 2024
Newport
Yes, the genius of removing electric trains and replacing them with diesels under the wires.
There’s a brilliant environmental metric available for government right there but it would make UK transport strategies look terrible.
