December 2025 East Coast Timetable
IrishDave
30 Jun 2009
Brighton
But there still seems to be a missing 2L52 1827 to Letchworth.
That is pretty poor to not have a service right in the middle of the evening peak commuter time.
It appears the 18:27 Kings Cross to Letchworth has been sacrificed to give paths over Welwyn for two off-pattern trains, the 18:42 to Newcastle (Lumo) and the 18:45 to Middlesbrough (LNER).
If they were in the standard pattern, the 18:42 Lumo would be at 18:15, but the 18:12 GN to Peterborough precludes the use of the 18:15 path and forces Lumo to go off-pattern at 18:42. Similarly, the 18:45 Middlesbrough would be expected to be an extension of a York path at 18:47, but that only works if the Kings Lynn departs at 18:54 and runs fast to Cambridge South; instead, the Kings Lynn departs at 18:48 and calls at Letchworth and Royston, forcing the Middlesbrough earlier at 18:45.
The combination of those two non-standard paths, which are themselves driven by the additional peak trains for GN, have led to the odd situation where one of the trains that *is* in the standard pattern (namely the 18:27 to Letchworth) cannot be accommodated. An odd choice, if you ask me.
OneOfThe48
6 Mar 2023
Ah I noticed these services had appeared in the timetable when I was putting everything into Simsig, but didn’t notice they started in February. The “model” date I chose was in March, so that explains that…
I’m sure February is what they’re hoping for, but nothing has been decided or confirmed as yet
Magdalia
1 Jan 2022
The Fens
1P90 1842 KX-Peterborough is also missing. Other than this there are xx12/42 KX-Peterboroughs from 1642 to 1912.
Between 1C86/1C88 1824/1854 KX-Cambridge there is now this procession of trains on the down fast:
1S28 1830 KX-Edinburgh
1N13 1833 KX-Newcastle
9S48 1714 Brighton-Cambridge
1D27 1839 KX-Leeds
1N98 1842 KX-Newcastle
1N86 1845 KX-Middlesbrough
1T54 1848 KX-Kings Lynn
9J56 1724 Horsham-Peterborough
All of these continue on the fast line after Woolmer Green, apart from the 2 Thameslink trains.
MikeWM
26 Mar 2010
Ely
This looks like classic ECML disruption delay, something I've experienced hundreds of times, and probably not new timetable related.
Thanks, that's interesting to follow. I hadn't looked into it in detail.
Agreed that these 1T48 issues aren't really new timetable related at this point, but that's partly because 1C80 is missing right now, as discussed above. Once 1C80 runs, it has the potential to significantly delay 1T48, as with the delay to 1T50 last night - 1T50 was only 2 late at Letchworth, but 11 by Cambridge, and that's entirely due to being stuck behind the late stopping service 1C82.
Eg. the stock for the 0946 Ely-KGX now only arrives at Ely at 0935. Previously it arrived 0926, and left 0947 - and even with 21 minutes, it all too often didn't make it to Ely if it had picked up delays earlier. With just 11 minutes to turnaround now, it seems more likely to be a problem. The first two days it has run ok, but let's see over time.
Was 20 late arriving this morning, but for once they didn't turn it at Cambridge - instead it left Ely 14 late, which worked fine (for me at least!)
aron2smith
20 Jan 2025
I'm impressed that Stevenage has clockface direct trains to Newcastle (and the main stops north of York) hourly, as well as Harrogate and Bradford seeming to alternate every 2 hours now. That 1 1/2 hour journey time to York or just over 2 hours to Leeds makes day trips viable, shame the price is prohibitive. Was shocked how quickly the ECML got me to the north when doing All Line Rovers in the past, but seems like Stevenage is even more of a convenient station now than ever before due to this timetable offering more direct trains. Very helpful for me with both the Hertford Loop and 907 bus being useful for onward travel, making it much easier to avoid travelling into London. Just a shame they made it set down only towards Kings Cross for those who need it, Thameslink seems woeful these days.
dk1
2 Oct 2009
East Anglia
1D27 1839 KX-Leeds
When it works it’s an extremely impressive bit of timetabling.
Magdalia
1 Jan 2022
The Fens
1D27 1839 KX-Leeds
While looking at tonight's disruption, I noticed something else about these.
1N98 goes onto the slow line at Woolmer Green, calls at Stevenage in platform 4, then goes back out onto the fast line after 1N86 and 1T48 have passed.
I'd call it brave myself. A flight of 8 like that is going to have the performance people permanently twitching.
As an optometrist would say, better or worse?
route101
16 May 2010
Do we think Lumo will expand the Glasgow service to include Saturdays and other services.
hexagon789
2 Sep 2016
The paths they've got are all the ORR would approve.
I understand they wanted others, including Saturdays.
Perhaps if the extensions prove successful, they may be able to lobby for additional ones in the future.
route101
16 May 2010
Speaking of LNER, I randomly came across a printed timetable at Berwick upon Tweed on the ticket office counter. Just one. And none were on any racks. These must be kept behind the counter. Did not expect to see them still around.
43 302
25 Oct 2019
First printed ECML timetable since 2019 I believe!
Llandudno
25 Dec 2014
Matlock
Can never understand why paper timetables are kept hidden behind the counter
No doubt at the next timetable change there will be 000s of spare timetable booklets sent for recycling.
Then a decision will be made to not issue them in the future as no one picks any up…!
Bayum
21 Mar 2008
Is 1T48 passing not because of the delays? Normally, it’s timetabled through Stevenage for 1748 so unless 1N98 is waiting 23hrs, I think it’ll be just the LNER it waits for!
There is 1T58 which passes from Kings Cross to Kings Lynn?
route101
16 May 2010
Yes, perhaps only limited quantities printed. The London and South East Rail maps were also behind counters in the last few years.
Magdalia
1 Jan 2022
The Fens
The relevant Kings Lynn train is 1T54 which departs Kings Cross at 1848. 1T48 was a transcription error, sorry!
Cach17
13 Jul 2023
Kent
Do they even still produce physical versions of the L&SE map? I thought they'd discontinued them.
Always loved collecting them on trips out over the years as a wee lad.
route101
16 May 2010
Last one picked up was late 2019 from behind the info counter at Liverpool Street.
sjm77
8 Jan 2020
Manchester
Do we have a view yet if the new timetable 'works'? PLEASE NOTE; I am not talking about the seat reduction to Leeds, or the lack of Newark-Retford connection. What I mean is can it operate reliably unlike the famous 2018 Northern/TPEx debacle!
Failed Unit
26 Jan 2009
Central Belt
Still too early to tell, the lack of recovery seems to be clear.
I was on the 1130 Edinburgh - London (ex Inverness). It arrived about 10 minutes late at Newcastle so the 1302 TPE was put out ahead of it, losing more time into York. After Doncaster, The 1200 Edinburgh - London overtook it. (Sensible as it was non-stop) but costing more time.
If the TPE had waited would the LNER have recovered? (Who knows) - Would the out of path TPE have lost more time and imported more delays accross the north?
Great Northern seems to be better at the Southern end. The Fenline users don’t seem too impressed
800Travel
3 Nov 2023
The TPEs are often held for late running ~XX:00 southbound LNERs - usually up to about 5 minutes or so. if the delay is more, the TPE tends to leave first.
MikeWM
26 Mar 2010
Ely
...this morning for example, the incoming train got stuck behind a late-running Thameslink which had been delayed somewhere around Purley, which itself got stuck behind a late-running stopper which picked up a large delay around Royston.
As such, 17 minutes late, terminated short at Cambridge, and no 0946 for me to catch at Ely.
Adrian1980uk
24 May 2016
It will take a while for the ROCs work out what works and what doesn't for recovery, even on timetables that have been in place for a few years it doesn't always appear to the average person why certain actions are taken in times of disruption.
sjm77
8 Jan 2020
Manchester
Does anybody know why there are some alterations to today's timetabled departure times from Kings Cross? For example the 16:00 1S23 to Edinburgh leaves at 15:56 instead of 16:00. The sectional running times are then extended between Potters Bar and Hatfield so the service picks up it's regular path. However realtime trains does show a switch to the slow lines. Similar ha shappened to the 11:46 Kings Cross to York.
Segedunum
International Transport
22 Dec 2013
Up North
No service from the East Coast Mainline to the Thameslink core, so some LNER services have been "flexed" to accommodate additional services using Kings Cross.
Looks like Thameslink have been given Platform 8 all day for this purpose.
