December 2023 Timetable Change
10 Oct 2012
Yes, there was a spell of 22tph.
Was there? As Welwyn to Sevenoaks in the peaks didn't start until May 2022, so 16tph from the MML and 2tph each from Peterborough and Cambridge would be a maximum of 20tph.
Yes, a quirk in the timetable, in one peak, one direction only!
Park47515
28 Sep 2022
There's also an additional 12-car in the mix as well, the 0733 from Bedford becomes a 12-car which returns in the evening peak at 1653 from Gatwick (1741 from St Pancras).
The reinstatement of the 0715 means the core has 21tph arriving at St Pancras between 0735 and 0835.
Just need a Littlehampton back...
Llandudno
25 Dec 2014
Matlock
I don't know if it's already been mentioned, but Wrexham Central–Bidston is going to ~every 45 minutes with Hawarden Bridge a request stop.
So less time to wait when a service operated by a Class 230 unit gets cancelled…
infobleep
27 Feb 2011
I noticed that the 14:54, Reading to Gatwick Airport service is a fast service but with an additional stop at Shalford, rather than stopping additionally at Shalford, Chilworth and Gomshall.
The thing is, it departs Redhill at 16:17, which is the same number of minutes past the hour to the 12:54, which does stop additionally at all three stations?
So 14:17 and 16:17 respectively.
Does anyone know why the two stations are missed out? I was checking Monday 11 Dec.
Wilts Wanderer
21 Nov 2016
Looking at the overall timetable on GWRs website it appears to be due to the pattern change for the evening peak where every train serves Shalford and then either Chilworth & Gomshall or Dorking West & Betchworth. The transition creates an additional interval gap of 30 mins on top of the previous 2hrs for the Chilworth/Gomshall pairing.
infobleep
27 Feb 2011
Given the there is time to stop there, they might as well do so. Its not as of the train is departing Shalford later or Redhill earlier.
HamworthyGoods
15 Jan 2019
It’s called giving performance robustness. Not calling allows for some recovery time prior to the evening peak starting.
Minstral25
10 Sep 2009
On a similar vein why does 2O96 22:34 from Reading turn round at Shalford and not provide a service to Gatwick and return to Reading later?
HamworthyGoods
15 Jan 2019
Because the route is shut for overnight engineering works. Details to be found in Network Rail’s operational rules which can be found online.
Network Rail has to maintain the track, the need for regular patrols has been highlighted this week by the broken rails on the Western Main Line.
FenMan
13 Oct 2011
The 23:34 from Reading does operate through to Gatwick though.
I thought the truncation of the 22:34 was a DfT-inspired decision due to a lack of custom east of Guildford. Indeed, it wasn't restored to the "normal" pre-COVID evening schedule at all until last year, resulting in a two hour service gap between Reading - Blackwater Valley stations - Guildford.
It certainly means that only one unit is at Redhill overnight, and given there are no GWR drivers based there avoids either having to run a late train back to Reading, a taxi ride for the driver or an overnight turn.
It doesn't come back to Reading though. The driver has to do a night shift to work it.
Wilts Wanderer
21 Nov 2016
The railway at the Wokingham end shuts at 0035hrs. If the 2234 runs beyond Shalford it can’t get back to Reading and would end up stabling at Redhill. This would need a long late-night taxi ride home for the traincrew (since GWR no longer hire GTR crew) so it’s not a surprise that it’s been cut really.
(JonathanH beat me to it :lol:)
I take it you mean the bit south of Wokingham, given that the 2350 from Waterloo arrives in Reading at 0107. However, I note that this SWR train doesn't have to get to Reading if the line is shut, whereas a GWR train would have to.
Wilts Wanderer
21 Nov 2016
Yes thanks for clarifying that, I did mean the Aldershot South Jn-Wokingham Jn section.
Mamorin
21 Sep 2020
Cheshire
So I just looked at the Northern timetable and it seems that services to Stoke on Trent are almost back to Hourly 6 days a week which is good to see.
infobleep
27 Feb 2011
I noticed the 23:37 empty coaching stock from Shalford waits 5 minutes at Guildford for pathing reasons.
What is the reason it can't run in passenger service non stop to Reading? So Shalford, Guildford and Reading. Would the guard be over their hours? I'm assuming the train has a guard.
Is there demand given the 2326 and 0001? It soon catches up the 2326, as far as that is possible given the signalling headways, in any case. There is a four minute pathing allowance at Farnborough and seven minutes at Blackwater.
Jamesrob637
12 Aug 2016
They have been for a while, but don't get many of us started on the Sunday service.
moonarrow458
9 Jun 2023
I wonder whether there's a reluctance to convert that particular ECS to passenger service, despite being perfectly feasible to do so, as there may possibly be a longer term aspiration to restore the 2234 Reading to Shalford to Redhill or Gatwick, as previously and in such a scenario the ECS would dissapear and so if the ECS were to run in passenger service then you'd have to withdraw that which would inconvenience any passengers that had come to rely upon it.
FenMan
13 Oct 2011
Running the empty coaching stock in service back from Guildford to Reading, departing Guildford at 23:45, would provide excellent connections with:-
- 2300 from Waterloo via Woking (arriving Guildford at 2339)
- 2219 from Portsmouth Harbour (2337)
- 2233 from Waterloo via Effingham Junction (2334)
- 2215 coach from Heathrow Bus Station (2328)
Neither of the 2326 and 0006 departures connect with anything useful (the 0006 - timed slightly earlier in the current timetable - used to connect with 2315 Waterloo via Woking*, but SWR have binned that service M-F).
So, yes, running the 2345 in service would be very worthwhile.
*I've used this connection 100s of times when travelling back from London to Blackwater. Since it was binned it's now more convenient for me to travel back via Paddington and Reading, departing Paddington at 2250.
DelW
15 Jan 2015
There's an annoying connection failure in the other direction as well. The 23:34 departure from Reading used to connect at Guildford onto the 23:45 Waterloo to Portsmouth. SWR have failed to reinstate that long-standing last train, so there is now no southbound connection off the 23:34 train from Reading.
It was even worse when GWR wasn't running the 22:34 departure, meaning that the last connection to the down Direct left Reading at 21:34. At least that's no longer the case.
takno
Verified Rep - Traksy
Feasible may be an overstatement here. It's not at all clear that the train running empty requires a guard, so one would need to be rostered. In addition it would need to spend a significant amount of time on station stops, not least having to run through platforms at Reading rather than straight round to the depot. The addition of stops also means that it actually needs to run, and moreover run booked time and booked route, and that if it doesn't GWR are on the hook for compensation or rail replacement buses or taxis.
It's never free to turn an empty stock train into a service train, and doing it with the last train of the day can be particularly expensive, often for very little customer value at all.
infobleep
27 Feb 2011
It isn't free but some other ECSs in other parts of the country have been turned into train services for passengers rather than remain as an ECS. So it is possible.
In this case on balance it may not have a good enough case but it should at least be considered.
I've not seen any publicity around the 2 trains hour to Gatwick Airport. Has anyone else seen any publicity? I would have expected a poster promoting it.
