DCR locos
Trainman40083
29 Jan 2024
Derby
I would imagine that having set up a supply line for 60099 will speed things up considerably for the rest
Thanks @47286Dan
60029 & 60055 worked 0036 0D23 Willesden to Wembley Receptions 1-7 and 0149 6D23 to Preston empties top and tail due to engineering work
60055 working 0754 6D23 Preston to Penmaenmawr Quarry empties - 1746 0D90 - 1841 0D91
60029 working 0712 0D60 Preston to Chaddesden
60047 working 0945 6Z92 Eccles Road Johnstons Sidings to Chaddesden empties
56045 and/or 56103 - 1224 0M47 - 1603 0M48 hauling 47715
Effectively you take parts from other 66s, overhaul them, create a pool of spares and speed up considerably.
ExRes
16 Dec 2012
Back in Sussex
And building up the UKRL expertise/workforce.
Exactly, at both UKRL Loughborough and Boden Rectory Junction, if the Land Recovery rebuilds go ahead then UKRL may be well placed for that potential work
60055 worked loaded 0851 6A25 Penmaenmawr Quarry to Wembley Receptions 1-7 and 1911 0A25 to Willesden
60029 worked 1212 0D62 Chaddesden to Rectory Junction
60046 worked 1224 0A60 Leicester LIP to Willesden via Nuneaton
60047 worked 2201 6M70 Chaddesden to Tunstead Sidings empties
60028 is at Bristol East Depot and 56045 & 56103 at Willesden
47286Dan
27 Dec 2018
Sunday morning update,
Correct with 60029 @ExRes
56045 DCRO WILSDNDCR WILSDNDCR F N
56103 DCRO WILSDNDCR WILSDNDCR F N
60028 DCRO BRISTLEDT BRISTLEDT 4 N
60029 DCRO CHADDESDN 570D621K16 F RECTRYJCR N
60046 DCRO LESTER SD 590A601K16 F WILSDNDCR N
60055 DCRO PENMANMR 406A251D16 4 * WEMRECP N
60099 DCRO LOUGBO HS LOUGBO HS F X
60047 GBTG CHADDESDN CHADDESDN 4 N
Dan
Monday morning update
60028 DCRO TYTHRINTN 816M021A17 4 * QUNTNRLHD N
60029 DCRO RECTRYJCR RECTRYJCR F N
60046 DCRO QUNTNRLHD QUNTNRLHD F N
60055 DCRO QUNTNRLHD QUNTNRLHD 4 N
60047 GBTG TUNSTDBLI 346M71C317 4 HUMBSTRD5
Dan
ExRes
16 Dec 2012
Back in Sussex
Dan
Dan
Thanks @47286Dan
60046 & 60055 worked 0328 0M23 Willesden to Wembley Receptions 1-7, loaded 0438 6M23 to Quainton Railhead and 0953 6V37 to Aylesbury North Loop empties
60047 worked loaded 0334 6M71 Tunstead Sidings to Humberstone Road No5 Top Sidings, 1516 6D59 to Chaddesden empties and 2013 6M81 to Peak Forest D&C empties
60028 worked 0349 6B01 Bristol East Depot to Tytherington empties, loaded 0704 6M02 to Quainton Railhead and 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
60046 worked 0953 6V37 Aylesbury North Loop to Tytherington empties and loaded 2158 6M29 to Willesden
60055 worked 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 1834 6V54 Aylesbury North Loop to Tytherington empties
56045 & 56103 worked 1035 6V23 Willesden to Merehead Quarry (Fhh) empties and loaded 1624 6M18 return
60028 & 60055 worked 1834 6V54 Quainton Railhead to Aylesbury North Loop empties
*Updated Tuesday 18th November*
60047 worked loaded 0350 6L82 Peak Forest D&C to Eccles Road Johnstons Sidings and 1800 6M54 return empties
60046 worked loaded 0423 6M23 Willesden to Quainton Railhead, 1034 6V37 Aylesbury North Loop to Tytherington empties and loaded 2136 6M29 to Willesden
60055 worked loaded 0704 6M02 Tytherington to Quainton Railhead and 1834 6V54 Aylesbury North Loop to Tytherington empties
60028 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1010 0A27 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 1904 0A53 to Aylesbury Sidings
60028 & 60046 worked 0924 6A27 Quainton Railhead to Aylesbury North Loop empties
56045 & 56103 are at Willesden
60029 (16/11) is on maintenance at Rectory Junction
*Updated Wednesday 19th November*
60047 worked loaded 0350 6L82 Peak Forest D&C to Eccles Road Johnstons Sidings and 1700 6M54 return empties
60046 worked loaded 0433 6M23 Willesden to Quainton Railhead, 1034 6V37 Aylesbury North Loop to Tytherington empties and loaded 2136 6M29 to Willesden
60055 worked loaded 0704 6M02 Tytherington to Quainton Railhead which was terminated at Woodborough Tamper Sidings reportedly due to bad flats
60028 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1010 0A27 Aylesbury North Loop to Aylesbury Sidings, 1Z99 to Woodborough and loaded delayed (1803) 1644 6Z74 (formerly 6M02) to Bristol East Depot
56045 & 56103 worked 1034 6V23 Willesden to Merehead Quarry (Fhh) empties and loaded 1624 6M18 return
ExRes
16 Dec 2012
Back in Sussex
What was 0Z55 all about this morning ?
6M02 starts East Depot
A very good question, on RTT there is an 0349 0B01 Bristol East to Tytherington as well as the 0530 0Z55 to Bristol East, for what reason I don't know, 0816 6M02 Bristol East to Quainton Railhead is showing on RTT as running presumably with 60028 - a Flickr contributor says that 60055 was taken off the train yesterday and put in the Tamper Siding
Another slight problem is what will release this mornings 6M23 at Quainton Railhead?
** Answers to both - 1) 60028 went to Tytherington and back for refuelling, I'd forgotten the new fuel point was there & 2) 56103 has gone solo on 6O34 to Cliffe and 56045 top and tail on 6M23 as release loco
56103 worked 0220 6O34 Willesden to Cliffe Brett Marine empties, loaded 0951 6Y20 to Chessington South Sidings and 1942 6M17 to Willesden empties
60028 worked 0349 0B01 Bristol East Depot to Tytherington, 0530 0Z55 return, loaded 0816 6M02 to Quainton Railhead and 1945 6V54 Aylesbury North Loop to Tytherington empties
60047 worked loaded 0423 6L82 Peak Forest D&C to Eccles Road Johnstons Sidings
60046 & 56045 worked loaded 0440 6M23 Willesden to Quainton Railhead and 0924 6A27 to Aylesbury North Loop empties
60046 worked 1034 6V37 Aylesbury North Loop to Tytherington empties and loaded 2136 6M29 to Willesden
56045 worked 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 1904 0A53 Aylesbury North Loop to Aylesbury Sidings
60028 & 56045 worked 1834 6V54 Quainton Railhead to Aylesbury North Loop empties
60055 is in Woodborough Tamper Siding and is scheduled on RTT as Fridays 2300 8Z60 to Bristol East Depot
*Updated Friday 21st November*
56103 worked 0220 6O34 Willesden to Cliffe Brett Marine empties, loaded 1045 6Y20 to Chessington South Sidings and 1942 6M17 to Willesden empties
60046 worked loaded 0423 6M23 Willesden to Quainton Railhead, 1034 6V27 Aylesbury North Loop to Wembley Receptions 1-7 empties and heavily delayed (1658) 1314 6D90 to Penmaenmawr Quarry empties, delay due to signal failures
60028 worked loaded 0704 6M02 Tytherington to Quainton Railhead and 1945 6M54 Aylesbury North Loop to Willesden empties
56045 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1010 0A27 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
60046 & 56045 worked 1005 6A27 Quainton Railhead to Aylesbury North Loop empties
60047 worked delayed 1124 6H84 Eccles Road Johnstons Sidings to Kings Lynn TC empties, 115 late passing Eccles due to points failure
60028 & 56045 worked 1834 6M54 Quainton Railhead to Aylesbury North Loop empties
60055 worked 2300 8Z60 Woodborough to Bristol East Depot
Forty29
10 Dec 2021
Bicester
Is it likely 56045 will be booked on 6M54 1854 Quainton to Willesden this evening solo or with 60046 if it runs?
Forty29
10 Dec 2021
Bicester
Thanks
56045 should likely be on 6M54 with 60028, 60046 should be heading north with the delayed 1314 6D90 to Penmaenmawr
Thanks for information plan was to go and catch it at Princes Risborough but had to do something else with family last minute!
ExRes
16 Dec 2012
Back in Sussex
60028 worked 0114 6V51 Willesden to Bristol East Depot empties
60047 worked 0450 6L92 Kings Lynn TC to Middleton Towers empties, loaded 0901 6M89 to Chaddesden and loaded 1646 6M91 to Ravenhead Sidings
60046 is at Penmaenmawr Quarry, 56045 at Aylesbury Sidings and 56103 at Willesden
60055 is at Bristol East Depot and scheduled to visit the St Phillips Marsh Depot wheel lathe on Monday
Thanks
56045 is actually spending the weekend at Aylesbury Sidings, 60028 worked 6M54 solo from Aylesbury North Loop to Willesden
47286Dan
27 Dec 2018
56045 DCRO AYLSBY LP AYLBYDMUD 1 N
56103 DCRO WILSDNDCR WILSDNDCR 4 N
60029 DCRO RECTRYJCR RECTRYJCR F X
60046 DCRO PENMANMR PENMANMR 4 N
60055 DCRO BRISTLEDT BRISTLEDT L T
60047 GBTG RAVNHDSTH RAVNHDSTH 4 N
Dan
Evening update,
Just one working, rest of locos in same place as this morning
60046 DCRO PENMANMR 406A231X23 4 * WEMRECP N
Dan
ExRes
16 Dec 2012
Back in Sussex
Dan
Evening update,
Dan
Thanks @47286Dan
60046 is indeed working loaded 1850 6A23 Penmaenmawr Quarry to Wembley Receptions
60047 was also out working 1752 6D85 Ravenhead Sidings to Chaddesden empties
47286Dan
27 Dec 2018
M60028 DCRO TYTHRINTN 816M021A24 4 * QUNTNRLHD N
60046 DCRO QUNTNRLHD QUNTNRLHD 4 N
60047 GBTG CHADDESDN CHADDESDN 6 N
Dan
ExRes
16 Dec 2012
Back in Sussex
Dan
Thanks @47286Dan
60046 worked 0131 0A23 Wembley Receptions 1-7 to Willesden, 0328 0M23 return, loaded 0438 6M23 to Quainton Railhead, 1034 6V37 Aylesbury North Loop to Tytherington empties and loaded 2136 6M29 to Willesden collecting 60055 from Bristol East Depot
60028 worked 0349 6B01 Bristol East Depot to Tytherington empties, loaded 0704 6M02 to Quainton Railhead and 1945 6V54 Aylesbury North Loop to Bristol East Depot empties
56045 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1005 0A27 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
60055 worked 0907 0B60 Bristol East Depot to St Phillips Marsh Depot Fhh and 1903 0B61 return visiting the wheel lathe
60046 & 56045 worked 0924 6A27 Quainton Railhead to Aylesbury North Loop empties
60047 worked 2013 6M81 Chaddesden to Peak Forest D&C empties
47286Dan
27 Dec 2018
Tuesday morning update
56045 DCRO WILSDNDCR 726O201525 4 * GRAIN FYM N
56103 DCRO WILSDNDCR 726O201525 4 * GRAIN FYM N
60028 DCRO TYTHRINTN 816M021A25 4 * QUNTNRLHD N
60047 GBTG PKFORSTDC 346L821425 4 ECCLESRD N
Dan
ExRes
16 Dec 2012
Back in Sussex
Dan
Thanks @47286Dan
56045 worked 0034 0A56 Aylesbury Sidings to Willesden
60046 & 60055 worked loaded 0418 6M23 Willesden to Quainton Railhead and 0953 6V37 to Aylesbury North Loop empties
60047 worked loaded 0423 6L82 Peak Forest D&C to Eccles Road Johnstons Sidings and 1800 6M54 return empties
56045 & 56103 worked 0502 6O20 Willesden to Grain Foster Yeoman empties, loaded 0930 6Z20 to Chessington South Sidings and 1942 6M17 to Willesden empties
60055 worked 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 1945 6V54 Aylesbury North Loop to Bristol East Depot empties
16 Aug 2019
Ldn
Thanks @47286Dan
56045 worked 0034 0A56 Aylesbury Sidings to Willeden
60028 working 0349 6B01 Bristol East Depot to Tytherington empties
60046 & 60055 working loaded 0418 6M23 Willesden to Quainton Railhead
60047 working loaded 0423 6L82 Peak Forest D&C to Eccles Road Johnstons Sidings
56045 & 56103 working 0502 6O20 Willesden to Grain Foster Yeoman empties
Looks like 055 joined 046 at Bristol East on 6M29 last night to get back to Willesden
47286Dan
27 Dec 2018
Wednesday morning update
56045 DCRO GRAIN FYM GRAIN FYM 4 N
56103 DCRO GRAIN FYM GRAIN FYM 4 N
60028 DCRO AYLBYDMUD 700A21TC26 F QUNTNRLHD N
60046 DCRO WILSDNDCR 726M23C426 4 * QUNTNRLHD N
60055 DCRO TYTHRINTN 816M021A26 4 * QUNTNRLHD N
60047 GBTG PKFORSTDC 346L821426 4 ECCLESRD N
Dan
ExRes
16 Dec 2012
Back in Sussex
Dan
Thanks again @47286Dan
60055 worked 0349 6B01 Bristol East Depot to Tytherington empties, loaded 0704 6M02 to Quainton Railhead and 1945 6V54 Aylesbury North Loop to Bristol East Depot empties
56045 & 56103 worked 0409 6O20 Willesden to Grain Foster Yeoman empties, loaded 0930 6Z20 to Chessington South Sidings and 1943 6M17 to Willesden empties
60047 worked loaded 0423 6L82 Peak Forest D&C to Eccles Road Johnstons Sidings and 1700 6M54 return empties
60028 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
60028 & 60046 worked 0953 6V37 Quainton Railhead to Aylesbury North Loop empties
*Updated Thursday 27th November*
56045 & 56103 worked 0220 6O34 Willesden to Cliffe Brett Marine empties, loaded 0949 6Y20 to Chessington South Sidings and 1942 6M17 to Willesden empties
60046 worked loaded 0418 6M23 Willesden to Quainton Railhead cancelled at Aylesbury North Loop due to signal failure and loaded 1034 6V37 to Willesden
60028 worked 1638 0A52 Aylesbury Sidings to Quainton Railhead and 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
*Updated Friday 28th November*
60055 worked 0349 6B01 Bristol East Depot to Tytherington empties and loaded 0704 6M02 to Quainton Railhead
60046 worked loaded 0418 6M23 Willesden to Quainton Railhead and 1034 6V37 Aylesbury North Loop to Bristol East Depot empties
60028 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1010 0A27 Aylesbury North Loop to Aylesbury Sidings and 1638 0A52 to Quainton Railhead
60047 worked 1122 6H84 Eccles Road Johnstons Sidings to King Lynn TC empties
60028 & 60055 worked 1834 6M23 Quainton Railhead to Wembley Receptions 1-7 empties and 2224 0M23 to Willesden
*Updated Saturday 29th November*
60055 worked 0019 0D23 Willesden to Wembley Receptions 1-7, 0149 6D23 to Penmaenmawr Quarry empties, 1446 0D90 to Llandudno Junction and 1535 0D91 return
*Updated Sunday 30th November*
60055 worked loaded 0950 6A25 Penmaenmawr Quarry to Wembley Receptions 1-7 and 1700 0A25 to Willesden
60047 worked 1752 6D85 Ravenhead Sidings to Chaddesden empties
60028 is at Willesden, 60046 at Bristol East Depot and 56045 & 56103 at Willesden
60099 is still on test at UKRL Loughborough
*Updated Monday 1st December*
60028 & 60055 worked 0321 0M23 Willesden to Wembley Receptions 1-7, loaded 0438 6M23 to Quainton Railhead and 0953 6V37 to Aylesbury North Loop empties
60046 worked 0349 6B01 Bristol East Depot to Tytherington empties, loaded 0704 6M02 to Quainton Railhead and 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
60028 worked 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead and 1945 6V54 Aylesbury North Loop to Bristol East Depot empties
60055 worked loaded 1034 6V37 Aylesbury North Loop to Tytherington cancelled at Willesden - AZ - Incident in freight Yard or Terminal
60028 & 60046 worked 1834 6V54 Quainton Railhead to Aylesbury North Loop empties
*Updated Tuesday 2nd December*
56045 & 56103 worked 0238 6O34 Willesden to Cliffe Brett Marine empties, loaded 0951 6Z20 to Chessington South Sidings and 1942 6M17 to Willesden empties
60028 worked 0349 6B01 Bristol East Depot to Tytherington empties, loaded 0704 6M02 to Quainton Railhead terminated at Willesden due to late 4V45 departure from Quainton Railhead
60055 worked loaded 0414 6M23 Willesden to Quainton Railhead, 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 to Quainton Railhead
60046 worked 0803 0A21 Aylesbury Sidings to Quainton Railhead, 1034 6V37 Aylesbury North Loop to Tytherington empties and loaded 2136 6M29 to Wembley Receptions 1-7
60046 & 60055 worked 0953 6V37 Quainton Railhead to Aylesbury North Loop empties
600xx & 600xx worked 1834 6V54 worked Quainton Railhead to Aylesbury North loop empties
600xx worked 1945 6V54 Aylesbury North Loop to Bristol East Depot empties
600xx worked 2010 0A54 Aylesbury North Loop to Aylesbury Sidings
ExRes
16 Dec 2012
Back in Sussex
60028, 60046 & 60055 worked variously loaded 0430 6M23 Wembley Receptions 1-7 to Quainton Railhead, 0803 0A21 Aylesbury Sidings to Quainton Railhead, 0953 6V37 Quainton Railhead to Aylesbury North Loop empties, 1034 6V37 Aylesbury North Loop to Tytherington empties, 1040 Aylesbury North Loop to Aylesbury Sidings, loaded 1344 6V02 Willesden to Quainton Railhead, 1638 0A52 Aylesbury Sidings to Quainton Railhead, 1834 6V54 Quainton Railhead to Aylesbury North Loop empties, 1945 6V54 Aylesbury North Loop to Bristol East Depot empties, 2010 0A54 Aylesbury North Loop to Aylesbury Sidings and loaded 2136 6M29 Tytherington to Willesden
60013 (2/25) is undergoing reinstatement work at UKRL Loughborough and 60022 (29/8) at Bodens Rectory Junction
60060 (17/10) is undergoing assessment at Rectory Junction
56091 (26/1/24) is stored at Leicester LIP
60057 (16/5) & 60075 (22/5) are stored at Rectory Junction for spares retrieval
60008/009/038/061/064/070/080/090/098 remain stored at Loughborough
*Updated Thursday 4th December*
56045 & 56103 worked 0223 6O34 Willesden to Cliffe Brett Marine empties, loaded 0951 6Z20 to Chessington South Sidings and 1942 6M17 to Willesden empties
60028, 60046 & 60055 working variously 0349 6B01 Bristol East Depot to Tytherington empties, loaded 0414 6M23 Willesden to Quainton Railhead, loaded 0704 6M02 to Quainton Railhead, 0803 0A21 Aylesbury Sidings to Quainton Railhead, 0953 6V37 Quainton Railhead to Aylesbury North Loop empties, 1034 6V37 Aylesbury North Loop to Tytherington empties, 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 Aylesbury Sidings to Quainton Railhead, 1834 6V54 Quainton Railhead to Aylesbury North Loop empties, 1945 6V54 Aylesbury North Loop to Tytherington empties, 2010 0A54 Aylesbury North Loop to Aylesbury Sidings and loaded 2136 6M29 Tytherington to Willesden
Welshguy1048
6 Apr 2023
North Wales
ExRes
16 Dec 2012
Back in Sussex
60028, 60046 & 60055 worked variously loaded 0414 6M23 Willesden to Quainton Railhead, loaded 0704 6M02 Tytherington to Quainton Railhead, 0803 0A21 Aylesbury Sidings to Quainton Railhead, 0953 6M27 Quainton Railhead to Aylesbury North Loop empties, 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 Aylesbury Sidings to Quainton Railhead, 1834 6V54 Quainton Railhead to Bristol East Depot empties and 2224 0V54 Wembley Receptions 1-7 to Willesden
60046 worked 1034 6M27 Aylesbury North Loop to Willesden Receptions 1-7 empties and 1314 6D90 to Penmaenmawr Quarry empties
60047 worked 1124 6H84 Eccles Road Johnstons Sidings to Kings Lynn TC empties
56045 & 56103 worked 1201 4V23 Willesden to Merehead Quarry (Fhh) empties and loaded 1624 6M18 return
Welshguy1048
6 Apr 2023
North Wales
60028, 60046 & 60055 working variously loaded 0414 6M23 Willesden to Quainton Railhead, loaded 0704 6M02 Tytherington to Quainton Railhead, 0803 0A21 Aylesbury Sidings to Quainton Railhead, 0953 6M27 Quainton Railhead to Aylesbury North Loop empties, 1040 0A28 Aylesbury North Loop to Aylesbury Sidings, 1638 0A52 Aylesbury Sidings to Quainton Railhead, 1834 6V54 Quainton Railhead to Bristol East Depot empties and 2224 0V54 Wembley Receptions 1-7 to Willesden
@ExRes
Thank you
Dave
ExRes
16 Dec 2012
Back in Sussex
60047 worked 0450 6L92 Kings Lynn TC to Middleton Towers empties and 0901 6M89 to Chaddesden empties
60028 worked 0935 0F60 Willesden to Chaddesden via Nuneaton & Leicester
60046 worked loaded 1453 6D24 Penmaenmawr Quarry to Chaddesden
60055 is at Bristol East Depot and 56045 & 56103 at Willesden
47286Dan
27 Dec 2018
Sunday update, not a lot happening
56045 DCRO WILSDNDCR WILSDNDCR 4 N
60028 DCRO CHADDESDN CHADDESDN F N
60046 DCRO CHADDESDN CHADDESDN 4 N
60055 DCRO BRISTLEDT BRISTLEDT 4 N
Dan
ExRes
16 Dec 2012
Back in Sussex
Dan
Thanks very much @47286Dan
60046 & 60047 worked loaded 2050 6A23 Chaddesden to Wembley Receptions 1-7
