Joseph T
Is there any reason, minus cost of upgrading lines and rolling stock, why the existing 750v DC third rail system can't be upgraded to a higher voltage to increase speed?
The ‘850V upgrade’has been debunked in these forums many times, a search on the term finds a number of threads where it’s been denied. Here’s an example:Some sections had, or have, the voltage up to 850v for that very reason (and to allow greater spacing of sub-stations, I think), but there is a limit to how much you can do this without the losses making it not worthwhile (again, I think). In any case, speeds above 100mph or so tend to be unsuitable for third rail use anyway.
Fair enough.The ‘850V upgrade’has been debunked in these forums many times, a search on the term finds a number of threads where it’s been denied.
Elf in High VisIs there any reason, minus cost of upgrading lines and rolling stock, why the existing 750v DC third rail system can't be upgraded to a higher voltage to increase speed?
This also means that as the voltage increases even below 875V, regenerative braking becomes possible for less of the time. This would increase energy use by up to 15%. It might be partly offset by the traction drawing a lower current at the higher voltage for the same power ... but that would result in no performance benefit and negate the point of changing the voltage in the first place.Regenerative braking effectively stops when the measured voltage is 875V.
The 850V is often associated with the 67 Bournemouth Electrification extension which was actually the no load voltage at the rectifier terminals. This was due to the low rating of the rectifiers used on the extension which were first generation silicon diode. Most were rated at 1MW (there were 2x1MW rectifiers at each substation) so to deliver 750V DC at full load the no load voltage was c850V DC due to the regulation across the rectifier. Previously the nominal rating of rectifiers had been 2.5MW and no load voltage was around 790V to deliver 750V DC.Some sections had, or have, the voltage up to 850v for that very reason (and to allow greater spacing of sub-stations, I think), but there is a limit to how much you can do this without the losses making it not worthwhile (again, I think). In any case, speeds above 100mph or so tend to be unsuitable for third rail use anyway.
Shoes dont float they weigh far too much. The main issue is the forces involved when transitioning onto ramp ends would tend to accelerate them up in the air and cause arcing but ultimately the shoes are designed to shear off at a certain point to avoid damage so there is a limit proportional to speed as to how fast you could go.I'm sure there were tests at above 100mph and the shoes started to float and not maintain contact with the 3rd rail leading to current collection issues. Or at least that's what Im sure I remember reading, feel free to tell me I'm wrong.
To an extent but increasing the voltage reduces resistive losses the and increases the overall system efficiency.This also means that as the voltage increases even below 875V, regenerative braking becomes possible for less of the time. This would increase energy use by up to 15%. It might be partly offset by the traction drawing a lower current at the higher voltage for the same power ... but that would result in no performance benefit and negate the point of changing the voltage in the first place.
The higher the max line speed the shallower the ramp angle needs to be but the shallower the ramp angle the greater the degree of arcing especially if you are well below line speed.The 850V is often associated with the 67 Bournemouth Electrification extension which was actually the no load voltage at the rectifier terminals. This was due to the low rating of the rectifiers used on the extension which were first generation silicon diode. Most were rated at 1MW (there were 2x1MW rectifiers at each substation) so to deliver 750V DC at full load the no load voltage was c850V DC due to the regulation across the rectifier. Previously the nominal rating of rectifiers had been 2.5MW and no load voltage was around 790V to deliver 750V DC.
Separately ive seem over 900V DC when we doing testing at night time as the no load voltage increased further as the high voltage tends to creep overnight to 34kV.
That's what I've tried to cover by mentioning that the current would be less at a higher voltage, but only if the overall power isn't increased to compensate. The OP suggested the reason to do this would be to increase speed, which would require an increase in power.To an extent but increasing the voltage reduces resistive losses the and increases the overall system efficiency.
The world record for third-rail systems was set by the Class 442. It reached 109mph on a test run. Though it didn't do this in regular service!I'm sure there were tests at above 100mph and the shoes started to float and not maintain contact with the 3rd rail leading to current collection issues. Or at least that's what Im sure I remember reading, feel free to tell me I'm wrong.
It was never really tested, certainly not at 125mphI'm sure there were tests at above 100mph and the shoes started to float and not maintain contact with the 3rd rail leading to current collection issues. Or at least that's what Im sure I remember reading, feel free to tell me I'm wrong.
Could be something to do with short 3rd rail ramps. If the shoe hits them at speed, power could be lost. The faster you go, the longer the ramp.I'm sure there were tests at above 100mph and the shoes started to float and not maintain contact with the 3rd rail leading to current collection issues. Or at least that's what Im sure I remember reading, feel free to tell me I'm wrong.
The shoes are fairly basic, just sit there under gravity. There has been no attempt at fitting small aerofoils to the brackets like the Bracknell-Willis pantograph has.
The situation itself is also more limiting compared with a pantograph. The inner side of the shoe is close to the bogie frame, the outer side is close to the gauge limit, and the top is constrained by the body above it. The whole thing is mounted to the axleboxes so is unsprung mass, and needs to carry much more current than an AC pantograph so must provide a larger cross-sectional area of conductor.Exactly. People seem to forget that pantographs were themselves not suitable for high speed operation with acceptably low maintenance until a considerable amount of research had been done on the dynamics of the pantograph/catenary system. The bald dogma that "third rail can't do >100mph" fails to acknowledge that pantographs used not to be able to either. It only appears to be true because nobody has done the equivalent research on what could be done for third rail current collection to improve upon dinosaur feet.
(I doubt you'd end up using aerofoils because the situations are rather different, but your point stands, that equivalent measures have not been attempted.)
Thing is the reason it hasn't been tried is that there's so little of the third-rail region where there's any point trying to exceed 100mph in the first place that nobody's interested in finding out how to do it.
The line, of course, still exists, but is now part of Metrolink, 750V DC overhead.The Lancashire & Yorkshire Railway had a third rail system out of Mancheter to Bury. It was a 1200v DC side contact rail system. The cross-section of the third rail was half that of the Southern's system. And it was encased, so it was extremely difficult to get electrocuted from it. Does anyone know what ampage was drawn by the units that used this system?
Unfortunately the line no longer exists
UK loading gauge is also unusually constrained low down below platform level, in areas also intruded by bridge beams and signals. The UK 3rd rail design had to be compact to avoid large-scale work to change that limited clearance. Many European and American railways were able to place their third rails further from the running rail because their loading gauge already allowed it. That then gave more space onboard in that area to design a more sophisticated yet robust arm to carry the contact shoe, more easily incorporating side or bottom contact if desired, pressure increase for better contact at speed etc.The situation itself is also more limiting compared with a pantograph. The inner side of the shoe is close to the bogie frame, the outer side is close to the gauge limit, and the top is constrained by the body above it. The whole thing is mounted to the axleboxes so is unsprung mass, and needs to carry much more current than an AC pantograph so must provide a larger cross-sectional area of conductor.
Research could be done clearly but the consensus seems to always have been that it was not worth the effort.These factors between them would place severe limits on any re-design of the shoegear for higher speeds. A pantograph has a large amount of movement space to play with, and the ability to mount various aerofoils, springs and dampers on the pan itself or on the roof around it, all of which can be used to improve dynamics.
