BRX
- Joined
- 20 Oct 2008
- Messages
- 4,496
Does anyone know whether the complete itinerary on a multileg DB advance ticket must be kept to, or is it only the IC/ICE parts, with some flexibility for the legs on S bahn or RB and so on?
Train Specific Travel
You may only travel on the long-distance trains (ICE, IC/EC) and on the days indicated on the ticket.
When starting or completing your journey on regional or local trains (RE, RB, IRE, S-Bahn), you are not restricted to specific trains or times. Your journey must be completed by 10 am the following day.
Thanks... Actually i have super sparpreis, looks like the conditions might be slightly different?
I did once mess up and book a Supersparpreis ticket for the wrong date. I noticed the mistake 5 minutes after making the booking. Online it said that it could not be changed, but I phoned their customer service, and kindly they cancelled the old ticket for me so I was able to rebook.
I guess it makes clear if you understand the code.If you look in the Route/Via field this makes clear (in coded form) what you must do on any DB ticket.
That's correct, unless the train you are supposed to take has a delay of more than 20', then you can just take the next one of your choice!In terms of booked trains it's fairly simple, if you see a train number in there (e.g. ICxxxx or ICExxxx) then you must use that train as booked.
