Dawlish sea wall collapse
455driver
10 May 2010
Have you been to Somerset recently :lol:
No, they have stopped running the trains for some reason! ;)
A signal lamp will be 12-20 feet off the ground (not sure what that distance is in Euros) so if that is under water there are some more serious problems to deal with than a poxy signal lamp. :lol:
Captain Chaos
31 Jan 2011
Indeed. Unless it's a GPL of course ;)
ModernRailways
21 Apr 2011
there is now a bbc article saying network rail are hopeful of beating new deadline.
Cannot put the quote in from phone, if someone could do that, or a mod edit my post i would appreciate that.
http://www.bbc.co.uk/news/uk-england-devon-26335125
dawlish railway reopening could beat target
network rail has told the government it hopes to reopen the railway line destroyed by storms at dawlish before its target of mid-april.
Rail minister steve hammond said he had been given a "commitment" that "if they can beat that date, they will".
The track connects cornwall and much of devon with the rest of the uk.
Transport secretary patrick mcloughlin will be questioned by mps on the transport select committee later over storm damage to places like dawlish.
'key priority'
network rail has said that it will reopen the track at dawlish, which runs along the seafront, by mid-april.
Business leaders in the south west have asked network rail and the government to consider opening an alternative route for the line that will run inland.
Mr hammond told bbc devon that it was a "key priority" to reinstate the railway.
"network rail had a good weekend last weekend and they have had some 20-hour days," he said.
"they are also looking at the long-term options for the railway.
"this is a truly exceptional event and we need to invest. Network rail is investing £35bn over the next three years.
12345
Goatboy
23 Jun 2011
Only of limited use whilst Bridgewater is shut, handy for London not so the North :(
Rich McLean
6 Feb 2012
Bridgwater reported to be re-opened by the 7th March. Water levels are now below the track bed, and work has started. New signalling has to go in, along with new track and ballast
There are however still some sections underwater, but should be clear next week
I've been watching the webcam for the last few days, and, at the risk of asking a silly question but can anyone explain what sequence this work is following? ie, what are they doing?
They seem to be building up in layers the same thickness as a course of the large blocks that appear to be 'permanent formwork'.
NR have put a load more photos on their webpage on the subject, I think they now possibly tell the story better than the webcam, the current picture at the top of the main page shows the basic setup, but scroll down and there's another link to a full set of Dawlish pics.
http://www.networkrail.co.uk/timetables-and-travel/storm-damage/
https://www.networkrail.co.uk/timetables-and-travel/storm-damage/dawlish/
sor
15 Nov 2013
Well considering that a lot of Conrwall is sitll mechanical, I'm just not sure why a railway fibre cable from Penzance to Totnes/Newton Abbot would have been installed. If it is indeed the case that communication between Exeter and the Newton Abbot and Totnes interlockings was via Met Office fibre cable to Penzance and then back to Newton Abbot via a railway fibre cable then I'm not if sure it would have been installed specifically for this type of event or if the installation would have been for another reason.
I am speculating here, but presumably Network Rail's FTN will be carrying far more than signalling related comms - stuff like the GSM-R mast backhaul, the railway phone network plus IP network connectivity. If any third parties have laid fibre along the track they'll want it up and running too. Seems like there's plenty of reason for redundant fibres to be run through to Cornwall, no matter how the signalling is performed.
petersi
24 Apr 2012
As a side note Cornwall is very important to the communication industry with several under sea cables landing there.
Sent from my Nexus 7 using Tapatalk
Oliver
17 Aug 2007
I can find references to the Dawlish webcam, but not the link. Help please...
Is the wall being replaced with a solid block of concrete or is that just me?
Based on the photos posted on the Network Rail page and watching the webcam, it seems that they are using pre-cast blocks and bonding them together with reinforced concrete that's poured on site. It's not a solid block though, you could see drainage pipes being cast into the poured concrete as it has been built up.
YorkshireBear
23 Jul 2010
They are progressing really really quickly. They are using fast curing concrete for sure as it is taking the load very quickly. They have had 7 days of good weather, now that is something they were not expecting and it really has let them work wonders. I mean look at the webcams! Look how sunny and calm it is down there! Mental. They are currently only not working at the tides highest two hours due to the wall being higher. Looks like the small breach near Dawlish Warren is being worked on just as quickly.
Overall much better progress than anyone expected and the other parts of the line are now being repaired alongside the main breach. The wall is now built up to almost its original height, and i would guess this reinforced concrete plug will be alot stronger when the next storm comes!
cambsy
6 Oct 2011
Has anyone got costs so far for Dawlish, and what total repair bill likely to be? What will the Dawlish section be like once opened? will it be concrete slab track or ballast etc?
John Webb
5 Jun 2010
St Albans
The "Dawlish Rail: 500m of wall still missing" is actually closer to Teignmouth on the section between Parsons tunnel and Sprey Point. Shame the video doesn't make that clear to help show just how complex NR's repair problems are!
According to someone in the know who posts on RMWeb, the concrete will be built up to formation level and then conventional ballast and track laid on top.
I would expect that they are just getting the job done and the cost won't be counted until it is finished.
Taunton
1 Aug 2013
I can assure you that the costs are being recorded very carefully by the contractor doing the job, that's the whole basis on which they, and in turn the lads on the ground, will get paid.
I really can't understand why slab track is not used here. How many times has the ballast been washed away over the years? I did hear that, this storm aside, there is a full time PW gang on the section just to maintain all the issues that arise on it.
YorkshireBear
23 Jul 2010
My own theory on slab track is the damage the sea water would do to the concrete pooling between rails... The current concrete being poured i would hope will have a membrane above it to stop sea water getting to it.
