Damaged Northern unit
Waddon
15 Sep 2009
Yesterday at Nottingham a Northern class 156 (i think) came in, I noticed that one of the cables between the two carriages was sheared off and hanging freely, I pointed it out to the guard who looked at it with the driver and phoned someone, but it obviously wasn't important as the train still left on time, with the cable still hanging...
I was wondering what the purpose of that cable is, if the train can operate freely without it? It looked like some kind of multi-core electrical cable. Any ideas?
YorkshireBear
23 Jul 2010
It could be anything, it actually may of had no use at all. Or just simply meants some lights or something didnt work.
it will of been a 158, dont get 156's over that side of pennines (cept up in newcastle)
WillPS
18 Nov 2008
Pretty sure I've seen it as a 156 before.
I've also seen 3-car 158s, 158+153, 155, 150...
EDIT: The more I think about it the more I doubt I have.
ChrisCooper
7 Sep 2005
Loughborough
Most DMUs will have 3 cables or pairs of cables between coaches. Multiple control, high voltage (usually 415v) and low voltage (24v). The only one that is essential under all circumstanes is multiple control, as without that the brakes wouldn't release. As long as both engines are running, the power cables don't really do anything. Still wouldn't want them dangling though, especially if likely to short out to anything (high voltage shorting out is not at all good, low voltage shorting to the running rails could false feed a track circuit causing a wrong side failure).
YorkshireBear
23 Jul 2010
Well i have seen other units 158's 150's plus the odd 153 added on but never seen a 155 or a 156 go further then sheffield
driver9000
13 Jan 2008
Second generation DMUs in the Northern fleet don't use a 415v supply. Between the vehicles there is a main air pipe and the 24v multiple control jumper, the individual vehicles supply their own heat and light supply. Some types (such as 150/2 and 158) have 2 jumper cables. Modern units running 3 phase will have extra jumpers.
Yew
12 Mar 2011
There is usually a 156 on the lincol Sheffield route. Or if it's not usually on. Then it's not uncommon to be on
37372
24 Jul 2006
Mexborough
Northern 156s never work any diagrams in South Yorkshire (with the exception of the Hope Valley stoppers), and rarely make appearances elsewhere in Yorkshire. They operate solely over the other side of the Pennines now. Last time I had a 156 in the region was Summer 2009.
Yew
12 Mar 2011
Hmmm it might have been a 153 then :/ Ive defiantely seen a 153 over there, and i was sure I saw a 156 some time, hwoever i could have just made up a coach from somwhere :/
37372
24 Jul 2006
Mexborough
When did Newcastle/Middlesbrough/Whitby end up on the other side of the Pennines to Yorkshire? :|;)
You get the idea, I was mainly thinking about Yorkshire! Some of the 156s go from Newcastle to Carlisle so I'm still partly right about them being in the west even if I did forget! :lol:
@Yew, it was probably a 150 or a 153 you saw, they're all Sprinters so you'd be forgiven for making that mistake.
