Daisy Nook Country Park railway
joebassman
5 Mar 2020
Stowupland
Does anyone know which railway ran through what is now Daisy Nook country park in Oldham? The line ran through what is now the car park by the cafe, here on Google maps, through a small tunnel and over horse shoe bridge. Google says it was the Ashton Under Lyne branch but when I have watched any videos of walks along that line they don't seem to go through that part of the park.
Sir Felix Pole
21 Oct 2012
Wilmslow
It is the Hollinwood branch of the Ashton Canal at Daisy Nook (closed in 1897) rather than a railway. There was tramway, however, to link up the canal to one of the collieries The Oldham to Ashton railway ran to the east of the main road - which you can mostly cycle / walk on although the viaduct at Park Bridge is missing.
Llanigraham
23 Mar 2013
Powys
Can I suggest that this site:
is very useful for finding if and what railways (and canals) were in a particular area?
billh
7 Jan 2015
There was a proposal in the mid 1970s to build a narrow gauge railway in the new Daisy Nook country park!
The idea was discussed and planned by the Medlock & Tame Valley Conservation Committee and got as far as acquiring two diesel locomotives and rolling stock from Oldham Corporation.
Nothing came of the plan due to the difficulties and expense of building and operating a passenger railway.
The Hollinwood Branch Canal closed in 1935 as a result of severe mining subsidence in the area. The Cinderland Bridge became too low to accomodate unloaded boats and it was impossible to maintain sufficient depth of water in the canal.
At closure, the 1812 beam pumping engine at the locks was stopped but remained reasonably intact into 1950s, then scrapped. Apart from some local coal traffic to mills in the Hollinwood area, a local canal carrying firm had a sand quarry on the banks of the Medlock, supplying a builders' merchants in Droylsden.
The course of the tramway from Woodbank Colliery to the canal can still be traced as a line of bushes and trees across fields to the north of the Fairbottom branch canal.
Mcr Warrior
8 Jan 2009
Just to confirm, was the tramway in question the one from Wood Park Colliery (Bardsley, Oldham) down to the (Daisy Bottom?) Canal Basin (which was connected to the Manchester and Ashton under Lyne canal) and was located maybe some 100ft below its starting point? If so, one source has the tramway as being some 1.42km in length and had been put in place by 1850. The colliery itself was closed by the N.C.B., around March 1955, apparently.
billh
7 Jan 2015
Sorry, yes Wood Park. I can just remember the (derelict?) pit head gear near the main Ashton-Oldham Road.Part of the tramway loading staithe is still visible on the canal.
