[/QUOTE]
To be fair, this was mostly back when I was still relatively new to cycling and had larger spherical objects when it came to risk-taking. You absolutely wouldn't find me on that road now, unless it was an emergency, as I last did that bit of the A40 when things were still quiet-ish in 2021.
There’s a cycling club out that way somewhere (Pontypool, I think) which uses the A40 from Abergavenny to Raglan for a regular time trial. Absolutely bonkers. They don’t half shift, but then so would I with 44 tonners heaving past every half Minute or so.
Bonkers is right. I wouldn't do it, mind you I wouldn't put myself in a time trial position either. It's not my idea of fun, and to be honest I'm not capable of it anyway.
That sort of thing breeds competitiveness, and I can't be dealing with that. I've spent much time getting such desires out of my system, I'm not so nice when I get all competitive after all. That and I don't really want the bragging rights if I do better than someone else anyway. Don't get me wrong, I love it when I get a new personal best, or when I get a top 10 performance on Strava, but the joy is short-lived.
I recently got a top 10 (just!) finish after absolutely flooring it on a local segment, destroying my previous best time by many seconds. I was still 25 seconds slower than someone else, but the way I look at it is that at least I did it safely which may not have applied to the other person. Considering it involves a pretty significant roundabout, doing it safely is key. Shortcutting it, and yes there are illegal ways of doing so, can result in quicker times but it's just not right. I'll stick to my 10th place time! Thing is, the joy I got from it didn't last long, it was nice while it lasted but I think I'm just not into competing with others now.
Which is one thing that puts me off cycling clubs, yes it's a good way to socialise but it's just not for me. Perhaps I'm just too out of shape and not willing enough to rip the body apart to join a cycling club!
@SCH117X makes a good point, knowing the local roads is important. The A49 in some places locally is absolutely horrendous, in others it's pretty reasonable for a seasoned cyclist. Similarly the A438 is full of places that drivers are stupid on, and it's not well looked after despite being one of the county's most important roads. So is the A417 but let's not discuss how horrid some of that is for surface quality!
Equally there's B roads that effectively get used as a race track by the less intelligent, and there's a road locally that saves distance and time but its surface is so bad that it's better to avoid it, go up the hill on the A4110 and turn off on the crossroads instead. There's some unclassified roads that are absolutely brilliant for cycling, with a good width and good visibility, although that's more because there's HGV use of them for quarries or similar.
It seems for every good road there's about a hundred bad ones! Some that used to be good, but needing some attention in 2020, are now getting dangerous even for car users in 2023. A local example is the unclassified road between Tillington and Credenhill, going east it's not too bad because the rough bit at Credenhill you're going slow over anyway, and the bit halfway along is rough going east but manageable. At the Tillington end, the surface is pretty decent.
Going west along said road, the bit in the middle has some serious big holes in it and I was fortunate the other day there was no traffic on the road so I could divert around them all. One of the holes in particular must be between 4 and 5 inches deep now, and said road is playing host to a half-marathon on Sunday! The rough bit at Credenhill on the road you have to know is there going west, as you've got a good bit of speed going on down the descent, I once suffered a major mechanical failure on that bit and the surface is getting worse.
So yes, local road knowledge is absolutely key!
