Loppylugs
Thank-you.....is right. All yours.
Loose wheelnut on a flashy porsche could result in the loss of the wheel here.
Scunthorpe? (anagram of "Thank-you.
Perfect explanation! Over to you.Scunthorpe? (anagram of "wheelnut porsche")
Thank you, that was a good one although I was worried my answer might get censored.Perfect explanation! Over to you.
That is correct, your turn...Tondu?
Check post #14 046. It isn’t a BR station, but is in Cumbria.Garsdale?
Dalegarth ?Check post #14 046. It isn’t a BR station, but is in Cumbria.
Thank-you, his fame is spreading, It sounds as if he is definitely from Wales.It certainly is. That’s why my thanks to Dale Cooper were part of the clue. Garth=station in Wales but Dalegarth is a station on the Ravenglass and Eskdale. All yours.
Not Welshpool.Welshpool.
I should have made it clearer that this was following on from the answer given in #14,053Thank-you, his fame is spreading, It sounds as if he is definitely from Wales.
Not Valley.Valley?
All I can think of is Denby Dale which is what I thought was the answer to the previous clue.Last clue: Welsh town is in North Wales, the station is in West Yorkshire.
That's the one. Congratulations, you are now famous. (Please note I didn't go for Birkdale).All I can think of is Denby Dale which is what I thought was the answer to the previous clue.
Thank you, Commondale would be the most appropriate.That's the one. Congratulations, you are now famous. (Please note I didn't go for Birkdale).
Next clue:
Five hundred Romans built this station.
Dormans is correct, open floor...Dormans ?
Open floor if correct.
Tonbridge?If nobody else is going to do one, I’ll jump in. I promise there are no references to @DaleCooper in this one.
C
In Kent
I think this will either be solved in five minutes or maybe need another clue. It is in Kent though.
Stone Crossing?If nobody else is going to do one, I’ll jump in. I promise there are no references to @DaleCooper in this one.
C
In Kent
