Croydon - Gomshall - Holmwood - Croydon
themeone
17 Feb 2011
On Sat 1 Feb I need to travel from Croydon to Gomshall, then later the same day return to Croydon from Holmwood.
Each ticket is £7.50 single, but is there any cheaper return ticket I could get which would cover both journeys?
bb21
Emeritus Moderator
4 Feb 2010
Can't check at the moment but I suspect that the Gomshall ticket should be valid via Dorking, leaving you only needing a Holmwood - Dorking single. Someone should be able to confirm shortly.
Romilly
5 Nov 2013
It is as bb21 says: an £8.10 Croydon-Gomshall offpeak day return, plus a £3.30 Holmwood-Dorking single, with a short walk from Dorking station to Dorking (Deepdene) station to pick up the train back to Redhill for Croydon.
bb21
Emeritus Moderator
4 Feb 2010
Alternatively without a change at Dorking, you can go via Sutton to West Croydon.
30907
The online planner says Holmwood-Dorking will have trains on Saturday - is that really the case, I wonder?
James Wake
30 Aug 2013
The regular 93 service costs £3.40 single, so the same as the train pretty much, just 10p in it. Depends when you get to the station what is due.
