VT 390
- Joined
- 7 Dec 2018
- Messages
- 1,733
To give Thamesmead a rail service Crossrail should provide the services but from the north.
This would be possible as the Overground extension to Barking Riverside has been proposed to go through a tunnel to Thamesmead and as the overground would provide just 4tph here it would not be worth the cost, but if Crossrail were to also use the tunnel then it would give Thamesmead direct services to central London. The route could use all existing lines from Stratford by leaving the Crossrail line to Shenfield at Forest Gate Junction stop at Woodgrange Park then use the same platforms at the Overground at Barking then follow the Overground extension to Thamesmead.
If this service ran about every 15 minutes then combined with the Overground a service every 7-8 minutes would run from Thamesmead to Barking.
If this frequency would affect Shenfield or Abbey Wood services then it should be possible to run these services along the slow lines to Liverpool Street (high level), as Shenfield services would be diverted to the Crossrail core, this would still give Thamesmead a direct service to central London.
