Crossrail - Construction updates and progress towards opening (now expected 24 May 2022)
22 Jun 2013
I'm flying from Heathrow tomorrow and no route finder, including TfL, City Mapper & Moovit, includes TfL Rail from Paddington, instead I'm directed to the very pricey HX! Anyone know why TfL Rail is omitted?
Adoarable
24 Jul 2020
Probably because those route finders either don't calculate fares or don't use it when generating routes. In which case Heathrow Express will always be prioritised over TfL Rail because it's quicker and no less convenient (until Elizabeth Line through running happens this/next year).
In the TfL journey planner, click 'Edit preferences' then uncheck 'National Rail'. You should be able to see TfL Rail options then.
DynamicSpirit
12 Apr 2012
SE London
What an utter monstrosity of a map. There's no way Croydon Tramlink should be on it - it's a tram, not a tube or a train. The selective inclusion of some rail lines but not others has little rationale, and makes it look like you'd need to go on a very long tube journey to get from Waterloo to Vauxhall, Clapham Junction, or Wimbledon. And then you have the absurdity of showing the North Kent line, but missing out Woolwich Dockyard, Belvedere and Erith stations (presumably because Thameslink trains don't stop there).
And I know geography gets skewed on the diagrammatic maps, but showing it as if Abbey Wood is within walking distance of Shortlands???? And the GWR lines turning North after Hayes and Harlington to end at Reading, which is just a short distance away from Uxbridge? Really????
It was originally designed to show TfL services but became messier when Thameslink was added back in. Allegedly that was only for the duration of the Bank upgrade works, but it looks like it's stayed. Personally I'd say the only two maps worth having are a central London map, made large enough for the various interchanges etc. to be clearly visible, and a Rail & Tube map showing everything. Unfortunately the latter isn't ideal either, being quite ambiguous about the fact that contactless is now valid to all of the Thames Valley branches, but not beyond Reading.
Horizon22
Jobs & Careers
8 Sep 2019
I’d say the latter point isn’t an issue considering all those branches are “within” Reading.
Perhaps we're talking at cross-purposes, as I was referring to the Rail & Tube map on this point.
The Thames Valley branches' stations aren't listed on the map and yet contactless is valid there. The arrow just says "towards Windsor & Eton Central" for example:
So how is anyone supposed to know that it's OK to use contactless to Windsor, but not Didcot? It's very ambiguous. The arrow towards Newbury and Didcot doesn't even go outside of the map, as most of the others do.
Peter Sarf
Croydon
I would favour keeping Croydon Tramlink on the map as it is quite a significant TfL service. It runs for quite a distance from Croydon to Wimbledon and the other lines also mainly link into rail lines. So it forms an important link between railway lines across South London. It is a lot more than a set of bus routes, sits better with rail than bus and it is largely off road.
But yes, the presentation of Crossrail is rather poor.
Egg Centric
6 Oct 2018
Land of the Prince Bishops
Is there any chance the barriers quietly open on Monday 23rd?
Precisely what I've been wondering.
I'm down for the Sunderland game on Saturday but then the next week working at my company's HQ in Watford with basically my main "out of hours" objective to ride this thing ASAP - the launch on a Tuesday of all days was very suspicious. Will be keeping an eye out. Would like the input of e.g. @geofftech on things like this...
AlbertBeale
16 Jun 2019
I think there's a case for something pared down to be more like the old tube map, for simplicity, as well as an "all London rail" map.
For the former...
It seems to me that both the Thameslink core and the Crossrail core (plus I suppose up to around the Greater London boundary - except Thameslink in the south after it divides too many ways) perform an Underground-like function (as per RER in Paris), with trains every few minutes and going through the centre of London, and it makes sense to include them on the Underground map, though as a separate "mode". Also, DLR - and perhaps Croydon Trams - are tube-like enough to be on the Underground map. I used to think that the Overground made sense in this context too - at least when it was mostly the original routes looping through the inner suburbs - as one more mode. But with some radial NR routes - seemingly arbitrarily - being re-designated as Overground, they're cluttering up the tube map too much now.
ijmad
7 Jan 2016
It seems like originally they expected to open on Tuesday 17th, after the Queen's visit and official ribbon cutting on Monday 16th.
The opening got pushed back a week but they couldn't push back the Queen...
Basil Jet
23 Apr 2022
When someone is in their 90s, delaying them a week isn't advisable even if they're okay with it.
jumble
1 Jul 2011
+ Oyster Ticket Stops in Zone 1, TfL Visitor Centres, at Heathrow stations, and Elizabeth line stations from Paddington - Abbey Wood, Paddington - West Drayton and Liverpool Street - Brentwood.
Thanks
I got 2 yesterday from the LUL machines at Liverpool St
( A kind CSA was extremely helpful in telling me which machines had them in and which did not)
Adoarable
24 Jul 2020
The Rail&Tube map has been updated too.
Highlights:
- On this map (as opposed to the Tube map), Elizabeth is solid purple. Which is great except it's quite similar in colour to the Piccadilly line, which it crosses at a skew angle.
- The interchange at Moorgate has been omitted. Presumably this helps with simplicity but it does hide the connection for Northern and Northern City Line passengers.
Intro298
21 Jul 2021
Malmö, Sweden
I will certainly be keeping my eye out on Monday, especially considering the early reopening of the Bank branch.
DynamicSpirit
12 Apr 2012
SE London
That would be a good argument for including Croydon Tramlink in the Rail-&-Tube map: It makes sense there as a link that connects quite a few of the rail lines in South London.
But the tube map doesn't show (most) rail lines in South London, so there's no point showing something that links those unshown lines.
To my mind, the fact that it's a TfL service is irrelevant. The tube map is branded as, and is (for the most part) a tube map, not a map of TfL services. It doesn't, for example, include TfL bus services.
The real problem with including Tramlink on the tube map is that the tube lines are really focused on central London - so the main utility of a tube map is in showing you how to get around zone 1 (and also now arguably the DLR area). If you're travelling in outer London - especially in South London, then for the most part, you need the rail & tube map - the tube map by itself is almost useless unless you happen to be travelling between destinations along the same tube line. But Tramlink doesn't go anywhere near central London - in fact, its only direct interchange with the tube at all is at Wimbledon. So it's mostly irrelevant to the kinds of journeys for which people will need the tube map. Worse - including it forces a distortion beyond belief of the South London geography on the tube map in order to fit it in. And including it but not the rail lines gives a completely misleading impression of what transport options are available in the Croydon area.
There's perhaps some case for showing the small section between Wimbledon wand Morden Road - just because of the linkage between the District and Northern lines in the area. But including the rest of it on the tube map seems to me to be a political decision that takes no account of the needs of tube map users. Croydon Tramlink should be on the rail-&-tube map, not the tube map.
BobSmith833
8 Nov 2010
I have been saying this for some time. It's probably time to retire the tube-only map altogether, it's not really useful in modern London, in which it's just as easy to travel around by train than by tube and often far more sensible than the options shown on the tube map (e.g. Queen's Road Peckham to London Bridge, Vauxhall to Waterloo etc.). Just give people all the options and let them make their own decisions, rather than arbitrarily including TfL and Thameslink but nothing else.
So, regarding the launch of the Liz line... there appear to be two outstanding questions:
1. Will it have a soft opening on the 23rd? Probability is perhaps that it won't, but seems nobody knows for sure.
2. Should enthusiasts go to Paddington or to Abbey Wood if they want to "ride the first train"? According to Geoff Marshall, the first train will actually depart Abbey Wood, by a few minutes, but then again the Paddington one will be the first to enter the new core tunnels. I suspect most people are planning to start at Paddington, but interested to hear what you guys here are actually planning to do...
DynamicSpirit
12 Apr 2012
SE London
I actually live in Abbey Wood, so the question of where I start is kinda make up for me :)
Personally I'm not that interested in getting on the the very first train. I'd quite like to take a ride at some point on Tuesday to see what it's like, but I'll probably wait till a bit later in the day - when there's actually something open to do in central London once I get there!
Horizon22
Jobs & Careers
8 Sep 2019
With Thameslink it would have made more sense if there were just arrows at certain points (maybe beyond Elephant & Castle, London Bridge, West Hampstead & Finsbury Park) but instead the line has shown every branch south of the river which really has added to the mess. I think most people were surprised to see everything on there when the original intention was to show that it is indeed quicker for a Z1 journey London Bridge to St Pancras rather than Northern line and fills a good tube gap.
I take that point. Perhaps the blue line should have ended before that curve towards Newbury & Didcot.
BobSmith833
8 Nov 2010
The same logic applies to the Waterloo to Vauxhall link on SWR though, that's still a zone 1 journey and incredibly frequent. The whole thing is too messy anyway, and attempting to predict what might be useful to customers is a fool's game.
Horizon22
Jobs & Careers
8 Sep 2019
Yes, and also for Southeastern from London Bridge to Charing Cross & Cannon St. It is I agree odd to add one and not another, but the thinking was generally it was to help relieve loadings for Bank blockade. Probably TfL need to have some firm words with GTR and try and 'reclaim' their map. But the whole thing feels like it needs a rethink because otherwise there's so much information, it actual devalues any useful information for the core base of people using it.
I would add though that this conversation has deviated a fair bit from Crossrail / Elizabeth Line opening & we best not get too far off-topic!
Mag_seven
1 Sep 2014
here to eternity
If you join the Abbey Wood starter you of course will be on the first train to actually enter the core section from outside it, whereas if you join the Paddington starter you are already in the core tunnels.
ijmad
7 Jan 2016
Abbey Wood is a core station! But yes if you want to be the first paying passengers in the actual tunnels then pick Paddington.
ijmad
7 Jan 2016
Isn't the core considered to be Paddington to Whitechapel?
Crossrail Central Operating Section (CCOS) which is the 'core' makes up most of the route to be used by Elizabeth line services that is not part of the Network Rail network.
It comprises Westbourne Park Junction to Abbey Wood and also the Shenfield branch up to Pudding Mill Lane junction immediately west of Stratford.
Mojo
7 Aug 2005
FWIW the Trams are not a new addition - they have been on it for a few years, ever since the Trams were included on the Service Update boards at stations and online.
The Northern line is actually quicker from Kings Cross St Pancras to London Bridge than TLRailUK, with most journeys timetabled for between 10-11 Mins, vs TLRailUK being 14/15 Mins.
When Thameslink was put on the map in January 2021, the accompanying media release said it was temporary, to support social distancing and also due to engineering works associated with the Bank upgrade. "In light of the continuing coronavirus pandemic, and next year’s Northern line closures required to complete the Bank Upgrade works, Thameslink services have been temporarily included on the Tube map to help customers move around the city. This has been a complicated addition to make to the map, but one that we feel will benefit Londoners as part of our work to promote safe, clean and reliable public transport use across the city" is a quote from Julie Dixon at TfL issued at the time.
I have not used the term "Core" be used within the context of Crossrail, I believe that is the term used for Thameslink. The Cos (Central Operating Section) is for Crossrail, this goes from Westbourne Park Junction (including the reversing sidings) to Abbey Wood (including Plumstead sidings), and Pudding Mill Lane Junction. This denotes TfL (RfL(I)) as the infrastructure manager as opposed to Network Rail: https://tfl.gov.uk/corporate/publications-and-reports/crossrail-central-operating-section
mattdickinson
14 Nov 2010
Uxbridge
With the extension of contactless to much of the South East due soon, the London map won't be suitable for indicating the limits of contactless acceptance. There's probably a case for removing the contactless only extensions to Luton Airport and Welwyn from the London map.
It's currently the only resource that indicates where contactless is valid. I agree though, at some point a different map will be needed.
subk2010
18 Feb 2021
TfL Go APP got an update. The icon becomes purple to welcome the opening of Elizabeth Line. Hope they will keep it purple as it’s sometimes confusing to distinguish the TfL App and RATP App.
