Crossrail - Construction updates and progress towards opening (now expected 24 May 2022)
stuu
2 Sep 2011
Putting Shenfield on there seems premature. I know obviously people can change at Liverpool St, but that applies to everywhere that can be reached via a change... unless they are planning on opening to Shenfield much sooner than assumed?
JN114
28 Jun 2005
The sign is (theoretically) going to be there forever; at some point in the not-too distant future there will be direct trains from Paddington LL to Shenfield.
It makes little sense to make a permanent sign now that doesn’t mention Shenfield, and in 6-9 months when through running starts replace the sign again.
tomuk
15 May 2010
I assume the other entrance at Paddington is signed for Elizabeth line to Reading?
The different signing because it is a different mode does seem to be inconsistent.
The other thing that I don't get is the stations. On previous lines and other systems eg New York Subway each station had some unique features i.e. tile patterns/colours at platform level to allow you to id the station easily.
On the Elizabeth line of the Crossrail mode most of the station platforms are nearly identical in the 2001 A Space Odyssey/Space: 1999 style.
Nottingham59
10 Dec 2019
Can people take (unfolded) bicycles on the Elizabeth line?
The TfL website says the new trains have: "Four dedicated wheelchair spaces as well as separate multi-use spaces which can also be used for buggies, luggage and bicycles"
The website says for bikes on TfL Rail:
"Allowed anytime on weekends and bank holidays"
"You can also take non-folded cycles from Monday to Friday, on trains: ....
Leaving London Paddington before 16:30 and after 19:00"
But I don't think they mean Eastbound....
SynthD
4 Apr 2020
Are bikes forbidden on deep tubes because it’s deep or small? We will learn which it is with this decision. I expect Paddington to Custom House and Stratford could the limit of the ban.
Elizabeth line trains to Reading still go from the main shed in the next phase. That entrance wording will have to be altered when the services are linked at Paddington.
tomuk
15 May 2010
But the sign says Shenfield. Trains won't be going to Shenfield only Abbey Wood to begin with.
stuu
2 Sep 2011
Why is it? Underground stations don't. Surely its just to tell people not to use it to go towards Heathrow?
matt_world2004
5 Nov 2014
Not really.
TFL use colours on station entrances.
That Paddington picture looks like the crossrail entrance and the Farringdon one the ThamesLink entrance.
Blue is underground.
If blue is for underground and farringdon is coloured blue for the underground. Why is Ealing Broadway purple?
Why is abbey wood blue when no underground services serve there
BahrainLad
3 Aug 2015
Farringdon is also odd because once you get past Thameslink on the sign over the entrance, all the internal wayfinding switches back to “National Rail“, immediately if you look closely at the picture above.
Malaxa
9 Mar 2022
Crossrail Information Paper E2 relating to cycle carriage suggests that bicycles would be banned at all times between Abbey Wood and Acton Main Line - i.e. the [deep] tunnel sections.
Of course cycle carriage outside peak hours is possible on the DLR beneath the Thames in, er, deep tunnels.
It seems to me that the probable banning of cycles on the Elizabeth may relate to access to the platforms. But again, this is no problem on the DLR, and indeed wheelchairs and buggies will be allowed, I suspect, on all sections of the Elizabeth.
I suspect the carriage of unfolded cycles in the central area would generally be between stations outside the central tunnel area. One does wonder how crowded the trains will be in that section.
matt_world2004
5 Nov 2014
I find that strange considering carriages are permitted on most of the sub surface lines off peak and crossrail is similar dimensions
tomuk
15 May 2010
I suppose the issue is if you take your bike and get off at Tottenham Court Road, for example and drag you bike through the connecting passageways onto the deep level tube lines.
londontransit
26 May 2021
Don't think they'll say 'to Reading' because people will already (in theory) be on those very trains heading for Reading. Similarly for Heathrow.
The reason the signage is done like this (eg Shenfield/Abbey Wood) is for those passengers who come off the main line trains at Paddington and will be looking for the trains heading in those directions.
That new signage at Paddington has been up a few weeks.
By the way the Crossrail lifts at Paddington have just been unfenced (eg there's no fencing across the entrances anymore) thus one can now get a better view of the main Crossrail ticket hall concourse and the ticket barriers from the bridge leading to the lifts.
And the good news (or is that bad?) Opening's definitely in June.
James H
25 Jun 2014
I think the point is that if you are at Paddington and want to travel to Reading, the Elizabeth line might not be your best option
stuu
2 Sep 2011
It is down to who runs the station - Ealing Broadway is an NR station which is now managed by Crossrail, hence purple
Abbey Wood is a cock up (or Southeastern, but their blue is darker)
londontransit
26 May 2021
LOL!
What about people entering Crossrail at that entrance from the local streets?
I had thought about that but in retrospect most will probably be wanting to head towards Central London or further eastwards.
Malaxa
9 Mar 2022
There's a distinction between the deep lines and the District/Met/Hammersmith & City lines. Cycle carriage is banned between Leyton and Stratford owing to a short section of tunnel between two adjacent surface stations. Cycles are also banned south of Drayton Park on Moorgate services at all times.
I forgot that you can also take cycles off-peak on Overground services which also uses a deep tunnel beneath the Thames.
Peter Sarf
Croydon
I think it’s a mistake not putting ‘Station’ as a suffix on the Elizabeth line stations. Yes on the Paddington example there’s a roundel tacked in the side but approaching down those stairs on the left it’s not exactly clear what it is.
The Farringdon example looks much better and I presume because it’s a combined station it gets the Underground look.
I suppose maybe the Paddington photogtraph is of the entrance to the Elizabeth line Eastbound platform only ?. Whereas the Farringdon photograph is of the (or one of the) entrance to the whole station.
t_packer
10 Dec 2017
That entrance leads down to both platforms. My best guess is that the “Abbey Wood/Shenfield” sticker will be gone once through-running begins, or added to include Heathrow and Reading. It likely says Shenfield now because it is still a destination on the Elizabeth Line which can be reached from Paddington, changing at Liverpool Street for now. It’s probably (for now) to distinguish those trains down on the Elizabeth Line platforms with those bound for Heathrow and Reading from the mainline station.
Roast Veg
28 Oct 2016
Have you been on it yet? I have, and what you say couldn't be much further from the truth. Every single station has a number of artistic design features that incorporate something of the local area.
matt_world2004
5 Nov 2014
But for hanwell , West Ealing , Acton Mainline ,Southall it very probably is
Abbey wood is run by MTR like ealing Broadway. Tottenham Court road is run by London underground and that has a purple sign
tomuk
15 May 2010
Upstairs in the ticket halls they do but the platforms are all the same for the central stations.
