CrossCountry Saturday HST
WestCoast
19 Jun 2010
South Yorkshire
I'm looking to buy an advance fare for a Leeds - Birmingham journey on a Saturday in March.
I've found that this service which leaves Leeds at 11:11 is supposedly booked for a HST on Saturdays:
1V54 0700 Glasgow Central-Plymouth
However, when I look at the seating map where you can select your seats on XCs website it shows a Voyager?
Does anyone know whether it will be a Voyager or a HST?
As the GW line is closed between Taunton and Exeter every weekend in March, the normal diagramming won't apply and HSTs will be used differently. I suspect the HSTs will run south later, if they run at all, to pick up their normal northbound working at Taunton, or wherever.
louis97
14 May 2008
Derby
The 0700 Glasgow - Plymouth is normally a HST on Saturdays in order to operate 1E73 1723 Plymouth to Leeds, but due to engineering works as already stated above, it is not a HST.
Instead of this 1V60 0820 Aberdeen - Taunton is booked a HST, this enables it to work the return service that 1V54 would normally run from Taunton (1E73 1854 Taunton - Leeds).
Arriva158
19 Dec 2009
Gobowen
A saturday service which is 90% guaranteed a HST even if engineering works are on is the 1211 (iirc) off Leeds to Penzance, much to my suprise and delight, happened a few weekends in a row when taunton diversions were on last year i think or it was the cheltenham diversions via Worcester!
The set goes down and forms a late night penzance - plymouth 2C51?... then back to Penzance early morning then a Penzance - Leeds on the sunday ready for an early morning start on Monday to Plymouth!<D
WestCoast
19 Jun 2010
South Yorkshire
I've checked the crosscountry seatmap (ever so useful too :D) for the 14:11 off Leeds and this appears to be booked a HST.
However the 11:11 and 12:11 appear to be voyagers for the Saturdays in March.
