Our new ticketing site is now live! Using either this or the original site (both powered by TrainSplit) helps support the running of the forum with every ticket purchase! Find out more and ask any questions/give us feedback in this thread!
Replace the £28,464 with £32,717 and the £37,713 with £43,347. Only after signing a route and a core traction do you move to the first year qualified driver Salary.
Thanks. So as I thought they go onto more than this fairly rapidly, in which case surprising the advert doesn’t mention that, and the eventual amount you progress to, rather than an amount you may be on for 8-12 weeks. A casual reader might think that’s what fully qualified XC drivers get paid! Another misleadingly/badly drafted advert.
Is anyone able to confirm the current 1st year and beyond rates?
In attempt to trial a move towards TOC driver recruitment being discussed in one thread per company, I’ve merged today’s vacancy into the existing thread from a previous campaign (and changed the thread title to reflect this.) This approach is instead of having a different thread for each vacancy/campaign.
I hope the experience of existing candidates can help those new to the process, etc
With XC using SHL, am I correct in presuming these are different to OPC results so would need to resit these or are OPC results / lives taken into consideration/ affected?
SHL? I’m at the end of the process with XC and not come across SHL before.
If it’s a psychometric testing company…the tests are all the same and ‘lives lost’ all count together as the tests are set by the British Rail Safety Board. If you’ve already passed them with OPC you don’t do them again.
Applied for Manchester. First time applying with XC. I understand the phycometrics need to be passed to national standard and not enhanced. What are the actual phychometrics you sit with XC? Obviously dot test, MMI etc. but what are the other ones if anyone happens to know? Cheers
1st test centre visit:
1. Group Bourdon (dots)
2. Comprehension test - read info, retain it then complete questions on the text.
3. Reasoning - a set of rules and apply them to the task. Aka cables and dials.
4. Listening to and counting beeps whilst looking for info in a directory. Aka test of everyday attention.
2nd test centre visit:
1. 30 mins on the computer watching the square flash - vigilance test.
2. Picture memory test on computer.
3. 2 hand control test on computer.
4. MMI
4. MMI
Is the picture memory the one where it flashes up for a fraction of a second and you have to say what you saw? Eg.
traffic light, green car, zebra crossing.
Thanks for the help. How did you find this one? I’ve been practicing psychometrics since they announced the age limit lowering and it’s the only one I’m a bit so so with. Just looking for tips to improve!
I’m 18 (been on the railway since I was 16) and have applied and haven’t been met with any push back.
I personally found the practice tests online harder than the actual test. Can't really recommend anything other than practice. Personally I found the interview portion the hardest.
I'm happy to share my experience on the picture test. I needed two attempts. It was the only psychometric test I failed. Did plenty of reading around the topic and saw the advice over and over about never marking things you think you saw. I took that advice and to be honest I think it made me too cautious.
Like everyone who fails something in this game, I didn't get any feedback but I did buy some software which mimicked the test after I failed and turns out I was pretty bad at it.
Lots and lots of practice and 8 months later, I went again and got through. So I think the advice to not select things you think you saw is sound but ultimately I believe the answer will be wrong if you miss stuff as well.
Like the dot test, there is ways to practice this and parting company with £30-40 for the software is worth it. Some people will naturally be good at it, I was not and had to work at it.
In hindsight should I have practiced harder to avoid the first fail? Yes. Should I have got the software beforehand? Yes - but easy to say now. Everyone is different.
Hi all, first time on this thread. I just wanted to get some info if possible. I’ve been in the talent bank with Avanti for 2 years now so have decided to apply for Manchester with XC.
Being that I have passed all psychometrics to enhanced standard, does that mean I would only have to pass an interview with XC if my application gets shortlisted?
If with XC you'll need to do the mmi and then dmi as they don't use CBI. Honestly the CBI and MMi thing needs to be standardised into one but thats a topic for another day.
Thanks, I did the CBI. Does the MMI differ much from the one I did? And the DMI I can’t remember. Is that the telephone call one they do as part of it?
No clue about xc process im sure thread earlier on eill mention but as for mmi its similar to cbi yes, just note that any result, overrides your CBI. If you pass, then CBI is replaced with MMI and no longer valid till redone. Vice versa.
Thank you. Although I am told that this is common misconception! I have spoken to someone who was in the talent bank for 2 different Tocs, one using and MMI and one using a CBI, and he was made an offer from both at different points. I thought it was interesting because I was always told otherwise
I would say that it would be worth going through the process and if you get that far you could then make a decision. If it does overwrite your CBI what do you think you would do?
I think I would still go for it because I think my current occupation will always provide me with good answers for any of the interviews.
Plus in all honesty, I don’t think Avanti will ever call me up. I hear they are well staffed for the Manchester depot and I really don’t want my enhanced passes for the psychometrics to go to waste. I’d be happy to wait until the very end if it meant being offered a job with them, but I’m sceptical that they will
We have had a number of issues with members trying to set up duplicate accounts in this forum.
Please note that we only allow one account per person, but if you find yourself in a situation in which you'd like a separate identity for this section then please contact us directly and explain your reasoning or concerns rather than setting up a separate new account.
We are aware of an issue with emails from the Forum to Microsoft-based email accounts (hotmail/outlook/live.com email addresses). This is being looked into currently, thanks for your patience meanwhile.
