The only route which requires a reversal is SE-NE, otherwise they can just go round the Camp Hill. Obviously the addition of stations and extra local traffic on the Camp Hill may prevent that longer term, and it's entirely possible thatOne thing I do hope is that the stuff from the South Coast (the hourly Bournemouth and the hourly Soton / Reading) simply cut across Brum towards Wolverhampton without needing to reverse etc; and that stuff from the South West goes towards Derby. That way, all traffic from the SW-NE and vice-versa can just do a simple driver change and load up before keeping going.
Only if you assume that nobody is trying to go SE-NE or SW-NW since they would all have to change at Birmingham m SW-NW is a change I currently make at WolverhamptonBy encouraging a half-hourly Reading (Bournemouth, Southampton) to Manchester, you can encourage further the ‘out of Birmingham’ changes at Wolverhampton onto Liverpool trains. It also creates peak capacity on the Birmingham - Liverpool trains as far as Wolves as people naturally gravitate onto faster trains.
A half-hourly Bristol (Exeter, Paignton, Plymouth) to North East also makes it more plausible to encourage out-of-Birmingham changes at Derby onto Nottingham trains. People changing at Birmingham therefore becomes a lot more limited.
Que? (to quote Manuel)Having the reversers allows one to change branch not at New Street - something they even had posters encouraging.
While for some journeys changing trains at Birmingham New Street is unavoidable, for others there are easier, more convenient station options. These are Wolverhampton, Cheltenham Spa, Derby and Leamington Spa. In some cases you will be able to change trains without having to switch platforms, making your journey even smoother
I was thinking more along the lines of this webpage, rather than that you can travel direct Oxford-Sheffield, though that also applies.
https://www.crosscountrytrains.co.u...nections/making-your-train-connections-easier
There's also a diagram on that page:
I'd be happy with that, make XC a much more simple service operationally, split up the mess of services into two distinct ones, would make it easier to amend them (since, at the moment, everything is tied up together) - e.g. you could run the Derby - Cheltenham service ten minutes later or earlier if that meant better paths, without having to worry about the Wolverhampton - Oxford service... you could give the Wolverhampton - Oxford services to the West Coast franchise (or the Derby - Cheltenham services to the East Midlands franchise)... you could get better bang for your buck with bi-modes on the Wolverhampton - Oxford services (since that runs under the wires for a much longer proportion than a Manchester - Plymouth service would)... you could cope with disruption much better (e.g. engineering works only affecting one half of things)... you could make it a much simpler better franchise (but the howls from people doing long distance journeys once a year will drown out the people who would benefit from things).
Instead, we are stuck with an operationally messy franchise where trains are stuck waiting at New Street for a path in a different direction because everything is tied together. Not that long ago (under Virgin) when Manchester had no service to Bristol/ Exeter/ Plymouth - when three quarters of "South West" services were Newcastle ones and the other was a bi-hourly one up the WCML through Wigan.
Realistically it’s not a Wolves - Oxford or a Derby - Cheltenham; it would be hourly each for:
- Plymouth to Edinburgh
- Cardiff/Bristol to Nottingham
- Cardiff/Bristol to Newcastle
- Bournemouth to Manchester
- Southampton/Reading to Manchester
- Birmingham to Stansted
If we assume an hourly Birmingham - Nottingham with stops at places such as Wilnecote and Willington will go over to West Midlands Trains
It was that service pattern (prior to the simpler post-2008 timetable) which most necessitated encouraging people to consider changing at stations other than Birmingham New Street.
One of the problems of just running NE-SW and NW-SC is that it requires a lot more churn of passengers changing between the two routes at New Street.
What exactly necessitates this service being transferred to West Midlands Trains?
As I think many of us have understood from the now defunct (?) Cross Country franchise prospectus, there are some routes that the DfT have elected should no longer be under Intercity Cross Country franchise control. Two of them are the hourly Birmingham - Nottingham ‘stopper’ and the hourly Birmingham - Leicester ‘stopper’. Given West Midlands Trains already manage some of the stations (despite no WMT trains calling) and assuming this will bring about a step change in rolling stock strategy, it seems most likely these two services will transfer to WMT.
That way, the Nottingham ‘stopper’ (Wilnecote, Tamworth, Burton, Willington, Derby, Long Eaton, Attenborough, Beeston, Nottingham) and the Leicester ‘stopper’ (Water Orton, Coleshill, Nuneaton, Hinckley, Narborough, South Wigston, Leicester) transfer in to WMT allowing the Cardiff - Nottingham and Birmingham - Stansted to ‘properly’ accelerate only calling at the bigger stations (Tamworth, Burton, Coleshill, Nuneaton).
Could you extend the Stansted Airport service to somewhere else and run it as a proper InterCity service.
Unlikely. There isn’t a ‘corresponding end’ at Birmingham to run through. This service can important somewhat significant delays as well so to terminate it at Brum and give it a 40-odd minute dwell and use the opposite end of the platform (e.g. 10B) for the Hereford or Worcester service would be a sensible use of capacity.
Sounds like a solution looking for a problem, you can't timetable it anyway.A simple extension for the Stansteds would be to Wolverhampton turning round in platform 2 which reduces conflicts. Stops at Sandwell and Dudley and Smethick (for the Kidderminster line) only. Of course this does then add to the turnround time, but does alow interchange away from New St. But does this then risk delays on that bit of line?
Stockport to Piccadilly is your issue.
It wouldn't, but unless you can get the LNWR to slot into that path south of Stoke then its a brand new path.Can you explain more please? I don't think replacing one of Northern stoppers with a LNWR stopper would pose a problem?
Indeed but a combination of poor timekeeping and lack of DMUs meant the service was often split at New St with a class 310 working the electrified section.At one time, of course, it ran to Liverpool.
