- Joined
- 15 Apr 2008
- Messages
- 19,717
Would still put money on Crewe getting the station....
Manchester Airport High Speed station will be connected to the tram system and thus have superior access to significant parts of Manchester than the city centre station.
If the entire Airport loop gets built you could even offer free transfers between the main and high speed stations.
I wonder about the route. The one to the airport, being built, is a 'round the houses' affair that I would imagine is more useful to airport workers living in the suburbs, a bit like Heathrow Connect or the Piccadilly tube line.I wonder what type of trams will be running on the Manchester Metrolink system in those far-distant future days when the HS2 project is operational in the Manchester area.
Well Paul, you can read the report as well as anyone. It airily infers that the line to Manchester will be converted to GC+ gauge, and become the main route northwards, without defining any solutions to such problems or where the branch occurs, IINM. The very thing that HS2 sets out not to do! All seems a bit half-baked and naive to me.
BB; I feel for you. How do you do summat about it?
Crewe is a dead cert. It has six radial routes presently and yet HS2 Captiives won't stop there! Seems like Stoke councillors and HS2 Ltd have something in common.
Think back why it was built in the middle of fields originally.
In answer to the first point, revolution tomorrow!
Crewe is the obvious location for a north midlands / south north west regional station. Perhaps even as an alternative to Manchester Airport?
In my opinion it should have HS2 served platforms rather than being a branch off the new line - unless there is an ability to weave onto HS2 south and north of the present station without too much time penalty. Otherwise, if HS2 gets extended north to Scotland in some form, the whole region loses out because, as per the current WCML timetable, expresses to Scotland won't stop at Crewe.
Ideally, HS2 would serve London, then Crewe, then Preston, then Glasgow. Picks up regional feeder services at those interchange points or classic compatible services join en-route. It's a personal opinion but I don't see the point in stopping at Old Oak Common in addition to Euston. Ditto Manchester Picadilly and the airport, ditto Birmingham and its airport. Too many intermediate stops being introduced.
Stoke Council should be more concerned about what rail services it will have once HS2 opens and be lobbying hard to get some decent promises from government / HS2. Birmingham to Manchester traffic will be on the new line. London to Manchester traffic will be on the new line. Not much left to serve Stoke. Gone will be the twice an hour, 90 minute, service to London.
This may seem a long shot but could they do what they have done with the East Midlands and build one in the Audley area and call it something like Stoke-on-Trent and Crewe or North Staffordshire Parkway?
However of the six routes serving Crewe this one is by some way the most difficult to divert into any new station constructed further south! Some maintenance sheds (part of LNWR I think) have been built on the former southwards curve.
The existing station at Crewe can be fairly easily upgraded and modernised to suit new twin coupled classic compatible HS2 services. Some of the existing and abandoned platforms are already up to 400m long and fairly straight and level. Hence double classic compatible HS sets could split and join in a dedicated pair of these long platforms every half hour to deliver a 200m train to Runcorn and Liverpool along one branch, and Warrington, Wigan, Preston and Blackpool alternating with Lancaster along the other, using only 2 paths an hour in each direction along HS2 itself.
It would be fairly easy to make the link into Crewe from the south 'captive compatible' for terminating trains only as well, but a full conversion of the complex junctions north of the station to the larger loading gauge required in order to get back back onto the High speed line at the north end would be expensive and unjustified, given that the Manchester captive trains would be unlikely to stop at Crewe as well as any proposed station near Manchester airport. That's no reason to place the HS2 station a number of miles out of Crewe however which smacks of an renewed attempt to leverage land development opportunities in that vicinity rather than any integrated transport objective for Crewe, Chesire and the broader region for which the existing station site is excellent. Any proposal to take HS2 calls out of the existing major junction station area could destroy potential interchange traffic, something that elsewhere has been specifically encouraged and designed for at the other major new HS2 hubs such as Totton and Meadowhall and which is already very well catered for at Crewe.
The railway yards to the south could provide sufficient room for a new access road from the A500 alongside the railway corridor into the traditional station and town centre from the south of the town. That could form a development spine without destroying the transport interchange. A hi tech local transit link could follow that corridor to connect the station and town with such new developments to the south and possibly satellite parking if that became a problem in the immediate station surroundings.
The idea to move Crewe station isn't part of HS2 and it pre-dates any government initiative for high-speed rail. If moving the
station is still a possibility, it would be madness to move it somewhere that HS2 then cannot stop there as well if the need arises. A relocated Crewe
station would be where all the current heavy rail services stop so it wouldn't make much sense for HS2 compatibles to continue to run into the old station
. . . Part of the reason moving the station was mooted is that it isn't in the most convenient of places to start with for passengers from Crewe itself. At the same time, it's close enough that a light rail or otherwise dedicated transport service from the station isn't justified.
The whole western island is out of use, the way to do the work would be to reactivate it which need not be disruptive as it's only used for excess capacity.
Once that's up and running close the middle island and rig it up as needed for CCs to split and join..
Do wonder if the south facing bay on the west island can be captive cleared or if that would have any utility in the event of say a closure further up the line.
I expect some will know this, but listing does not prevent alteration. One simply needs to prove one has not needlessly destroyed a listed feature in one's application for listed consent. Clearly that is not always easy.
Chief Exec of HS2 has hinted they would pursue the Crewe option and not the Stoke option.
THE boss of HS2 has not ruled out Stoke-on-Trent's bid for a station, but admits the city is likely to lose out in favour of neighbouring Crewe.
Alison Munro, chief executive of the quango, said she would be reviewing the Potteries' case for an HS2 hub following the end of a consultation this month.
But she also revealed that the Cheshire option was seen as 'preferable'.
She said: "Many cities would like to be served by HS2, but obviously we can't have too many stops or else it ceases to be a high-speed line.
"We looked at where we could put another stop on the route from Birmingham to Manchester.
"We did look at options around Stoke-on-Trent but our view was that it was preferable to have a station at Crewe.
"But Stoke-on-Trent isn't being ruled out. We have just completed a consultation and Stoke-on-Trent's views have been submitted."
Stoke-on-Trent City Council put forward the economic case for a hub stop between Stoke railway station and Etruria Valley last month.
Under the authority's plans, the existing West Coast Mainline north of Stone would be upgraded to carry high speed trains at up to 142mph slashing journey times to the capital by 55 minutes.
It would involve completely changing the HS2 route between Birmingham and Manchester, which currently bypasses Stoke-on-Trent.
The council says this will be ready seven years earlier and cost £5 billion less than building an entirely new line through the Staffordshire and Cheshire countryside, as is currently proposed by HS2 Ltd.
Council leader Mohammed Pervez said: "This will make Stoke-on-Trent a core city. The amount of growth that would happen would be unimaginable and the amount of contribution that an area like Stoke-on-Trent and Staffordshire can make to the overall economy of the UK would be huge."
But Michael Jones, leader of Cheshire East Council, is urging the Government to favour Crewe's bid.
He said: "At the end of the day, the real deal is in Crewe."
The Secretary of State will make a decision on plans for where the stations will be based and a decision is expected by the end of the year.
Chris Dawes, secretary of the Whitmore Heath and Baldwin's Gate HS2 Action Group, is opposed to the current plan which would see a 50-metre tunnel created under his Whitmore Heath home. But he said if HS2 goes ahead, he would rather see the route altered and a hub created in Stoke-on-Trent.
The retired Michelin executive, who lives at Heath Rise, said: "I would be delighted if the route was to change, not just for me personally but for Stoke-on-Trent. But unfortunately I think they have already made up their minds."
Naturally the Local BBC News have run with the opposite :roll:
http://www.bbc.co.uk/news/uk-england-stoke-staffordshire-26217552
Completely rebuilding the station on the current site has the disadvantage of heavily disrupting the main hub of the entire WCML. Building their station idea a short distance down the line, with a suitable metro system to connect it to the centre of Crewe, would have much of the same benefit at much reduced monetary and disruption cost.
