Crewe Resignalling Dec 27-Jan 2
I see there are no Avanti trains to/from Liverpool today, with no services through Crewe because of resignalling there.
There are replacement buses to/from from Stoke, serving Crewe/Liverpool/Chester/Preston, to pick up Manchester-Euston trains from there.
LNR has a similar bus Liverpool South Parkway to Stafford to pick up there.
Preston/Glasgow are served by a couple of trains which run Euston-Stoke-Manchester-Golborne-Wigan.
North Wales gets a few Chester-Holyhead shuttles.
It's unusual for Liverpool to lose London services.
The Chat Moss line is open so you would expect a service via Manchester, but none operates.
Is this the resignalling that eliminates Basford Hall Jn box?
There are no trains at all today at Crewe, so what is going on on the north side?
I can't remember Crewe being closed completely since the 1985 resignalling.
Is this the resignalling that eliminates Basford Hall Jn?
Yes, signalling work will also take out the fringes as its all the boxes on the Independents that go. You can't fit two diverted Avanti via 13/14 at Picc without decimating the existing services. There will likely be the odd Intermodal via Macclesfield as well so the capacity isnt there.
Looks like every day is different through Crewe until Jan 3.
Once the routes to Stafford/Shrewsbury reopen on Jan 1, the route via Weaver Jn closes for a couple of days.
While the Stafford line is closed, London/Birmingham services are routed via Alsager and Stoke.
Wiring Crewe-Kidsgrove for WCRM is proving its value again.
Rhysdabeast
10 Apr 2020
Crewe
Salop Goods, Sorting Sidings North and Basford Hall Jn have closed with the boxes set to be demolished. Everything transferred to Manchester ROC. Basford Hall Jn area now has the Area ID M7 and The Independent Lines now have the Area ID M8 in Network Rails open datafeeds. Basford Hall Junction has the same berths but just re-numbered and the 2 shunt signals on the Up Fast and Up Slow now have berths. The independent lines pretty much are the same as well but should hopefully come through the datafeeds now as with Salop Goods and Sorting Sidings North the datafeeds was pretty limited.
M60lad
31 May 2011
And as usual while the works at Crewe were/are going on there's bound to be problems elsewhere and for some reason for the past couple of days there's been problems at Wolverhampton due to a fault with the signalling system although Cross Country Journey Check is saying due to engineering works not being finished on time.
Without going too much off topic does anyone know what is causing the problems at Wolverhampton?
Mugby
25 Nov 2012
Derby
Kidsgrove - Crewe certainly is being put to good use on the 31st with Preston/Glasgow/Edinburgh services being routed that way.
I'm travelling north on the 31st and I see quite a lot of recovery time has been packed into the timetable with trains standing for about 10 minutes at Barthomley Crossover and almost 20 minutes at Crewe Station.
Tilting007
21 Oct 2024
Rugby
And a dewirement at Four Ashes overnight…
AndrewE
9 Nov 2015
A self-congratulatory puff here: https://www.newcivilengineer.com/la...190m-overhaul-of-crewe-bottleneck-09-01-2025/
Network Rail completes ‘once in a generation’ £190M overhaul of Crewe bottleneck​
Crewe’s railway infrastructure has undergone a “once in a generation” upgrade following a £190M investment by Network Rail, aimed at enhancing both passenger and freight services at one of Britain’s busiest junctions.
but there are still only 3 approach lines into the station from the south... from 4 slow and fast lines and serving 5 through platforms, 2 through lines and 5 bays! It's no good saying that freights have gone off on the independant lines (the usual establishment justification,) I have frequently been delayed while conflicts at the S end are resolved.
Modern signalling naturally has a lifespan of about that length, so it's pretty meaningless self-congratulation to celebrate replacing life-expired assets.
And it's hardly "digital" or "modern" signalling. That would require ETCS, which is decades away from making an appearance here, now that they have just resignalled it with last-century technology.
It wasn't resignalling Crewe though, it was Basford Hall and the Independents.
AndrewE
9 Nov 2015
so what bottleneck was removed? Not the strangulation point of 3 approach lines to the station from the south... Maybe I shouldn't have taken "crewe" to mean the station, but if it's just resignalling of the goods lines how does that help? Maybe it helps NR because they don't have to find signallers for the small boxes...
Merle Haggard
20 Oct 2019
Northampton
Railtrack had, and Network Rail have,a history of describing replacement of worn out infrastructure as 'Investment' rather than 'Renewals'.
Would be interesting to see how it's treated in their books...
Its spin and it may be the NCE saying that, not anyone else. It was consolidation of the old boxes into one workstation, so yes saving NR headcount, much like any signaling job over the last 60 years.
poffle
11 Oct 2023
Dublin, Ireland
I think that they have now lifted some speed restrictions on the independent lines and the plan was that some of the through passenger services could use the independent lines in future rather than go through the station. That could facilitate greater use of the through platforms for stopping trains.
That's my memory and I can't immediately point to a source.
Harpo
21 Aug 2024
Newport
Generally, stuff delivered by maintenance teams is opex, and stuff delivered by renewals teams is capex.
On top of capex is enhancements. Anything that results in a greater operational capability than exists now, needs its own business case and source of funds/sponsor.
Anything other than opex spend has to pass through investment panel scrutiny.
Speeds didnt get lifted, its still 10 and 15mph. Its now passenger rated, but I doubt it will see any diversions as no one will sign it.
Lewisham2221
23 Jun 2005
Staffordshire
It doesn't say anything about a bottleneck being removed, just "overhauled" and "upgraded"
AndrewE
9 Nov 2015
Silly me! Fancy reading "Network Rail completes ‘once in a generation’ £190M overhaul of Crewe bottleneck!" and imagining that they might be addressing a bottleneck... What an idiot I am: Of course ovehauling a bottleneck means just leaving it as it is.
poffle
11 Oct 2023
Dublin, Ireland
Here's an article from Rail Engineer describing the project.
Among the main things
Chester line gains access to the independent lines
Increased speed was supposed to be part of the project
Modern signalling capable of supporting future systems
Closure of old signal boxes
A lot of this is enabling work for later stages of the Crewe project. The existing track and signalling infrastructure in Crewe is life expired and needs renewal. This work will allow some trains to run through Crewe during blockades.
Here is an article on the overall project:
There is also another article on the overall scope of the Crewe Hub project.
A lot of this was also at least partly related to HS2.
Efini92
14 Dec 2016
I don’t think anyone signs the chat moss from Liverpool to earlestown.
There is no Crewe project now HS2 is curtailed.
AndrewE
9 Nov 2015
What do you mean, "gains?" the line is still in on Open Train times even if it has been singled - and is grey on Traksy.
What a triumph, reinstating a mothballed line (not!) It definitely doesn't count as overhauling a bottleneck in my book. Why can't they just make an honest press release? - e.g. signalling upgrade/removal of 3 manual boxes, preparation for reinstating Chester Independants.
"Some sections of overhead line equipment above the out-of-use Down Chester and Coal Sidings 9 will be recovered" doen't sound very clever to me, as it will stop electric locos getting from Basford Hall to the ETD!
It's history now, but Avanti has in the past diverted through Manchester via Chat Moss, and occasionally via Warrington BQ and Earlestown.
In fact the latter diversion was used last week when there was a problem at Runcorn.
The Crewe resignalling was supposed to be the beginning of a complete upgrade which would include HS2 Phase 2a (extended platforms etc).
But that's in the bin now, and it's also unclear when the remaining fringe boxes at Crewe (Steel Works and Coal Yard) will be replaced.
