Peter, I believe that validity stops when you get to Clapham, as Waterloo isn't on any of the valid maps.Just a thought; does validity stop at Clapham Jct or can you carry on to Waterloo?
Clapham Junction is not valid as it is not classed ass on of the LOndon Terminals.
Peter
Peter, it is valid as it is on a valid route to London Group, if you can get to London on the same ticket or not, as said by yorkie, being able to complete your journey does not determine validity.
Edit - as yorkie said in this thread you do not have to be able to complete your journey - as this does not determine validity.
I missed this discussion, so to clarify, when using a mapped route, you may choose any route on the given map combination even if the route does not go between the origin and destination routing points?
ie. holding a Crewe to London Terminals ticket, you are allowed by LC to use the ticket to Clapham Junction by changing at Willesden Jcn, even though there is no mapped route from Crewe via CJ to London Terminals on map LC?
That doesn't make sense.![]()
Time I got me maps out again!!!
More to Follow - I'm on it!
This is how I determined that CLJ is permitted:
Firstly I looked at the YELLOW Pages (as I know that Crewe and London Grp are routing points):
This shows the permitted routes (the maps) - CM+GC, CS, LC.
So I looked at the maps:
This allows London Marylebone, travelling via the Chiltern Mainline (changing at B'ham) & London Paddington (when services exist) via the Chiltern Mainline.
This allows London Marylebone, travelling via the Chiltern Mainline, London Paddington travelling via Reading & Slough & you can get to Clapham Junction via Dorking, Redhill & Croydon this route would be fine for people getting a Travelcard, but you then won't be able to get into London on this ticket.
This allows London Euston.
Also allowing Clapham Junc, travelling via Willesden Junction & Kenny O again fine for Travelcards but not for others.
Hope this helps!
In that thread, transportphoto claimed that a London or Tottenham Hale ticket was not valid via Stansted Airport as from Stansted Air you can't then complete your journey (without doubling back between Audley End and Elsenham) as the first stop on XC is Audley End this renders your ticket invalid via SSD however it is valid only via Mountfitchet.Edit - as yorkie said in this thread you do not have to be able to complete your journey - as this does not determine validity.
Inadvertently, this has led to the second misapprehension. transportphoto has interpreted this to mean that it is not necessary to be able to complete the journey on the map for the route to be permitted. yorkie didn't mean that. He meant that it is not necessary to be able to complete the journey by timetabled trains for the route to be permitted. It is necessary to be able to complete the journey on the map(s).We have concluded several times that you do not need to 'complete' your journey, or be able to 'complete' your jouney
