Crewe blockade?
TrainOnLine
17 Aug 2010
Access to Arriva Train Care during the blockade will be challenging using the Up Fast via Basford Wood Ground Frame.
There would need to be a series of WD moves made at Basford Hall Junction - logistically a bit of a tricky one. I imagine the Up/Dn Chester Independent Line will see more use depending on where the blockage starts and ends
childwallblues
3 Jul 2014
Liverpool, UK
Did the 85 diversion behind various classes mainly 86 and 87 but also a 85. This time as no Avanti Liverpool service stops at Stafford (only LNW 350s) it would have to be a 390 to Lichfield Trent Valley or a 807 to Milton Keynes Central.
Thank you for so clarifying. I'll re-phrase the question...
When is it currently believed that the blockades will take place?
Someone else can do that, as I am not risking putting stuff out in the public domain before its officially announced. Its in the EAS section 7 final documents on the NR website.
Vexed
12 Jan 2020
Herts / Hants
To give more specific dates than my post in #6 (all dates 2027) from the EAS plus a few other non-Crewe closures nearby on the WCML in italics:
There are works in Jan and Feb around Manchester Airport / Piccadily and Stockport for resignalling and Manchester Airport remodelling not included.
Sat 13th to Sun 21st Feb, full station block at Crewe
Sun 14th and Sun 21st, unrelated to canopy works closure from Crewe to Stockport.
Sun 28th Feb & 21st March, full station block
Sat 1st to Mon 3rd May, unrelated to canopy works 3 day closure around Warrington BQ plus Tues 4th to Fri 7th slow line closure for Golborne station (quite a few slow line closures in April as well)
Sat 8th to Sun 9th May, unrelated to canopy works closure of WCML around Warrington BQ
Sun 9th May, full station block at Crewe
Mon 31st May to Fri 4th June, 5 day full station block
Sat 5th June to Fri 27th Aug, platform 6 / down slow closed for 3 months
Sat 19th to Sun 20th, Trent Valley line closure unrelated to canopy works
Sun 20th June, Sun 27th June, Sun 11th July, Sun 18th July, Sun 25th July, all these Sundays are morning blocks until 1240 for platforms 1-6 including Up & Down fast
During the Sunday closures above, from Sat 10th July to Tues 20th the Marches line to Shresbury will be closed unrelated to canopy works
Mon 26th July to Thur 5th Aug, 11 day full station block
Sun 15th Aug, full station block
The previously mentioned plat 6 / down slow closure ends Fri 27th Aug and then it all starts again on the other side of the station.
Sun 29th Aug, full station block
Mon 30th Aug to Fri 26th Nov, platform 5 / up slow closed for 3 months
Sat 4th to Sun 5th Sep, weekend closure near Warrington BQ unrelated to canopy works
Sat 16th and Sun 17th closures in the Chester area for signalling recontrol
Sun 12th to Thur 16th Sep closure between Wilmslow and Stockport (exclusive) for resignalling
Fri 17th Sept to Sun 3rd Oct closure for resignalling between Crewe and Stockport
Sun 19th Sep, 26th Sept, 3rd Oct, all Sunday morning blocks until 1240 for platforms 1-5
3rd Oct, closure through Stoke-On-Trent & Macclesfield
Sun 10th Oct, full station block
Sun 17th Oct, Sunday morning block until 1240 for platforms 1-5
Sun 24th Oct, Sun 31st Oct, Sun 7th Nov, unrelated to canopy works closure of the slow lines towards Stafford running Sat night to Mon morning.
Manchester Airport remodelling closure on 24th Oct & Sun 28th Nov
Looking ahead to 2028 there is a Manchester Airport to Health Green North blocade for 11 weeks 8th Jan to 20th March for remodelling. This is the side of the triangle outside Man Pic between Manchester Pic and Manchester Airport.
Unless otherwise noted closures are for the full day and may include part of the evening before & early morning after
There are also closures for resignalling between Crewe and Stockport in September and October.
There is one earlier than that. The Manchester south ones are bigger still.
Vexed
12 Jan 2020
Herts / Hants
Thanks, that's a 9 day one from Sat 13th to Sun 21st Feb (and more resignalling closures towards Manchester for both the weekends that 9 day is there!) as well as Sun 28th Feb, Sun 21st March. I didn't look back at 2026-27 at all. I've edited the original message in case anyone refers back to it.
Maybe I'll detail the Manchester south ones if someone else makes a thread on them and I have time (I'm going on holiday tomorrow so probably not for the time being).
Wasn't that bad, they're mostly in there now.
M60lad
31 May 2011
How will Rail services be affected by these blockades next year and where will any Rail Replacements run to/from during the blockades?
Will Derby services be Rail Replacements throughout as there's nowhere apart from Crewe to turn them round is there?
saismee
20 Oct 2023
Better get my WMT splits ready so I can jump on Avanti for cheap :D
SCDR_WMR
17 Dec 2017
Crewe
Surely they will turn around at Stoke? They often do when they run late as standard. No point having a RRB for the entire journey
Stoke
spp
8 Dec 2024
wolverhampton
How will this affect Birmingham to Liverpool services? (Particularly Wolverhampton to Runcorn a journey I make a lot)
Peter0124
20 Nov 2016
Acton Bridge, Hartford and Winsford would be left without a service, so I can see being reduced to an hourly stopper and ran via the independents.
Mcr Warrior
8 Jan 2009
Why couldn't WMR trains temporarily not call at Crewe and just operate otherwise as normal between Liverpool Lime Street and Birmingham New Street? Are there potential pathing issues?
pokemonsuper9
20 Dec 2022
Greater Manchester
I'm not sure of the exact layout (As to what can be used by passenger trains or not), but the normally freight only lines tighten to effectively 2 1 track lines at the connections to the South WCML, which I think won't be anywhere near enough for the normal ~9.33tph of through trains through Crewe.
Per hour through trains:
2 Avanti (Scotland-London)
2 Avanti (Liverpool-London)
1 Avanti (Manchester-London)
1 Avanti (North Wales/Chester - London)
2 LNWR (Liverpool-Birmingham)
0.33 Lumo (Stirling - Euston)
And then also freight.
and also not going onto the WCML:
1 TfW (South Wales - Manchester)
No.
They won't be using the independents.
craigybagel
25 Oct 2012
Even if there were paths,I doubt there are enough freight drivers available to pilot.
I would be amazed if between TfW and Avanti we end up with much more than 2 tph.
Bevan Price
22 Apr 2010
I understand that the Crewe station roof and other repairs are expected to occur at a (so far) unknown (to me) date in 2027, which is likely to cause major disruption. Platform 5 and adjacent tracks are likely to be closed first, followed by Plaform 6 and adjacent tracks.
(And remember that access to Platforms 1-4 is via Platform 5; access to platforms 7-11 is via Platform 6...)......
Apologies - I posted this before my attention was drawn to this thread.
And a comment. On days when there is not a total blockade, could Platform 12 remain open for limited services as it is available for reversible working, and could feasibly be accessed via "the landing" - as happens when replacement buses are operating. (Of course it has no rail access to the Manchester line.)
SCDR_WMR
17 Dec 2017
Crewe
No apologies needed.
Other than when there is a full closure, access will remain via both main entrances regardless of any platform closures.
I believe there is a plan being worked on to keep full access to other platforms on the islands during P5&6 closures. Given these closures are for several months at a time, it's simply not feasible to move all platform 1-5 services to 6-12 given all Manchester trains would have to use 6. And the same for platforms 6-11 services fitting in P1-5 & 12.
Unsure how 1-4 will be protected during P5 works, depends if the mid-platform over bridge can be kept open. Otherwise it may be via the Subway from P11 which is not ideal for moving large numbers of passengers
AndrewE
9 Nov 2015
a minor point, it is actually the "horse landing." Presumably dating from when horsebox traffic was common.
route101
16 May 2010
Are the independent lines, the lines that dive under and cross over?
