Coventry to Wembley park
TomJ93
24 Apr 2010
I need to get to Wembley Park on Tuesday, current plan is Branson all the way down to Euston, London Underground to Baker street, then back up on the Met.
Using a Zones 1-6 Travel card.
What are my alternative choices? I need to get a train to Wembley Park as opposed to London Overground to North Wembley etc :)
thanks.
SS4
30 Jan 2011
LM to Euston and then as your suggestion. LM super off peaks are relatively cheap for walk up tickets
Alternatively:
Coventry to Banbury
Banbury to Marylebone
Walk to Baker Street (It's about 300m and I find it easier than using the tube)
Met to Wembley Park
Do you really need a zones 1-6 card though? A zone 1-4 will do for Wembley Park
A cursory check on NRE states that travelling via High Wycombe (ie: the second route) is cheaper for walk up fares than Any Permitted (I did not check LM only)
edit: What Mojo said (post 3)
Mojo
7 Aug 2005
There is not enough information here on which to provide a good answer to your question.
Are you trying to save money? Or find a better/more interesting route?
What time do you need to leave/arrive? Are you averse to taking omnibuses? Do you hold a Railcard?
TomJ93
24 Apr 2010
I'm only looking to solve the tube part of my equation, hence using VT down to either Watford or London Euston.
So I am looking for the cheapest way from either London or watford to wembley park, full adult fare.
Thanks guys :)
MikeWh
15 Jun 2010
Crayford
Thanks guys :)
OK, here's what I think are your options (assuming you will not be arriving in London/Watford before 9.30am):
  • VT to Euston, walk to Euston Square, Underground to Wembley Park (possibly changing at Baker Street). Cost £7.30 for Z1-4 off-peak day travelcard or Oyster single fares of £3.40 between 1600 and 1900 towards Wembley Park or £2.50 at other times and for the return at any time.
  • VT to Watford Junction, LO/LM/SN/Bakerloo to Kenton, walk to Northwick Park, Met to Wembley Park. Cost with Oyster of £3.00 between 1600 & 1900 and £1.40 at other times each way. Travelcard would be £14.50.
Deerfold
26 Nov 2009
thanks.
Does your ticket allow break of journey? If so you can change at Watford onto a local train to Wembley Central. If this is too far from Wembley Park for you to walk you can get a bus - 223 or 297. This will cost £1.30 on Oyster or £2.20 cash and the same back (or if paying cash cheaper to get a 1 day bus pass).
