Coventry to London via Oxford
TomJ93
24 Apr 2010
For this Tuesday, I want to do XC to Oxford and change onto a HST bound for Paddington. Outbound only I need to arrive by 1pm. Full fare ticket, could I also be given 1st fares for my HST journey?
Thanks.
bb21
Emeritus Moderator
4 Feb 2010
I don't understand your question. A First Anytime Return is £215 between Coventry and London Terminals and is valid via Oxford for the itinerary you gave.
sonic2009
19 Jan 2010
Crewe
bb21 i agree with you also don't understand. Outbound Only? Does this mean single?
wintonian
15 Jan 2010
Hampshire
A Coventry to Oxford FOS is £58 and a Oxford to London FDS is £47 = £105 for the singles.
Thanks.
You mean you want a (walk-on) 1st class single? The 1st Anytime Single fare Coventry - Paddington is £107.50. The route is priced by Virgin as they assume you will go via Rugby which attracts a hefty premium. Therefore, try splitting (my usual advice applies ;)) in this case, try somewhere like Banbury.
Coventry - Banbury FDS £22.50
Banbury - London Terminals FDS £65.00
Total £87.50
(FDS = 1st Anytime Day Single)
Other splits may be cheaper, usual advice on how to find them applies :)
TomJ93
24 Apr 2010
Sorry guys. I mean an advance single if possible, as long as the train arrives before 1pm.
Am planning to go standard the length of the journey but If a first advanced single is not too much more I'd like to sample FGW 1st :)
OwlMan
25 Jun 2008
It is cheaper to split at Leamington
Cov - L Spa FDS £9
L Spa - London rte Banbury FOS £75
Peter
sonic2009
19 Jan 2010
Crewe
Coventry - Bicester North (valid to stop short at Banbury )
FDS Route Any Permitted £18.90
Bicester North - Clapham Junction (valid to start at Banbury)
FDS £32.40 Route Any Permitted +
valid via Reading,London Paddington CS+LONDON+LB also Easment : 700028 Customers travelling from Bicester North to Oxford and beyond, may travel
via Banbury. This easement applies in both directions.
total cost : £51.30
bb21
Emeritus Moderator
4 Feb 2010
If you're talking Advance fares then I think First Class might be a bit of a luxury. Standard is available from £5 at http://www.mobitix.thetrainline.com/FGW/advancepurchase.aspx for the day in question.
If you have a railcard, a number of departures including 1001, 1031 and 1101 are currently £4.30 on Advance.
There is no First Advance for this flow so you will be looking at walk-on fares with no discount given for Y-P.
TomJ93
24 Apr 2010
Decided to do a 67 from Leamington, the 10:55 for £7.
Thanks for all the help.
