(Course) literature regarding Track and Signalling Engineering
S.S
1 Oct 2009
Hi!
Im a new member of this forum and i apologize sincerly if i am in the wrong section,but... As a railway engineer student from Sweden, i am eager to know if there are any books or similar publication whom which describes the engineering principles behind signalling and track engineering? I am in search of uk based / applicable books.
Any help at this stage will be very appreciated!
Your truly,
S.S
driver9000
13 Jan 2008
Try the Modern Signalling Handbook by Stanley Hall.
Good luck!
mr_moo
7 Sep 2009
Cambridgeshire
For P-Way stuff I can heartily recommend the books from the PWI:
http://www.permanentwayinstitution.com/
Click on publications.
The 6th edition of the handbook is a good summary of everything, if a little dated. The PWI are currently re-writing and massively expanding the info to be published as a 7th edition in lots of parts, only some of which are available. They are being very slow in this regard...
I too am on the lookout for other good books so eagerly await suggestions.
Also, If you want to learn about track, you mustn't forget the formation/trackbed side of things, although I've got no idea what to recommend by way of reference material for this.
Old Timer
24 Aug 2009
This is the website you need. It has pretty much everything you will need to know about signalling.
Institute of Railway Signalling Engineers.
Also look out for two books published by A & C Black which I believe are now out of print but can still be found via one of the many bookshops on the Internet. The first is called "Railway Signalling", the other is called "Railway Control Systems".
The Permanent Way Institute has a series of books about track engineering which can be purchased. They are cheaper if you are a member. If you want to be a member then PM me and I will organise an application for you.
You may also wish to join the American Railway Engineering and Maintenance of Way Association (AREMA).
AREMA
I can also highly recomment the Institute of Permanent Way Engineers (India), who are highly regarded
PM me for anything else you may wish to follow up on.
mr_moo
7 Sep 2009
Cambridgeshire
Seconded re joining the PWI. You get a quarterly journal which has some very interesting info in it usually, cheaper books and publications, the ability to attend the main conferences (although these carry individual charges), and you get added to the mailing list for your local section so you find out about their meetings. My section (Birmingham) has meetings nearly every month, other sections have different numbers of meetings. Attendance at these meetings is free and you don't have to be a member so I suggest you go along and join up if you think you like it.
Some more areas of reference:
If you are interested in safety, the "yellow book" is good: http://www.yellowbook-rail.org.uk/
If you want to know more about signalling, the absolutely superb railsigns website is at http://www.railsigns.co.uk/
I can also recommend the also superb website at http://www.signalbox.org/
Joyce Whitchurch maintains a good set of info:
http://www.joyce.whitchurch.btinternet.co.uk/
HTH!
