To allow wheelchair access a lot of busses these days have automatically deployable boarding ramps. Could the same be done with trains to reduce the need for platform staff to be available to set up and remove boarding ramps manually?
Technically possible (believe some trams in Europe do this) but would slow down dwell times significantly and would be a potential safety minefield as able-bodied passengers will be trying to board and alight as the ramps are moving, while on DOO services the driver may be rather far away from the door and only have a tiny CCTV image or even just a mirror on the platform to see if somebody needs the ramp.To allow wheelchair access a lot of busses these days have automatically deployable boarding ramps. Could the same be done with trains to reduce the need for platform staff to be available to set up and remove boarding ramps manually?
Are the ‘automatic’ ramps on buses actually completely automatic or are they deployed by the driver when necessary?
Thanks for confirming this. So, NOT ‘automatic’.The driver presses a button to deploy it (or on simpler designs manually folds it out).
I can't see any in the film, only the usual slide-out step - have I missed something?The DB ICE 3neo has built-in ramps
Thanks, that's impressive, as historically mainland Europe has relied, rather like airlines, on platform-based lifts.Looking at the photos here it's actually a lift rather than a ramp.
