Wouild it not be worthwhile having an isolator immediately off the southern end of the City platform followed by a short section of dead contact wire to prevent even a slow train sending a pantograph into the last bit of cover. This would mean that as soon as the first pantograph lost power, an experienced driver would be aware of the drop in power as although 700s can climb the 1:29 with half power, it should certainly be obvious that something had happened. Although the scissors crossover at the bottom of the incline is occasionally used to recover trains, that would be using 3rd rail for those that had ac power issues. If for any reason the dead stub was needed to have power that could be brought back in manually with a single contactor that was integrated with the ground switching in the area.Indeed - drivers rarely have to manually do the changeover now, so they are more likely to make a mistake on the rare occasion they do have to
Only when the train stops in passenger service!
