Contactless Reading to London
Halsebee
8 Mar 2009
Is contactless travel allowed on any train from Reading to London or only on Elizabeth line? And if it is, are there contactless readers on the main platforms at Paddington?
Yes, Contactless valid on all trains between Reading and Paddington. Barriers at Paddington on platforms 2 to 5, 10 to 14, standalone readers on platforms 1, 8 and 9.
Most definitely not valid for travel to London on any other route that doesnt involve travelling from Reading through West Drayton though.
It's also valid to Euston on the handful of diverted GWR services that have an advertised public call at Reading.
infobleep
27 Feb 2011
When do these run or next due to run? I couldn't find anything on Real Time Trains.
renegademaster
22 Jun 2023
Croydon
Do the gates charge you a different fare depending on wether you come out on the high level GWR platforms at Paddington compared the Elizabeth line ones?
No. There is only one peak and one off-peak fare defined for Reading to Paddington, as indicated by the single fare finder.
There is no penalty for interchange at the high level platforms compared to travelling throughout on the Elizabeth Line.
ivorytoast28
10 Dec 2018
Sheffield
At £32.80 for a single peak reading to tfl zone 1 that has to be just about the most expensive contactless fare on the network.. just as well contactless payments are no longer capped at £30!
infobleep
27 Feb 2011
Reading to Gatwick Airport is £44.10 peak.
akm
21 Mar 2018
As has already been noted, this isn't by any means the most expensive single fare in the TfL contactless system.
And as a point of interest, this system was never subject to the contactless limit on retail transactions, since it uses a different model (google "transit transaction model). Indeed, if you pick an uncappable journey such as the Heathrow Express, you can make your one daily charge be as many £25s as you can fit journeys in a day...
renegademaster
22 Jun 2023
Croydon
What is the most expensive single fare?
Gatwick to Reading gives me £44 for a peak time single on the TfL single fare finder. Curious if that works on the North Downs line Service or just via Farringdon?
miklcct
2 May 2021
Cricklewood
The North Downs line is outside the contactless area.
akm
21 Mar 2018
As of right now, Gatwick Airport to Reading is indeed the most expensive. Watch this space, though...
Reading to Bletchley is £49.30 in the Oval fare structure for anytime day single so will tip over £50 in March.
There may well be some higher ones once Oval / Contactless includes stations further out from London.
Just via London and the GWML. Not valid on the North Downs and not valid via Bracknell
Indeed, but no need to go via Farringdon. GWR to Paddington, underground to Victoria and Southern to Gatwick also fine, as indeed is any other route which remains wholly in the Contactless area and doesn't exceed the maximum journey time.
plugwash
29 May 2015
You must remain within the area. That pretty much means you need to travel via West Ealing and South croydon. Also IIRC there are no OSIs to/from gatwick express, so I think if you use that you will be charged two seperate fares.
Farringdon is the obvious choice with only a single change, but I don't think there is anything stopping you taking other routes through London if you prefer.
The direct train from Reading to Gatwick leaves and re-enters the area so it's not valid and you are likely to get in trouble if ticket checked.
