Connections into restricted super-off peak train
Re 4/4
30 Jun 2018
Bristol
I have this super off peak return from Bristol to Guildford: https://www.brfares.com/!faredetail?orig=BRI&dest=GLD&rte=700&tkt=SSR
It says that it is
Not valid on trains timed to depart: Reading after 04:29 and before 10:30 and after 15:31 and before 19:01;
but also
Super Off-Peak tickets from stations not listed are valid for connections into trains departing as shown above.
So, on the return portion, can I definitely take any train from Reading to Bristol because I start in Guildford?
Haywain
3 Feb 2013
No, you have to adhere to this part:
  • London Paddington after 04:29 and before 10:10 and after 15:04 and before 19:01;
  • Reading after 04:29 and before 10:30 and after 15:31 and before 19:01;
If you need to dodge the restrictions on trains departing Reading at certain times of day, might be able to do Guildford - Woking (change train) - Salisbury (change train) - Bristol (but depends on what routing restrictions you have).
Is a slower route, but if alternative means waiting hour or two to use Reading route, then might be faster.
30907
There are Waterloo departure and Salisbury arrival restrictions which rather spoil that.
