Welcome to the forum!
Transport for London take misuse of Freedom Passes cards
very seriously and a prosecution under the TfL Bylaws is the usual outcome.
TfL will send you a Verification Letter in the next 2-3 weeks. It may be sooner, it may be later depending on their volume of cases. This asks you to confirm or deny the incident and is an opportunity for you to tell TfL about any mitigating circumstances you want them to take into account when deciding how to proceed.
I suggest you mention the following in your reply:
- That you are sorry for what has happened
- What you have learned from the incident
- That you are keen to settle the matter without the need for court action
- Offer to pay the outstanding fare and TfL's administrative costs in dealing with the matter
TfL generally do not offer out of court settlements although in some very limited circumstances they have been known to issue a final warning instead of prosecution. Prosecutions are normally done through what is called a Single Justice Procedure Notice. This means that if you plead guilty it is not necessary to attend court in person (unless you choose to do), you simply return the form to the court with any mitigation you want them to take into account and they will write to you with the details of the fine you have to pay.
If you are prosecuted and plead guilty (or are found guilty by the court) then you will have to pay:
- A fine based on your income - normally reduced by a third of you plead guilty at the earliest opportunity
- A surcharge of 40% of the value of the fine
- A contribution towards TfL's costs
- Compensation for the fares avoided
If you are found guilty then this is a criminal conviction. If you are prosecuted under the TfL Bylaws (which is what normally happens) then the conviction isn't normally recorded on the Police National Computer and won't normally appear on Basic DBS checks although we always advise people to be honest when asked if they have a conviction.
As far as I know your relative will be able to apply for a new card, although I'm not exactly sure what the procedure is for this. Again as far as we know there are no consequences for them other than having to apply for a new card.
Some people have reported that using a solicitor to assist in presenting their mitigation can sometimes result in a more favourable outcome. The decision on whether or not to use a solicitor is one that only you can make - solicitors specialising in fare evasion aren't cheap and you will still have to pay their fee even if they are unable to negotiate a more favourable outcome for you.
In answer to your specific questions:
I am ok with paying the small fine or even being prosecuted for my mistake but I don’t want to have to go through unnecessary hassle on accusation of being a repeat offender, as I have commonly seen in threads regarding issues like this
It's not up to you to decide what happens next. Ultimately TfL will decide how to proceed and what hassle it might cause you won't be any concern of theirs.
Is there anyway they could use cctv or something to prove it was not me?
It's highly unlikely they will check CCTV. The one case where TfL caught you is sufficient for them to prosecute so they are unlikely to spend too much time finding other incidents. Is there a pattern to the journeys made legitimately that is different to the journey you made?
Here's a link to TfL's Revenue Enforcement & Prosecutions Policy which you might find worth reading:
https://content.tfl.gov.uk/revenue-enforcement-and-prosecutions-policy.pdf
