Computer Help
Gizmogle
28 Aug 2006
Whilst using my Mac I had the brilliant idea that I could probably connect the monitor to it and use my computer monitor for the display.
I use a Dell monitor with a DVI connector thingy, and my MacBook has a Mini DVI connector thingy.
After reading around, I've found that many Dell monitors have weird DVI connectors with 4 pins missing.
Apple do a DVI to Mini DVI cable, but I don't want to end up buying one that isn't compatible with my Dell monitor. I also read stuff about DVI-I and DVI-D. According to a reviewer, Apple's cable is a DVI-D.
If someone could just tell me what I need with maybe a handy link, that'd be good :) Cheers.
D306
9 Apr 2007
somewhere concrete
Where is Tom when you need him.
Check the forums over at the apple site for some help. If it was to do with a normal PC then I'd be able to help, but I'm not experienced with Macs
Gizmogle
28 Aug 2006
Well the Mac bit is simple as it's just an ordinary Mini DVI. It's Dell with their funny connectors that has me confused.
I've had a look around Apple forums, but I don't really know which stuff applies to me.
D306
9 Apr 2007
somewhere concrete
it could be the Dell monitor then. Best to ask apple for compatibility first then go and buy one, or even ask dell, but you may get no-where with them. Try asking apple and see what they say
Gizmogle
28 Aug 2006
Right, it looks like I might need a DVI-D to Mini DVI cable, which is what Apple do, so it'll be fine.
Unfortunately they're bloody £15! Think I'll look elsewhere.
nath9425
10 Nov 2006
Milepost 84 Chiltern Mainline
From experience at work we have had 120 Dell Monitors put in, and never needed to change the Dell DVI Cable, it was straight swap so I can't see why you need one of these mini ones? That sounds silly, All dell PC Monitors were built to standard DVI Connections.
Gizmogle
28 Aug 2006
I need the Mini DVI because the input on the Mac is a Mini DVI. (Obviously would have been quite hard to fit a full size DVI connector on such a small laptop)
Craig
15 Jun 2005
Newcastle
DVI-D is digital, DVI-A is analogue and DVI-I is integrated (digital and analogue). If you need a digital one then a DVI-D or DVI-I cable will work. I think the 4 missing pins on the Dell's are probably just the analogue pins, making them digital only.
Something like this should do you.
Gizmogle
28 Aug 2006
That'd be good :) I'll have a look at my DVI connector thingy later and tell you what it is.
Tom B
27 Jul 2005
£15 doesn't sound *too* bad... you may be able to find it cheaper though.
Gizmogle
28 Aug 2006
Yeah, I'm tryna get one of eBay at the moment, as I really am too cheap to spend £15 on one :p
Broken Viking
23 Oct 2006
some place west of France
...Whatever floats ya boat!
Generally speaking, Blood floats mine! <D
Although trying to find a sea full of Blood to sail something the size of an oil-tanker on (I have a crazy speedboat project in mind! <D) isn't an easy task...And the difference between Blood and sea-water could lead to the ship floating dangerously high above "the line" anyway... :shock:
