Common Local Government Ticket Poland
sonic2009
19 Jan 2010
Crewe
Common Ticket
Is there any routes or way of a circular journey I could do for a day starting from Poznan with this ticket?
Or any recommendations without this ticket using local and PKP services.
Common Ticket
The obvious one is Poznan-Zbasynek-Wolstyn-Leszno-Kalisz-Poznan (including the steam train). Whether that is do-able in practice I don't know, it's years since I was there.
dutchflyer
17 Oct 2013
MOST=not all of local services=all stops, are done by PolRegio-and this offers its own ´rover´tickets as well- like 3 days travel in some period (1 month-maybe shorter). They do most local rutes out of Poznan. Pretty cheap.
PKP only does the longer distance IC/Expresses etc and all trips have to be reserved, also with any type of ride-at-will, like also InterRail.
MUst admit that what you mention is unknown to me till now, perhaps its just yet another title for what existed already.
rvdborgt
24 Feb 2022
Leuven
Reservations are only mandatory in some trains, check the PKP planner. Recommended in many cases nevertheless.
Cloud Strife
25 Feb 2014
The one that immediately comes to mind is Poznań-Wolstzyn-Leszno-Ostrów Wielkopolskie-Kalisz-Poznan, all on Koleje Wielkopolskie.
sonic2009
19 Jan 2010
Crewe
Thank you - does the Wolstzyn steam run at this time of year? Ideally I'd be looking at Wednesday 5th February for my Poznan trip start.
30907
https://parowozy.com.pl/fahrplan.htm
sorry, no English version AFAIK but "erst ab Februar" means "(only) from February."
The pdf timetable says "Mon-Fri from 3 Feb" so you are in luck! However, you will probably need to reverse/adapt my suggested trip upthread.
sonic2009
19 Jan 2010
Crewe
Thanks I'll take a look at timings when I can make it onto a desktop - trying to work out on mobile isn't the greatest.
P Binnersley
30 Dec 2018
According to the timetable there is one afternoon return steam working from Wolsztyn to Zbąszynek, which is in the opposite direction to Leszno where it used to go.
Zbąszynek is mainly served by expresses from Poznan, but their is a limited KW and Polregio service.
The Saturday steam service to Poznan is one return working 05:52 from Wolsztyn returning at 09:24 from Poznan.
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
Did use this ticket in February last year from Poznan precisely to cover the steam turn but couldn't do a circular route. Went to Wolsztyn (ticket includes entrance to Steam shed or at least a reduction in the cost, can't quite remember which) then up to Zbaszynek and return to Wolsztyn for train back to Poznan. Took the entire day!
sonic2009
19 Jan 2010
Crewe
I looked at the timetable and connection from Zbaszynek back towards Poznan was at 1525 Polregio Service. So ideally if the steam is on time then I should be able to make it.
I'm going to have a look tomorrow at times - as I'd like to start from Poznan at around 9am and go somewhere and end up in Wolstzyn for the steam service. However proving where to go in a circular journey is proving difficult.
