Collision Plymouth 03/04/16
greaterwest
23 Nov 2014
Exactly. I'm surprised a platform, anything SW of Bristol, could accommodate both a HST and any other stock you care to mention. Having said that, even if signaller error, the driver of the HST should have been fully aware of this. Still, let's wait until the RAIB report before jumping to conclusions
As per my previous reply, the HST driver did nothing wrong. I don't think you read the article, or this thread.
TOCDriver
24 Jan 2013
I can't see how the driver of the HST has done anything wrong. His train was seemingly correctly platformed and stationary when hit in the rear by 2E68.
Ooops, sorry, not read the thread or news properly! I thought the HST had gone into the 15X, not the other way around! Apologies! Looks like the 15X man has some explaining to do then.
HarleyDavidson
23 Aug 2014
What a bizarre comment!
Care to enlighten us on this? If the driver is in the cab with the brake pipe fully charged, MS in Neutral, DRA set, GSM-R setup and they're comfortable and ready to go, what more do they need to do or worry about?
If it were me, I'd be sitting there probably having a drink, not wondering whether something's going to hit my train up the backside or whether the signaller has made a mistake.
I've known them to accidentally put one on top of me at Waterloo years ago, which screwed things up, I was a tad puzzled, but not worried.
There are some really odd folk here.
ExRes
16 Dec 2012
Back in Sussex
A bit worrying that you use the title TOCDriver, mention "jumping to conclusions" and admit to "not read the thread or news properly", perhaps that might point to why there is so much falling out on this forum whenever this sort of situation arises
Mike395
23 May 2009
Bedford
Final reminder (if it continues the thread will be locked). Whilst the investigation is proceeding, please keep to the facts and not speculate. For those asking, the reason it's not a good idea is (at least) twofold:
Firstly, any speculation has a tendency to blow out of all reasonable proportion, and turn into a 'trial by forum' type discussion, which isn't helpful to anyone and opinion becomes far more likely to be presented as fact.
Secondly, there are a lot of active rail staff on this forum, and TOCs/the BTP monitor it too, so there is a small but serious risk that discussion here may influence those dealing with the investigation itself.
hello
10 Jun 2008
i believe platform 4,5,7 and 8 at plymouth could accomodate a 2+7 hst set and a 4 car sprinter where the coaches are 20 metres in length
BritishRail83
16 Feb 2014
Poplar
I see the media didn't waste any time in sensationalising this story. I'm sorry for anyone injured or shook up or left anxious by this incident. It shouldn't of happened and I'm confident that the RAIB will thoroughly investigate. But to put it in perspective how many people have been injured or worse on Britains roads today as a result of collision? I believe I'm correct in saying that it's been 9 years since a passenger in a British train was killed? Railways especially our own have a brilliant safety record. I'm very proud of Britain's Railway safety record.
Parallel
9 Dec 2013
Thoughts to all those involved in the collision today.
GWR have three 'spare' power cars, so it depends on their availability, and on whether the Mk3 coaches are undamaged, but the HST could be back in service relatively quickly.
The 150 situation will be harsher, as there are already not quite enough DMUs in their fleet to run the service they want to at all times — in the past there have been full-time bus replacements rationed out amongst branch lines on a rota basis.
Hmm and it doesn't help that two other 150s (and a 158/9) are currently away for work as well. To GWR's credit, they are usually pro-active with utilising all available stock when damages happen. Assuming at least 1 car of 150219 (?) will need work and possibly the other 150 that was attached will need to be examined for any damage caused by impact, GWR will (hopefully) have a couple of plans up their sleeve to minimise the shortfall of carriages.
Johncleesefan
4 Sep 2013
Out of interest 150219 has the new pis/pa systems and matrix dot blinds? It went through refurb with 150232 (gwr livery) which has been notorious for faults
HMS Ark Royal
2 Sep 2015
Hull
How would the Sprinters and the HST be recovered to depot? Towed or able to limp in under their own power at a shunting level of speed?
Curious to know
greaterwest
23 Nov 2014
Curious to know
The HST would probably be driven into Laira under its own power (Laira is just past the London end of Plymouth)
I'm not so sure about the Sprinter, they may be able to drive it from the middle cab of 150249 but I don't know how operationally viable that is, or how bad the damage is to 150219.
bnm
12 Oct 2009
Possible we'll see a hybrid comprising the undamaged half of 150219 plus a 153. Or possibly add the undamaged half to another 150 to make a hybrid 3 car 150. Still means you are effectively one unit down but does at least keep the undamaged half in traffic.
Domh245
6 Apr 2013
nowhere
Curious to know
It'd depend on the damage to some extent. I'm only armchairing, so don't take it for a truth, but if the sprinter had damaged some piping beneath the cab and broken the brake system, it may not be towable without skates (or a very slow speed limit and the brakes isolated)
HMS Ark Royal
2 Sep 2015
Hull
Thank you... I keep forgetting that some 150s have a extra cab
Thanks
TOCDriver
24 Jan 2013
Looking at that damage, I can only envisage it being reversed away because you certainly couldn't connect anything to it.
Parallel
9 Dec 2013
Yep, 150219, 150238 and 150232 have been refreshed and had accessibility mods fitted.
jmbill
28 Aug 2013
South West
Yes that's correct. 150219 is in plain blue FGW livery but has pink cab doors. So it's quite easy to spot on the network and is the one with a few upgraded features ahead of 2020 disability laws coming into force.
Crossover
4 Jun 2009
Thanks
The 150s that had an 'extra' cab were those in the Midlands that were formed of a 150/1 with a single carriage 150/2 in the middle. These have all been disbanded at the point they transferred to Northern and FGW
In this case, the middle cab would be the front cab of the rear set
SpacePhoenix
18 Mar 2014
Is the cab a single metal casting or a number of different plates welded together?
Phil.
10 Oct 2015
Penzance
Few observations- According to Open Train Times 1A91 Plymoyth to Paddington was destined for platform 7, and 2E68 Penzance to Exeter St Davids platform 8.
In the picture, the track appears to have a lot of oil on it (platform 6)
The semaphore calling on signal is smaller, and has a horizontal white stripe.
The semaphore calling on signal has a white arm with horizontal red edges. It has a white arm because it is not a stop signal.
bnm
12 Oct 2009
GWR have two 3 car 150s with middle cabs. 150925 and 150926.
Llanigraham
23 Mar 2013
Powys
For 12 ambulance vehicles to be called does suggest the accident was, perhaps, originally thought to involve more casualties than, thankfully, were the case. Even including paramedic motorbikes, etc, that represents almost all the available vehicles/personnel from quite a wide area of Devon and Cornwall.
When I heard of the accident I have to admit to breathing a sigh of relief as to the timing. Yesterday I attended the Golden Wedding celebrations of some friends in Penzance and three of their guests, including their daughter, were travelling on a Pz to Paddington service at 14.30 today, which would still have been nowhere near Plymouth by 15.30, so I know they are safe. I'll post later as to what happened to their journey(s). Two of them had to get to Margate, one of them starting a new job tomorrow morning in London.
As someone who is involved in major incident planning and the voluntary services; if a "major incident" is called, such as a train crash, then there is a known procedure to be followed, which includes the number of Ambulances tasked. It is easier to "stand down" crews when the full circumstances are known, as appears to have been done here.
Unfortunately there appears to be a lot of speculation by the uninformed here!!
the sniper
4 Sep 2007
He really should not be speaking to the press until the RAIB have finished with him.
The driver spoke to the press...? :|
EDIT: Unsurprisingly I can't find that anywhere... Maybe he let NR know instead? :roll:
cjmillsnun
13 Feb 2011
How else would we know that he says that he had the right signals? If it had been said to a TOC employee or an employee of the the police/network rail said person should not be talking about it either to members of the public or on a public forum... I doubt any employee would put the statement I directly quoted on this forum.
bnm
12 Oct 2009
That the driver said he had the correct signal on approach to platform 6 was not said to the press. It was said to Network Rail staff who then communicated it on rail industry systems.
This allowed movements to resume past the signal in question.
cjmillsnun
13 Feb 2011
OK, but should that be on the forum? It is now public knowledge rather than in a restricted rail industry system.
