Coal Falling Off
sonic2009
19 Jan 2010
Crewe
Train involved :
0347 Redcar B.S.C. Ore T. to MargamT.C.
Whilst awaiting the 1033 XC Birmingham service at Tamworth, the above freight passed through chucking a load of coal of in the process all over the platform, luckily nobody was injured.
Is there a set procedure if a load is too high like this, not only a danger to the public, but also other trains. I reported it to the Guard on the 1033, who has passed it on to his control, who will then pass it on to Network Rail.
What will happen to this train, will be stopped and the driver investigates?
Tomnick
10 Jun 2005
Yes, the train should be brought to a stand (preferably somewhere convenient!) for the Driver to go back and have a look. I'm not sure, to be honest, what the Rule Book says should happen next, but I'd imagine it'd be allowed to run forward, at reduced speed if necessary, to a suitable location for it to be dealt with properly.
tsr
15 Nov 2011
Between the parallel lines
I would have been strongly inclined to use the Help Point, rather than wait until I found the guard of the next train! If there's a noticeable amount of the load coming off, the emergency button may be appropriate, as even a small bit of debris could injure someone if it hits them awkwardly.
The train should be stopped, I would think, yes.
sonic2009
19 Jan 2010
Crewe
I couldn't locate a help point and the next train came through 3 mins after.
As soon as I mentioned it to the guard he immediately phoned his control as he could see it on the platform.
michael769
9 Oct 2005
Perhaps a good reason to have Network Rail's Emergency number handy.
It's 08457 11 41 41
tsr
15 Nov 2011
It's 08457 11 41 41
Indeed. I actually have this on my smartphone's home screen (protected by a series of gestures to ensure I don't auto-dial it) as I figure I will need it sooner or later, given how much time I spend on trains and stations, and the easier it is to dial, the better.
GB
16 Nov 2008
Somewhere
Train was stopped and examined with no issues found. It is suspected that it was light weight coke rather than coal and as such excess was blown from the train as it moved.
sonic2009
19 Jan 2010
Crewe
Thanks for that info. I will keep that network rail number handy, where abouts was it stopped?
TDK
19 Apr 2008
Crewe
This would be classed as a train with an unsafe load and as a rail employee you should get the train stopped immediately with an emergency call if nessessary..
reb0118
Fares Advisor
28 Jan 2010
Bo'ness, West Lothian
There is regularly loose coal lying around the platforms on the EGS (Edinburgh to Glasgow Central via Benhar Jn.). I've never seen it blown of trains but don't for one minute think it was the coal fairy. What would be the legality in taking and using said coal? Not any good for me as I have only a coal effect gas fire ~ as an aside I wish visitors to my humble abode would stop treating it as coal fire by throwing in their rubbish! Does this coal still belong to its original owner or does the railway take possession as it is now on its land?
barrykas
19 Sep 2006
Network Rail - 0845 711 4141 or 020 7557 8000 Melton Street switchboard
Network Rail are no longer at Melton Street...Though the Switchboard number hasn't changed since the move to Kings Place (and is given on their Contact Us page).
It's incorrect to list it as an alternative to the 0845 number, however, as that goes directly to a dedicated Helpdesk.
Mojo
7 Aug 2005
Does this "dedicated helpdesk" have a proper number? I'm not in the position to be able to call an 0845 number. Would contacting the National Operations Centre suffice?
Tomnick
10 Jun 2005
Obviously if you see it yourself, you're in a better position to judge whether it needs to be brought to a stand immediately. In this case, I'm sure it'd take some time for the information to trickle down from Control who would probably decide for you! Sounds like the sensible course of action of getting it clear of the main line was taken here, given that it had already run a couple of hundred miles!
TDK
19 Apr 2008
Crewe
If a piece of coal had come off that train and hit a trains windscrenn travelling in the opposite direction it could have killed the driver so soryy to dissagree with you but that train should have been stopped immediately or run at a reduced speed until it could be inspected, I suppose the signaller was more worried about delays than the welfare of a driver!
Tomnick
10 Jun 2005
As I said, I doubt the Signalman was made aware of the issue other than by a vague instruction from Control to recess the train for it to be inspected - so the decision had already been made. At no point did I suggest that performance should come ahead of anyone's safety, and if I (as a Signalman) observed something wrong with a passing train, then I'd be able to make my own decision based on what I've seen. I don't think it's too uncommon for small, light lumps of whatever to be lifted out of wagons though, so unless the train's obviously overloaded or there's bigger bits (which, as you say, can potentially do some damage) involved, I'm not sure I'd stop the job. If there was any hint of a dangerous situation though, that's a different kettle of fish!
Cab2Cab
12 Jan 2013
Hi,
Dependent on the method of work at the loading location the train should be checked before leaving with a train list (weights, etc), you have a care of duty to passing through stations, other rail operators, OHLE and lineside equipment, somebody has to sign for the train and it's load.
Because the train has been reported and bought to a halt questions will be asked.
Cheers
sonic2009
19 Jan 2010
Crewe
And it didn't come off lightly either, it came off like someone had thrown it at the platform although we now know that it's light coke that came off not coal, it still came off and a few of the wagons were loaded right to the top.
If someone had been hit it would of caused a serious injury at which the speed it came off
Broken Viking
23 Oct 2006
some place west of France
Shouldn't loose loads like coal, ballast and sand be sheeted over if being carried at speeds over 30-40mph? :?:
(I know nowt about rail freight operations, but I know for certain I'd be "sheeting" my load if I was driving a truck loaded close to/at capacity with aggregates like that...)
Welshman
11 Mar 2010
While I have no desire to detract from the seriousness of this matter, the headline of this thread also reminded me of tales of how coal used to regularly "fall" off the tenders of steam engines. And I'm equally sure that it was merely coincidental that a friend just happened to be passing at the bottom of the embankment with a wheelbarrow.
7 Jan 2010
If a piece of coal had come off that train and hit a trains windscrenn travelling in the opposite direction it could have killed the driver QUOTE]
I'd be very surprised if that would happen. Windscreens are amazingly tough and in 10 years on the railway i've not known anything penetrate a windscreen.
I've even taken a sledge hammer to a windscreen that had been removed due to being cracked and could not puncture the polycarbonate layer.
LE Greys
6 Mar 2010
Hitchin
About fifteen years ago, I went to get some shots of Flying Soctsman going through Baldock, and a massive lump of coal came off the tender and hit me on the leg. It now sits on an old ashtray underneath my gas fire. She was doing about fifty at the time, and it fealt a bit like being trapped LBW by a fast bowler, only without pads on.
ChiefPlanner
6 Sep 2011
Herts
There is a charge against freight companies for coal spillage - less and less common these days. I recall trains of somewhat overloaded MGR wagons having the overheight pile of coal smoothed off by the first overbridge ! Coal , not being particularly heavy and likely to fragment is less of an issue than say flying stone or ballast , or scrap metal.
306024
23 Jan 2013
East Anglia
During the war............
Coal used to regularly fall from the steam loco's on the Thetford - Swaffham line, right into my aunt's garden.
Pure co-incidence ;)
