Class 93 Tri-mode Loco
ExRes
16 Dec 2012
Back in Sussex
Unless anyone can provide better information, I believe the Class 93s will initially be based at Leicester LIP.
Always prepared to be proved wrong but I simply don't see GBRf allowing the 93s into Leicester LIP, it could/would lead to GBRf having their 99 style cramped
cj_1985
6 Mar 2010
Lanarkshire
GBRf dont own Leicester LIP, that would be UKRL. However, the Stadler shed was built to specifically cater for the GB class 99 fleet... so they may have grounds to argue for the 93s not to make use of those facilities... if they have part funded the construction of that shed
Wyrleybart
29 Mar 2020
South Staffordshire
AIUI Leicester depot is not "owned" or "controlled" by GBRf though is it ? Stadler have the shed for the class 99 contract maintenance etc and UKRL operate Beale St depot. UKRL also carry out contract servicing and CET of Cross Country class 170s. I suspect UKRL also provide some fascilities for ROG and EPX.
Bertie the bus
15 Aug 2014
As alluded too on another forum, it appears the goal posts for approval continue to be moved by the infrastructure owner, and the class 93’s have not received full approval yet. Hence the 0Qxx headcodes when moving on the network.
I find that very hard to believe (the moving goalposts being the reason for the length of time bit).
Class 93 - first arrived in June 2023, mainline testing didn't commence until May 2024.
Class 99 - first arrived in June 2025, mainline testing due to commence within 1 week of arrival.
themiller
4 Dec 2011
Cumbria, UK
I wonder if 93001 wasn’t tested as rigorously at Velim as the 99s due to cost saving or capacity constraints.
Wyrleybart
29 Mar 2020
South Staffordshire
Strongly suspect it is the regime used by the owner to breing them into service. I have always been struck by how keen GBRf are to get their stuff going. Maybe that the class 99 is basically a UK sized Stadler Eurodual which already has an operational presence and service history on the European mainland. The class 93 on the other hand - does that have a European "forebear" ?
I think GBRf have made their intentions very clear over the role of the class 99, whereas ROG have previously suggested their 93s would replace their class 37s (all they currently have). So you might imagine the Stadlers would be hauling Rosco stock around, but recent comments are that the autocouplers have been removed from those out mainline so far.
D365
29 Jun 2012
… whereas ROG have previously suggested their 93s would replace their class 37s (all they currently have).
This may have been suggested in the past, but none of the ROG lectures that I have attended in the past 12 months have stated that the Class 93s will displace their Class 37s.
Richard123
11 Nov 2018
Rugby
The first of type battery loco might also have triggered additional testing.
No doubt the class 99 introduction will be aided by class 93 experience, just as class 93 will have been aided by class 88.
Manufacturers often tweak their software based on measurements from testing to mitigate EMC issues or undesired operational behaviours,which can involve trial-and-error, one reason a follow-on order is so much quicker than a new design...
How long did it take to get the 88s into traffic?
Bertie the bus
15 Aug 2014
3 1/2 months from the first loco being delivered to Carlisle until it hauled its first proper train - a DRS hired Northern Belle for bigwigs and hangers on, and full freight service soon afterwards. 2 years and counting for the 93s.
cj_1985
6 Mar 2010
Lanarkshire
How do you work that one out?
Richard123
11 Nov 2018
Rugby
Testing throws up compatibility issues, sometimes not found in previous tests, with other equipments.
NR demand changes.
Manufacturer has learned a bit more about UK issues, fixes them but also normally avoids repeat with the next generation.
Sometimes the train order is big enough to switch things round: the first IEPs caused signalling failures across ECML and GWML.
NR ended up funding major infrastructure changes across both routes over several years to reduce susceptibility to the IEP harmonics.
I can't remember a previous train introduction triggering such a scale of retrospective infrastructure works, but most other manufacturers had a long history of experience of delivering similar trains here, except perhaps Stadler? (CAF started off with Siemens traction equipment)...
NR demand changes.
I forgot Alstom where the pendolinos triggered substantial works...
cj_1985
6 Mar 2010
Lanarkshire
NR demand changes.
You talk as if Stadler Espana haven't had any experience introducing locomotives to the UK....
The 99s will be the 3rd fleet under their brand...
The 68s under the prior Vosloh brand that previously ran and manufactured at the facility...
And the 67s under Alstom before them...
ac6000cw
10 May 2014
Cambridge, UK
The 99's will be 5th loco fleet from Valencia (67, 68, 88, 93 and 99), the 4th using ABB AC traction drives and the 3rd with 25kV OHLE capability. Also ABB supplied the AC traction drives for the 92's (and the Eurotunnel shuttle locos, but they don't run on NR track).
I think the only mainline UK locos with AC traction drives not supplied by ABB are the GE-equipped class 70's.
cj_1985
6 Mar 2010
Lanarkshire
But what i mean is the 3rd fleet since the factory has been under Stadler ownership... but yes, 5th overall for the UK
Richard123
11 Nov 2018
Rugby
Indeed; the second AC fleet. The diesel fleets don't bring too much learning from traction compatibility perspective, as the currents are largely contained within the loco.
The power upgrades on the South Western triggered by the Desiros?
Fair point, but that wasn't a vehicle compatibility failing, it was a lack of power problem
800001
24 Oct 2015
Suraggu
23 Oct 2013
The Far North
Rail Quest
8 Apr 2023
Warrington
Trainman40083
29 Jan 2024
Derby
hwl
5 Feb 2012
If this does run this evening, does anyone know what wagons it'll be hauling?
At a educated guess starting with ~ 600t and then stepping up in 200t increments (e.g. 2x loaded aggregate box wagons) with a couple of runs at each step. Then probably throwing in a 100t increment just below where the "really struggles" case is.
AndrewE
9 Nov 2015
So it appears loaded tests are beginning tomorrow.
and it's booked to stand for 14 minutes at Tebay, presumably a challenge test for restarting on a gradient, or climbing Shap without having had a run at it.
Suraggu
23 Oct 2013
The Far North
It certainly appears that way. Clearly this is what these tests are being carried out to demonstrate/show.
Tomorrow test show a maximum weight of 1400 tonnes.
AndrewE
9 Nov 2015
I'm a bit puzzled as to why they are pathed as diesel... surely the point of these locos is that they can draw lots of power from the wires to keep going up the bank at a decent speed?
If there was no power (and one stalled) then there would be no electric trains for them to hold up anyway...
