Class 88 working recently
D6975
26 Nov 2009
Bristol
Nothing sudden about it, 88s have been commonplace on flasks for a couple of years.
We even get them down here in Bristol when the Bridgwater runs, which isn't that often of late.
Class15
30 Dec 2021
North London or Mildmay line
Thanks! About those Bristol workings, are those the first (partly) electric freight so the GW?
D6975
26 Nov 2009
Bristol
No, they only run under the wires from Bristol Parkway to Westerleigh, which is a very short distance, so electric isn't used at all. The flasks are usually either a pair of 68s or a 68/88 pair
Class15
30 Dec 2021
Thanks! Very disappointing about the lack of electric freight on the Great Western but if the people in charge can’t bother wiring Wentloog and Acton Bank then not much hope.
Class15
30 Dec 2021
Could I have an update about the situation and whether anyone knows about when the 88s will be back on normal duties? They seem to be back on the Tilbury trains but not the Anglo-Scottish ones.
88001 - stored at Crewe?
88002 - Tilbury Intermodals
88003 - at Leeds, anyone know why?
88004 - flasks
88005 - at Crewe
88006 - at Crewe
88007 - at Crewe
88008 - stored at Carlisle?
88009 - at Carlisle
88010 - at Carlisle
Are these correct?
Tractor37
23 May 2017
88004 - flasks
88005 - at Crewe
88006 - at Crewe
88007 - at Crewe
88009 - at Carlisle
88010 - at Carlisle
Are these correct?
88003 at Midland Road, Leeds for tyre turning. Often used by DRS.
50002Superb
18 Aug 2021
88004 - flasks
88005 - at Crewe
88006 - at Crewe
88007 - at Crewe
88009 - at Carlisle
88010 - at Carlisle
Are these correct?
Are 5 and 6 at Gresty Road?
D6975
26 Nov 2009
Bristol
88001 was stored at Crewe, without a pantograph. It has since been moved to Carlisle and back to Crewe again. Does anyone know if it now has a pantograph?
D6975
26 Nov 2009
Bristol
Yes, it moved to Carlisle without a pantograph (paired with a 68) . i wondered if the purpose of the move was to fit a new one.
LA50041
20 Feb 2017
Showing on TOPS as status X (Undergoing maintenance or repair at a TMD or is on a test run)
Northampton
Wentloog would be a big issue with unloading containers under the live wire, and Acton Bank is much more trouble than it's worth at the moment (neutral sections close to stopping points on steep gradients etc). Those sort of gaps aren't half as problematic once you've got last-mile capability, it's the big runs like Westerleigh-Birmingham or Didcot-Coventry that are stopping electric freight on the GW.
Class15
30 Dec 2021
Does a shunter exist to you?
Northampton
Got to pay somebody to drive it haven't you? And if shunters are fine, then why is not wiring these places a problem? They could pull into a suitably close loop/yard, drop the shunter on and get moved into the loop. Pengam Sidings or Alexandra Dock and Acton Yards, in these cases.
Also, freight is a happy accident to electrification - the business case is always on passenger journeys.
Class15
30 Dec 2021
Wire reception sidings and get a shunter to shunt around. How do Trafford Park, Coatbridge, Garston and Daventry work then?
Northampton
Largely by being diesel hauled and using the main loco to shunt around. However there are some electric worked freights to these yards and they do have reception roads for just this purpose. But they come with greater handling time and higher operating costs, as well as needing either slots with nearby signallers (at Daventry) or to shunt onto mainline-controlled sidings (at Trafford Park). Don't know about Coatbridge and Garston.
But this is all stuff that would be resolved by a Class 88, as they have the power to shunt such trains around yards and to bridge short sections of slow speed unwired track.
Class15
30 Dec 2021
Then why don’t we order more bi- or tri-modes?
JKF
29 May 2019
They have used a pair of 88s too - 30/11/22 and 7/12/22 workings to Bridgwater were 88009 & 88002.
Pep and co
17 May 2019
Any updates regarding the status of 88006 and 88008?
Thanks in advance for any information about these locos
