Class 83 at Reading 1979/1980ish.
Ashley Hill
8 Dec 2019
The West Country
This evening I was told of an event that took place around 1979/80. Due to OHLE damage at Hemel Hempstead a postal train hauled by a class 83 was diverted,first to Birmingham NS and via the WR to Reading. It seems on arrival at Birmingham NS a Saltley crew with a Peak was attached and dragged the train to Reading. There (surprisingly) the seagulls said we don’t sign past here,unhooked and disappeared into the distance with the peak leaving the 83 and its train stranded at Reading. Some hours later apparently a 50 arrived and dragged the train to Euston via Acton Wells. Can anyone corroborate this and more importantly are there any pictures of the 83 at Reading?
D7666
12 Aug 2013
This evening I was told of an event that took place around 1979/80. Due to OHLE damage at Hemel Hempstead a postal train hauled by a class 83 was diverted vis the WR to Reading. It seems on arrival at Birmingham NS a Saltley crew with a Peak was attached and dragged the train to Reading. There (surprisingly) the seagulls said we don’t sign past here,unhooked and disappeared into the distance with the peak leaving the 83 and its train stranded at Reading. Some hours later apparently a 50 arrived and dragged the train to Euston via Acton Wells. Can anyone corroborate this and more importantly are there any pictures of the 83 at Reading?
I vaguely remember something of this ilk no gen - oddly it is the 45/46, then 50 into Euston I can sort of recall, not the ACL bit, but that's not to say it didn't happen. ISTR something about it was supposed to go via Wycombe with a Banbury crew relieving. 40+ years ago, too many grey cells dead, and still a student at the time and not as fully into the WMids stuff as I was by 1981.
However, it is true Reading was the nominal limit of default Saltley enginemen route knowledge at that time; individuals may have known beyond, at depot level no.
There are far far too many fables myths and legends about what Saltley was alleged to have done - and in this particular direction - via Reading - many of the oddball workings were actually NewST *** enginemen not Saltley. NS depot probably had a bigger route mileage knowledge than SY, and an equally wide traction range but of different types - what NS lacked across diesel classes they made up by ACL and EMU classes. Everyone forgets NS, who just got on with it, without bragging about it or creating seagull badges and myths. Wolverhampton depot also had almost as wide a range of knowledge as NS and I think knew Padd too.
For example AFAIR diesels NS knew - I think - (24) 25 31 * 40 45 45 47 50 and Banbury also 20 and 33, and both knew Paddington via both Oxford and Wycombe; when you look towards Reading, in the 79s/80s era referred SY did know that lot and 37 56 58 - but w.r.t. roads SY not beyond Reading. Yet even at the time neds were stating SY did this that and the other when actually NS did. Drags to/from Padd, planned drags were all booked 50 or 47/4 (ETH for coffins) and from the LM end with NS/WN crew, so no issues, emergency drags used any on hand crew and power e.g. 56/58s with conducting arranged as necessary.
Yes, as always, there were individuals transferred from other depots to SY that knew Padd, and back then that was 'allowed' if confident of competence, but that did not mean SY as a depot did. Cue all sorts of wibble about 34567 doing 1X76 on the fourth blue moon in Febrytober in 197x but these were the exceptions where the right individual was in the right place at the right time, and 'fixes' of traction types also often involved fixing of enginemen working (overtime !!!) .
Where I say crews at depots here obviously this allows for links.
Anyway, the reason for this rant is I would say it is right that by default a SY crew would not work beyond Reading as they did not know it, and finding a WR crew at Reading that knew 45/46 would also have been not easy, and the obvious step is those crew remove the loco and themselves.
*** and often Banbury
* NS may have learnt 37 later as 37s work spread across LM; not sure on that point except NS not knew them early 80s anyway
Ashley Hill
8 Dec 2019
The West Country
The driver and secondman on the 83 were Euston men. It is the secondman (now driver) who recalled this story. Several others in the group nodded along in agreement.
I’ve tried looking on the internet for further details on this but hit nothing. I’d have thought an 83 at Reading would have attracted a lot of attention given that it and its train were there until late morning apparently. Did it make the railway press at the time?
6Gman
1 May 2012
Around 1979 I'm pretty sure we sent Saltley men as far as Eastleigh, though I may be misremembering.
D7666
12 Aug 2013
Unless it has been relocated this morning, Eastleigh is beyond Reading in a different direction from where I said QUOTE in this particular direction UNQUOTE as the thread is clearly referring to the direction west to east through Reading, not a west to west reversal or west to south bypass.
D7666
12 Aug 2013
Im really trying to find out if this actually happened and not trying to discuss how far Saltley crews flew.
appreciate that, but you did post surprise over the crew issue in the OP hence my comment directly relevant to the question as it may be the clue to why - if the event happened as described - such a train was left there without diesel loco.
westernpunk
16 Apr 2024
Crediton
as an aside about 1973 a friend said he saw early hours a 73 collect a failed 33 from exeter sp no photo no one believed him not saying it didnt happen
randyrippley
21 Feb 2016
finding a WR crew at Reading that knew 45/46 would also have been not easy,pt NS not knew them early 80s anyway
But surely Peaks were still in force on the WR then?
Thought they were still used on the Paddington-Torbay services as well as NE-SW
Shaw S Hunter
21 Apr 2016
Over The Hill
Surely Peaks into Paddington would have ceased after the last 50s moved from Crewe to Bristol in 1975/6. Though equally Peaks continued to occasionally reach Reading after that from the Birmingham direction.
D7666
12 Aug 2013
They were yes, but would you find a crew at Reading who knew them when one turns up at random.
IIRC those passenger workings into Padd were all enginemen from Exeter or west thereof; I don't think Westbury were involved with those.
I am less certain of WR depot traction knowledge - but I question that WR London division knew 45/46 at all.
So quite a number of swiss cheese holes have to align for a random 45/46 arrival at Reading for an available non LOndon Division crew to work it with enough time on their shift left to work to and across London and then get home.
Ashley Hill
8 Dec 2019
The West Country
Just to clarify in this case,the 45 that dragged the 83 to Reading returned to Birmingham. There was never any intention of it going into Paddington. The train was being supposedly dragged from Birmingham to Euston via Reading. The 50 then dragged the electric to Euston later that morning. The Euston crew from the 83 conducted the WR crew on the 50.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
There were still Peaks working into Paddington in the 1980s, I believe as part of a triangular diagram, Birmingham-Cardiff-Paddington-Birmingham, the last part being the 1307 Paddington-Liverpool, presumably as far as New Street. The 1307 was a regular train home from Reading for me, and in 1983 produced the following;
Thu 16th June 45131
Thu 28th July 45111
Thu 27th and Fri 28th October 45148
Thu 29th December 45118
Obviously all the Drivers involved knew the traction!
Shaw S Hunter
21 Apr 2016
Over The Hill
Thu 16th June 45131
Thu 28th July 45111
I guess that shows it's still possible to be surprised by gen from the pre-internet era. A brief search of Flickr shows photographic evidence of such unlikely events does exist. I wonder how many here remember checking Ceefax each Wednesday trying to work out the coming weekend's interesting diversions?
D1537
11 Jul 2019
North Yorkshire
Thu 16th June 45131
Thu 28th July 45111
Nearly but not quite! The diagram started at Bristol and was
ECS Bristol-Weston
2C10 0642 Weston-Cardiff
1A15 0935 Cardiff-Paddington
1M14 1307 Paddington-Birmingham
1V95 1935 Birmingham-Bristol
Ashley Hill
8 Dec 2019
The West Country
I’m surprised no information has come forward on this. The person concerned is a long life enthusiast and railwayman and I’ve no real reason to doubt him. Generally it’s well documented when something unusual happens but clearly this hasn’t happened here. An 83 at Reading would have been quite a coup at the time. I don’t think I was spun a yarn as there were several people in attendance who had already heard his tale. This therefore will go down as one of those unprovable legends.
D7666
12 Aug 2013
I do know someone who was a BR WR parcels manager and actually lived in Reading then and still does now; he was a WR man but I bet he knows something of this if it did take place. He is still around, and I know for sure some in here will know who this leading ;) man is. However, to my knowledge does not even have email never mind web access; when next our paths cross maybe I will remember to interrogate him.
I'm not really surprised you are getting little response, if it were a passenger train yes, but as soon as one starts on non passenger on a specific date of a specific train at a specific location, the specific gen is never forthcoming. Except when someone finds a picture in flickr etc, a search that you have already no doubt done yourself or others would have found by now.
Peter Mugridge
8 Apr 2010
Oakham
If it was a midweek day... in the early 1980s... there'd hardly have been any enthusiasts around on the day in question as the working week was a lot less flexible than it is now; couple that with no internet, no mobile phones, word of mouth gen only... especially if it was arranged at the last minute...
I don't doubt it happened, but the chances of anyone actually getting a picture of it ( which would have been on film so rare though it was likely only one or two images would have been grabbed ) must be quite remote - and over 40 years on from the event, how many of the few who would have observed it would likely still be around, let alone on this forum?
Cowley
15 Apr 2016
Devon
Although it’s more talking about 86s and 87s, are there any clues to be found in this thread from 2017?
nw1
9 Aug 2013
Interesting, I would have seen the 1307 Paddington-Liverpool at Reading on three occasions in early 1984 (IIRC the dates were: Thurs 5/1/84, Sat 10/3/84 and Thurs 19/4/84) and I don't think I remember it being hauled by a 45 but I could be wrong. I do seem to vaguely remember seeing a 45 at Reading at one of these occasions but I have a feeling it was the southbound Derby-Brighton.
I have a vague idea it was a 47 on two occasions and a 50 on the third, but I might be wrong.
Falcon1200
14 Jun 2021
It wasn't a 45 every day, presumably it depended what locos Bath Road had available. My records for 1984 show;
Thu 19 Jan 45134
Wed 08 Feb 47567
Wed 15 Feb 45115
And that's as far as I can go, as in March 84 I moved to Scotland!
Ashley Hill
8 Dec 2019
The West Country
Thanks for linking,but not in this case.
nw1
9 Aug 2013
Thu 19 Jan 45134
Wed 08 Feb 47567
Wed 15 Feb 45115
Ah, OK - thanks.
Harpo
21 Aug 2024
Newport
ECS Bristol-Weston
Booked for a 50 as I recall? Canton driver into Padd and a NS driver back out. Canton’s training on 50s seemed not to get very far despite having a training loco for a while that also did the 2000 Cardiff-Crewe and 0147(?) return courtesy of three Hereford drivers.
