Class 800 Interior Redesign Project
Peter Mugridge
8 Apr 2010
Epsom
There are only two things I would change:
1) Make the seats softer - but keep them the same shape, size and layout.
2) Reduce the harshness of the interior lighting. It's uncomfortable on the eyes at night.
That's a good point, the lighting could be softer and classier - spotlights, a warmer colour and perhaps even aircraft style use of colour would be good. It's not the worst (as it's at least indirect) but it could be better.
43096
23 Nov 2015
Having had the misfortune to use these on the East Coast for reasonably long journeys (London-Leeds), it's quite simple:
- rip the bogies off and replace with something that actually rides smoothly. If it isn't as good as a Mark 3 at 125mph, then it's not up to scratch.
- gut the interiors and start again. If it isn't up to DB ICE standards, then it's not good enough.
If you want the rail industry view on these things, have a read of Ian Walmsley's piece in the current Modern Railways.
It's interesting that Bombardier were proposing a classic LHCS solution. I wonder what that would have looked like?
I'll create a thread on this for further discussion.
py_megapixel
5 Nov 2018
Northern England
To be fair, the ICE is very much a premium service, where there is usually a sensible alternative. while LNER has to cater for everyone.
To be honest I don't really care about the ride; it's maybe a little bumpier than a Mk3 but perfectly acceptable.
43096
23 Nov 2015
It's DB's premier long distance fleet, as the 80x fleets are for LNER and GWR. I see no reason for having lower expectations here.
I can't believe that we are accepting a worse ride - and it is significantly worse - than a Mark 3. It's just embarrassing that a 50-year-old design is better than what there is now: my car offers a smoother ride than the equivalent in the 1970s. Or are we saying that the BT10 is perfection and will never be matched?
py_megapixel
5 Nov 2018
Northern England
I don't think we shouldn't have high expecations; it's just that a higher standard would drive up fares and make the train less attractive because of the shortage of public transport funding in this country.
The thing about the ICE is that it's often not the only sensible route from A to B - there are IC and RE services which are an alternative. Whereas on most medium to long distance East Coast or GWML journeys - at least those in and out of London - an LNER or GWR 800 will be pretty much the only option. The UK really lacks a mid-tier option.
When the new FirstGroup east coast open access operation launches there will be a more budget-orientated competitor to LNER, and then one could argue that LNER is the premium service and should have more put into it. But still, there will only be a few open access trains a day so most will still be stuck on LNER.
Admittedly yes, but I just don't think it's a massive deal. There are far worse issues with IETs that need to be sorted out first.
Plus it's not like the engineering hasn't progressed. Compare a the 319s to the Desiros on the west coast for example; the Desiros are very smoother, quieter, more reliable and have better acceleration compared to the 319.
My suspicion is that they just cheaped out to be honest. I don't think the engineering is incapable of delivering anything better; I think the money just wasn't there.
I wouldn't say smoother. Desiros are great, but they ride like a cart.
If you don't believe me, try a LNR service that traverses Ledburn and attempt the use of the facilities for a standing performance while it does so. You might want to bring a mop.
London Trains
9 Oct 2017
Both very rough rides. On the south WCML 377s have a much better ride quality to 350s or 319s
I don't get why Mk3s are considered a benchmark, anyway - I've always considered them quite rough with a pronounced sway due to inadequate side-to-side damping. Mind you Mk4s are truly terrible.
The Class 158, for under 100mph, is as good as it gets. For 125mph it has to be the heavyweight Super Voyager, though even the 220/222 aren't bad, which shows that inside-frame bogies aren't by definition bad.
py_megapixel
5 Nov 2018
Northern England
I still maintain that the Desiros are far preferable to the 319s when it comes to ride quality. You're right however that it was not the best comparison but my point still stands; it is not that the engineering has become worse, merely that it is not being used to it's full potential
tetudo boy
5 Apr 2018
Near Liverpool
Tobi Wan, can you answer a few questions for me?
  1. Are you actually making your own layout and design for the interior with an illustration?
  1. If you are making one, are you actually considering to show this to the DfT/Hitachi?
  1. Will you do the same with the Class 801 and 802's, and the LNER, Hull Trains, and TPE Hitachi units?
Your project seems to be very ambitious, I like it!
YorksLad12
5 Feb 2020
3. Fit luggage racks in all 4 of the door pockets, removing 8 seats per coach. This will make luggage provision about the right level and get rid of those highly undesirable seats.
When I last travelled LNER, mid-March, the pair of seats opposite each luggage rack had covers on them saying something along the lines of "don't sit here, use these seats for luggage". I said they used as such when I first saw them; with no windows those seats would be better as luggage racks than seating at Standard Open prices. Better seat space than the Mark 4s though, almost up to Mark 3 standard I think.
The seat back trays in Standard are poor; there's a wire pull-out which isn't great for laptops, and the laptop covers both cup holders. And things still roll off them... never happened on a 125 as the seat trays had curved edges :lol:
In First, in the single seats (cells), it seems odd to have a table leg when the table can be secured to the window and the seat in front. That leg gets in the way of my poorly leg, and my bag. I actually prefer the layout in the Mark 4 coaches with the 2+1 seating swapping over halfway down. Means you can have a single seat on the 'shaded' side, whereas now I'm always on the eastern side, usually with back to travel if I want a seat with a whole window.
Also: the plug sockets aren't easy to find unless you know what to look for. Minor quibble, but I'd have them in front of the passenger rather than behind and to one side.
TT-ONR-NRN
30 Dec 2016
Cambridge
1) Allow leather seats in first class, like Mallard ones or the old FGW type Chiltern have in the business zone
2) Dividers like LNER HSTs, with fake wood effect. The carriages are far too long otherwise, it’s like being on an aeroplane.
3) Nicer seats of course
4) Get rid of the what are in my opinion horrific disgusting announcements by Neil Rudd on the Novas - the sarcastic sounding Yorkshire voice. Even the dead sounding woman on the 350s was better.
5) Add a cafebar to ALL 80x trains not just Azumas
long shot
6) Refit with plug doors so they flush with the bodyside. Pocket doors look horribly dated on brand new express trains
The doors don't affect the passenger experience at all; surely the funds could be better spent elsewhere?
The only effect they really have (apart from looks) is the pockets have no windows, but as luggage provision is inadequate that's easily fixed - put luggage racks in all 4 of those spaces per coach, or maybe a "pram dock" in one of the 4.
59CosG95
18 Aug 2013
Beeston (Notts)
Of course, another reason why the doors are the way they are is the pressure seal; this inflates above a certain speed to stop air whistling through the doors and into the train.
Whether the addition of outside air to the vestibules is a pro or a con is a personal matter! It certainly helps prevent people's ears popping when barrelling into a tunnel.
Pretty much all designs of Shinkansen in Japan (from the 1960s to the present day) have doors designed in this way for that very reason...although I can't deny that many of their interiors are airline-esque!
py_megapixel
5 Nov 2018
Northern England
Even if plug doors were to be fitted (which is a crazy idea which will probably never happen) they would presumably not cut windows through the door pockets.
Tobi_Wan
22 May 2020
Warwickshire
Apologies for the radio silence everyone, life took a turn for the busier recently.
I have recorded all of your advice an thoughts - thank you all for your help and direction! Keep an eye on the thread for some initial design ideas in the coming weeks.
Stay safe and all the best.
Tobi_Wan
22 May 2020
Warwickshire
Hi there - absolutely!
1: Yes. This will start in 2D, with sketches and rough models used to develop the design and gain feedback. When the design has progressed iteratively it will move into 3D, so CAD and renders. This will allow the design to be examined and presented in the best detail possible - VR could potentially involved if my student budget stretches!
I will also explore 3D printing certain elements of the interior for testing, such as grab handles, buttons or any other element in the interior.
2: I hope so! Ultimately I’m studying transport design as I’m passionate about our railways, if this project gets me in a room with a potential employer like hitachi then the project will have been a success. If they actually want to use the ideas from the project then even better, as hopefully it’ll improve the travelling experience for passengers.
3: In the timeframe of the project this would be stretching it, I only have 10 weeks from now to complete the above tasks. However the interior design will be made to fit the class 801/802 chassis, so all elements are applicable to LNER, Hull Trains and TPE stock. The designs will be rendered up in GWR livery however.
Many thanks for your interest!
Clansman
4 Jan 2016
In all fairness the Mk3 preferences are often distorted by ridiculous things like the nostalgia of the droplights and memorable bouncy suspensions. But there's a valid point to be had when it is in regards to how space is maximised in ways that isn't compatible with safety regs or the technical requirements of TOCs these days (ie lower floor than MUs, untappered bodies, and higher placed minimally reflective windows at wider spacings than your average MU). I've a feeling this is what people use as a benchmark.
PG
Thanks - this comment has reminded me of the need for a redesign of the non-accessible toilets on the 80x. Currently they invariably have wet floors (most likely due to the sink/water outlet) which isn't appealing. See also this post from a different thread:
The toilets in these, while a step up from the HST (which isn't difficult give the age difference) are another area of poor design. The door is heavy and clunky, and the location of the lock can be confusing to some passengers. I don't like the fact it is the same level as the sink, as it does catch water. The design of the sink / tap unit regularly allows water to end up on the floor (hence the floor often finding itself being flooded), and the hand drier is often temperamental.
On the subject of external doors this post, again from another thread mentions the steps required to keep them operating. Maybe plug doors would be worthwhile in your redesign if only to prevent units having to be taken out of service for door faults which seem inherent by design!
Biggest failing to me is the ride and the sliding doors with door pockets rather than the plug type.
I'm old enough to remember that after a winter of frozen door tracks NSE said they would only buy trains with plug doors. Fast forward to last year an staff were reportedly using vaseline to try stop the door tracks freezing. Hmm dont we re learn eveything every 10 years or so.
tetudo boy
5 Apr 2018
Near Liverpool
I'd also like to see seats that change to the direction of travel. TGV InOui has done such thing. Of course, the face-to-face seats would not change.
tetudo boy
5 Apr 2018
Near Liverpool
Maybe you could use the standard livery to avoid confusion. It would look like you were only doing it for GWR and not other companies if you did it like that. I'm talking about this livery:Hitachi_Super_Express_mockup_(1).jpg
The interior also has its own standard brand:Hitachi_Class_800_series_-_First_Class_interior.jpg
I would recommend using these, but then again, you don't have to use them.
jimm
6 Apr 2012
Try to get as many samples of people who have made a journey longer than 4 hours and go through asking them how comfortable they felt. After all, that's the primary purpose of these trains.
The only GWR journeys that IETs work that take four hours or more are between London and Cornish stations or the limited services to Carmarthen and Pembroke Dock.
The overwhelming majority of passengers on GWR's High Speed Services are travelling for no more than two hours and plenty for much less than that.
In less than or about two hours, you can get to Bristol, Cardiff, Taunton, Exeter, Gloucester/Cheltenham and Worcester (never mind the likes of Oxford and Swindon in 50 minutes), with Plymouth, Swansea and Hereford around the 2hrs 45 mins to three hours mark.
Meanwhile on LNER a lot of the custom is to and from Yorkshire, with York a two-hour run and Leeds two-and-a-quarter hours.
coppercapped
13 Sep 2015
Reading
I do not agree with the premise of your argument.
BR was also strapped for cash - yet managed to produce in the BT10, Series 3 and Series 4 (as used under the Class 158s) bogies designs which generally ride better that current designs. I exclude the Siemens DC units on the South Western from this blanket condemnation - these units are smooth and quiet.
No consideration was paid to the quality of the ride in those trains procured by the DfT directly as quality of ride was not a factor in the procurement.
One other thing - in Germany the ICE services are the only ones which run long distances between different Länder with a limited number of stops. The EC and IC services are slower because the additional stops they make and the RE services are largely funded by the individual Länder so are limited to operation within the funding Land. Of course some of these cross borders to terminate at at town or city where traffic flows make it sensible but as a rule they are not ideal for long distance journeys crossing from one Land to another.
So, for short(ish) distances the IC and REs offer an alternative - but I wouldn't want to use them from München to Hamburg,
py_megapixel
5 Nov 2018
Northern England
That is exactly what I am saying. It's not that modern technology is incapable of producing high ride quality, it's that the DfT gave no consideration to it.
I just believe that there are more important things that need to be sorted out with the IET fleet first.
class26
4 May 2011
It isn`t so much they gave no consideration but they cocked up the contract by making certain essential aspects such as ride quality "desirable" rather than essential. This meant that anything not essential got the cheapest option. See the article in June`s Modern Railways,
